removing conventional fork seals without disassembly
Discussion in 'Old's Cool' started by xtphreak, Feb 17, 2007.
  1. xtphreak
    xtphreak from B4 "adventure bikes"
    Jul 21, 2004
    7,966
    Back-n-forth [GA & WNC]
    ok lazy bastid I is
    whoops
    efficent person I am
    tried something a little different this afternoon
    GPz needed fork seals
    originals been in there since 1984
    and a couple thousand miles :evil
    here's the deal
    remove fork caps
    pull springs
    pull fork legs
    remove dust seals, circlips, shim washers (everything that holds the oil seal in or could hold it in, like a shim washer slipped to the side)
    fill fork with 10W-40 ('cause I had a bottle sitting there) to the bottom of the cap threads ... object is to have as little air inside as possible
    reinstall fork caps (both inner & outer on GPz)
    ok on the GPz, kawasaki had a brain fart on the air forks
    instead of a sniffle valve in each cap or leg, they drilled an itty-bitty hole in the fork tube and used a double collar thingy connected with a tube.
    plugged that with a pc of inner tube and a hose clamp
    put fork over a pan
    put a wood block between the fork bottom and a wall
    put a bottle jack on the other end with sufficent blocks to reach a fairly immovable object (deck post)
    put rag over seal area to forestall a geyser of oil (I went slow and didn't need it, but if I hadn't I would have for sure)
    as you extend the jack, slowly, the fork tries to compress, but oil don't compress very well, so the pressure seeks the point of least resistance ... i.e. rubber seal without any retaining devices (you did remove them right??)
    tadaaa
    as I stroked the jack handle, I could see the seal easing out :clap
    be aware that sometimes you should wait a minute between strokes as the seal will try to remain in place.
    I removed the spring because I'm a wimp :nod
    I do not test things with methods that STORE ENERGY that can hurt my tender ass. :nono
    Like SPRINGS that compress and then when the jack or a block slips ... BWANG!!!
    the fork extends quickly, catching a finger or gonad or shin or just jumps off and lands on the floor with a sickening clatter.
    or AIR.
    Damnit air will act like a spring :nod
    same same
    if you need to test something for pressure (tank, pipe, etc) fill it almost full with water or oil and then apply air in a very smalll volume. if it bursts, 100 cc of air at 100 psig will not hurt as bad as 5 cu ft of air at 100 psig.
    ok
    it worked really good
    forks are draining overnight
    a pc of 1 1/2" PVC conduit is perzactly the right diameter to slip ove the fork leg but still fit into the seal area to tap the new seal into place
    replace the washer, circlip, dust seal on each ... reinstall fork legs into triple tree
    refill to spec with new forking oil
    reinstall springs, caps (on GPz inner caps only) handlebars, outer caps, front wheel, brakes, fairing,
    take for a test ride (who cares if it's only 22 outside??)
    next week we'll discuss replacing the piston rings thru the tailpipe :D
  2. knybanjo
    knybanjo kinda slow
    May 8, 2006
    36,003
    out in the clover patch
    :clap
    :thumb
    :lurk
  3. xtphreak
    Jul 21, 2004
    7,966
    just stay tuned
    same bat time
    same bat channel
    :wave
  4. Stagehand
    Stagehand Imperfectionist
    Oct 6, 2004
    33,270
    Turicum
    :lol3 :lol3
  5. norton73
    norton73 drinkin' Supporter
    Dec 20, 2003
    13,128
    Beautiful Downtown Springville, Alabama
    Pretty inventive there, Ron. Looking forward to the piston ring post, as I've got this to do in the near future;
  6. xtphreak
    Jul 21, 2004
    7,966
    that should be a piece of cake with that easy radius curve
    :rofl
    hiya Andy :wave
    coming to the Rendezvous THIS year or you gonna come up with another excuse?? :ear
  7. cpatstone
    cpatstone N00b, obviously.
    Jul 26, 2004
    347
    Western MA
    I wanna know how many times you checked the porch post. :rofl
  8. xtphreak
    Jul 21, 2004
    7,966
    once to start with :huh
    it's set good and deep and concreted too
    started to use the 12X12 on the back deck, but figured the seal wouldn't be that stubborn ... and they're 12 feet apart
    and no convenient old deck to work on
    if I got oil on the hot tub deck phreakwife'd have my a$$
    #8
  9. norton73
    Dec 20, 2003
    13,128
    Mebbee yes, mebbee no. :dunno
    That's way to far out for me to plan :norton
    #9
  10. Motomech
    Motomech Adventurer in Latin Amer.
    Dec 29, 2005
    337
    Playas del Cocos, Costa Rica
    How about the easy way;
    1]Put the inner tube in a vise(soft jaws or a rag, as not to scratch).
    2]Put pan under to catch old oil.
    3]Put 8m/m Allen socket attached to air wrench into the holding bolt located in the recess at the bottom of the lower fork leg.
    4]While pulling on lower fork leg, zap out holding bolt with air wrench.
    Vola, it's apart.
    This can be done without removing the fork tubes from the clamps.
    #10
  11. xtphreak
    Jul 21, 2004
    7,966
    1) but you pulled the steering head to get it up to the bench to "...Put the inner tube in a vise... This can be done without removing the fork tubes from the clamps"???
    if it's in the clamps (triple trees) why the vise??
    and if it's on the bench what's the difference?
    still have to pull wheel
    2) requires air wrench & compressor to run it
    bottle jack at HF = $8
    walmart 10W-40 oil = $1.24 (actually free since it was open and sitting on the shelf)
    easy is as easy does :dunno
    I like my way
    #11
  12. Motomech
    Dec 29, 2005
    337
    I didn't DO anything, you did.
    I'm just telling you the way I used to replace fork seals when I was working as a tech.
    If all that was required was fork seals and oil, then the inner tubes would not be removed from the clamps.
    I would just put the frt. end of the bike in the air(center stand and tie downs on the back) with the wheel removed and pop off the lower legs as described above.
    Once I replaced the seals, I would put the bolt back into the lower leg with a dab of silicone, fill the leg with the prescribed amount and weight oil and zap it back on.
    This was one of the best jobs in the shop because it payed two hr.s and I could do it in less than one.
    #12
  13. rowansride
    rowansride recreational menace
    Mar 29, 2004
    164
    Homer, AK Kenai Peninsula
    I just used a screwdriver... Maybe I should try something more difficult next time.
    Looking forward to writeup on head cleaning using scanning electron microscope and carrion beetles.
    #13
  14. xtphreak
    Jul 21, 2004
    7,966
    sure ya can use a screwdriver or an ice pick or anything else as long as you're ok with nicks and scratches
    go fer it & getter done
    #14
  15. knybanjo
    knybanjo kinda slow
    May 8, 2006
    36,003
    :waveI just gave your "lazy" method a try and it worked just fine!
    On the old DR650 it just seemed easier to pull the leg off the bike than to separate the 2 halves.
    took out spring
    added a bit of oil
    replaced cap
    seal eased right on out with just a few pumps!:thumb
    I didn't have any PVC pipe big enough to make a seal driver.....but.....
    I did find a cardboard tube the right size and the new seals snapped right into place!:D
    I guess I should have taken a pic or 2.........
    #15
  16. xtphreak
    Jul 21, 2004
    7,966
    Hiya :wave
    I found it easier to pull the forks out too
    I's a lazy ...err efficent bastidg
    I gotta find somewhere to host me pics and relink the helpful stuff
    maybe just repost all that TB trash :dunno
    #16
