Rekluse Auto Clutch for F800GS
Discussion in 'Parallel Universe' started by toro618, Apr 18, 2012.
  1. pklop
    pklop Motorcycle addict
    Apr 1, 2010
    479
    Holland
    Thanks - do appreciate your insights!
    I count myself to the "normal users" group (with moderate skills) so that's a plus in this case :thumb
    I find the stock clutch pull to be to hard for longer sessions doing lots of technical stuff. Are you saying that the rekluse makes it even harder? Or did you mean this compared to the magura you had to remove. Because, asuming that the clutch has to be used less frequent because of the rekluse, i could live with the effort needed, but not if it gets even harder.
    Since you already tried the magura we seems to be at a dead end with that (easy clutch pull + rekluse). Even an easy-pull clutch like the RSC (http://www.righteousstuntmetal.com/international/levers.html) shortens the cable stroke so that's a no-go it seems.
  2. LNICK
    LNICK Adventurer
    Feb 4, 2016
    12
    Rio de Janeiro
    Haha pklop is getting old as me. Unavoidable! :lol3:lol3:lol3
    pklop likes this.
  3. Zé
    Been here awhile
    Apr 19, 2014
    101
    Lisboa - Portugal
    As far as I'm concerned, its harder then OEM without the Rekluse. But we do use the clutch a looooooootttttttt less with the rekluse under normal use, so it being heavier its hardly noticeable after a few rides. Only when you start pulling it a lot for more extreme or hard riding does it become actually too heavy on the arm. But still, not all kinds of terrain or thecniques require this. So you can spend days on end just using the clutch for shifting even while riding some thought and technical terrains.
    What I mean is that I would get it again on the spot, even if it was harder then it actually is :D It is not a no-go situation. Not comfortable, but definitely not a no go.
    I'm playing around with some ideas on how to make it lighter, but until then, a longer arm on the clutch lever straight out of the engine case will definitely help out. I know I'll go down this road soon. Something like this
    If I'm not mistaken this picture is already here on the thread somewhere
    pklop likes this.
  4. Lost-n-Lovin-It
    Lost-n-Lovin-It Lurker
    Feb 28, 2012
    201
    Maple Valley, Wa
    Has anyone worn one of these out yet?
    Curious if you have to buy a whole new setup from Recluse plus an OEM clutch pack to do a rebuild or if there is a cheaper way.
    I love the sounds of getting a Recluse for mine, but all clutches wear out eventually and I'm wondering how much it costs to fix once it does.
    Thanks.
  5. Loutre
    Loutre Cosmopolitan Adv Super Moderator
    Nov 28, 2010
    14,227
    :o)
    you just need a couple of discs not a whole new clutch
  6. Lost-n-Lovin-It
    Feb 28, 2012
    201
    Maple Valley, Wa
    Sounds great. Where can I get the individual disks?
  7. Loutre
    Nov 28, 2010
    14,227
    :o)
    euh... from your used clutch.. normally there are always a couple that aren't too badly worn, otherwise you'll need to make out used parts or ahead and buy the whole kit from BMW
  8. Lost-n-Lovin-It
    Feb 28, 2012
    201
    Maple Valley, Wa
    Sorry if this is a stupid question, but how do you rebuild a clutch with the old worn out parts?
    All my experience has been on bikes with dry clutches. When they are worn they are to thin to be reused and you throw them out. Are the wet clutches different? Or am I misunderstanding something?
  9. Loutre
    Nov 28, 2010
    14,227
    :o)
    no on the recluse clutch you don't need all plates, means that if some are still good on your old clutch you can use them with the recluse kit. can't recall how many plates you actually need. it is written in here somewhere. on wet clutches not all plates wear the same amount
  10. Reaver
    Reaver How Did I Get Here?
    Aug 7, 2008
    20,992
    Zona Sur Costa Rica
    Rekluse sells complete rebuild kits now, check out the site. I posted a price awhile back but forget now.
  11. Lost-n-Lovin-It
    Feb 28, 2012
    201
    Maple Valley, Wa
    Thanks for all the info. This is going to have to be my next project.
    Just curious, how many miles have people put on these without a major rebuild?
  12. Reaver
    Aug 7, 2008
    20,992
    Zona Sur Costa Rica
    Lots. I'm at only 20 K kms but that's in the Jungle here where I use it all the time.
    Shhhhhhhhh. I'm about to pull it out and rebuild it before I install it into MY bike. Wife doesn't appreciate it enough. :1drink Will post up.
  13. Reaver
    Aug 7, 2008
    20,992
    Zona Sur Costa Rica
    Ahhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhh!
    Dammit.
    I have my Rekluse apart and found wear, slivers etc. Prob is, I ordered 2 pad kits specifying Part #782-002A. They sent me 782-002, which is I assume, a B. The old pads are .185" wide and the new are .215".
    So there's ONE change.
    Yes, I'm in the Jungle without an address.....
    Sent them an email so we'll see what they recommend. They've been great so no complaints.
    Stuff happens.
  14. ebrabaek
    ebrabaek Long timer
    Jan 12, 2010
    5,729
    Grand Valley, Colorado
    They must have changed the pad size after I got out of it. I don't recall seeing g a pad change during prototype testing.
    Bummer, that shows ya how much they have done since I was involved.
    Hope you get it sorted. Let me know if I can help.
  15. Loutre
    Nov 28, 2010
    14,227
    :o)
    see and this is why you should have kept the 8GS
  16. Reaver
    Aug 7, 2008
    20,992
    Zona Sur Costa Rica
    Well Erling, still no reply on my email. Maybe call Jon and get him to read it. Here I am, without my clutch.
    Oh, btw, that CF piece you made me was a highlight here one fine day a month ago, with friends flown in. Thanks again!!
    Shhhhhhhhhhhh.
  17. ebrabaek
    ebrabaek Long timer
    Jan 12, 2010
    5,729
    He he...... I am really liking the big piggie though.
  18. ebrabaek
    ebrabaek Long timer
    Jan 12, 2010
    5,729
    Lemme see what I can do.
    It is good to hear the cf is holding. It was one of my most special builds...... and I was honored to be part of this..... :) can you pm me your email.
  19. atarijedi
    atarijedi Been here awhile
    Jan 15, 2014
    202
    Ontario, Canada
    I'm looking to get an F650GS twin, good to see the issues have been worked out, as I have left arm/hand issues and can't really feather the clutch all that well anymore.
    Are people still receiving the EXP with that rough edge/face which would grind on the teflon pieces and cause shuttering? Doesn't seem to be much of an issue to smooth it out though.
    I currently have a rekluse in my DRZ400SM "Adventure", and I love it. I know it will be different than in the F650GS because I can shift without using the clutch at all, but I believe the Adventure EXP is different? It's simply meant to prevent stalling?
    I'll also note that my DRZ has a wet clutch, and I run Rotella T6 oil in the bike, which was recommended by Rekluse. It is a full synthetic diesel engine oil. Anyone tried that oil yet in their f650gs/f700gs/f800gs?
  20. Lost-n-Lovin-It
    Feb 28, 2012
    201
    Maple Valley, Wa
    Finally jumped on board and got a Rekluse. First thing I did was tear it apart to look for any sharp edges that may cut into the little plastic sliders. Looks to me like they may have improved their machining technique because the milling marks on mine look a little different from past pictures I've seen on this thread and I couldn't find any sharp edges to smooth out.
    Install was easy thanks to the great videos on YouTube. Setting the gap at the end took a few minutes, but I seem to have figured it out.
    Most importantly the test ride went great. It's raining so it was a short ride on some tight single track. Areas that are usually challenging were child's play and one spot I've been hesitant to try on dry days was easily conquered. So far I'm impressed and would recommend this mod.
