1. eNewsletter Sign Up
Removing Factory Tank Liner and New Casewell
Discussion in 'Airheads' started by Gismofx, Jan 3, 2020.
  1. Gismofx
    Gismofx Adventurer
    Oct 27, 2018
    14
    Florida
    My 78 R100 had a poorly repaired hole in bottom of the tank. Needless to say, it was slowly leaking. I brazed a little patch over it and that’s fixed. Next, the rust and decayed factory red liner. I decided upon casewell epoxy liner, but prepping the tank first. I tried a “safe” stripper and got nowhere. Then, went with methlyene chloride. I was expecting all the liner to be removed, but it’s still “mostly” intact. I did the sloshing around with chains in the tank and a lot of gunky liner came out, but not all.
    Does all of the old liner need to come out before casewell liner is applied. Also, I was planning to use Phosphoric Acid prior to casewell liner.
    Are there any additional steps? Any chemicals/rinses between the phosphoric acid and the casewell liner?
  2. satmanski
    satmanski Sausage Creature
    Aug 11, 2015
    159
    Spokane, WA
    You will find that a lot of people have used industrial white vinegar which is available at home depot and cheap. I used the POR 15 cleaner degreaser and a big chunk of chain. Same thing, plan on leaving it in and sloshing it around. To answer your question your tank needs to be absolutely bare metal for the new liner to work. Don't get impatient. I didn't use the casewell so I can't say what steps it requires. If you have a change of heart on the casewell I can vouch for the POR15 tank liner system. Did a great job on my tank.
    KatCon85 and Gismofx like this.
  3. TwoShoes
    TwoShoes How Many Shoes?
    Aug 18, 2003
    476
    Fredericton, New Brunswick, Canada
    Recent tread on this very subject https://advrider.com/f/threads/rust-and-old-tank-liner-removal.1413618/
    Agree that the tank needs to get to bare metal. I can also agree that the 10 % vinegar works well on the factory liner. I can also vouch for POR15, I had such good luck on that R100/7 tank that I decided to use it on the G/S tank last night with very nice results, I was even able to get it to coat the inner baffle in the big Paris Dakar tank
    Gismofx likes this.
  4. satmanski
    Aug 11, 2015
    159
    Spokane, WA
    Heck, now I want to post my 'after' photo.
    Gismofx likes this.
  5. Big Bamboo
    Big Bamboo Aircooled & Sunbaked Supporter
    Sep 29, 2010
    16,029
    Big Island of Hawaii
    +1 on the cleaning vinegar, and it won't kill your cesspool if you dump it down the drain.
  6. Gismofx
    Gismofx Adventurer
    Oct 27, 2018
    14
    Florida
    Thanks all for the comments!
    Seems almost unanimous regarding vinegar. So, I opted to strip the liner with 10% vinegar. 6 gallons in my tank now and will just flush it through daily(if I can). I can wait until next weekend for the results. Will report back.
  7. TwoShoes
    Aug 18, 2003
    476
    I found the routine of (1) drain vinegar (2) shake chains around when tank is empty to loosen the bits of lining (3) refill with the vinegar
    to be useful. Good luck!
    Gismofx likes this.
  8. KatCon85
    KatCon85 Been here awhile
    May 3, 2013
    107
    Hudson Vally, NY
    I did the white vinegar thing 3 years ago, and Caswell liner. It came out great. 2 things I would mention. after the vinegar and chain, rinse the tank with hot soapy water & baking soda. Then rinse it again with clear water. I used a hair dryer to completely dry the seam in the bottom of the tank. Then let it sit overnight in the house and did the caswell the next day.
    I would mix up more than you need. My kit said "does a 10 gallon tank" so I mixed up 1/2. it ended up a little short, so there was a frantic -mix up a little more - moment towards the end.
    Also, when you apply the liner- do it in a warm location (not your cold winter garage) so the epoxy liner flows a little better.
    #8
    Gismofx and PaulBarton like this.
  9. Gismofx
    Gismofx Adventurer
    Oct 27, 2018
    14
    Florida
    Going well so far! Looks like most of the liner is gone! But I developed a new pin hole near the first larger hole. I’m going to pause and braze this one up and probably do another day or two of vinegar.
    #9
  10. Gismofx
    Gismofx Adventurer
    Oct 27, 2018
    14
    Florida
    From what I can see all the liner is now gone!(about 1 week of vinegar soaking)
    • I flushed the vinegar about 4 times throughout the week
    • I used 5 pieces of 1ft x 1” chain in the emptied tank to help remove the liner between flushing.
    • After shaking with chains for 5-10 minutes, I removed the chains with a magnet and rinsed out the loosened liner bits with a hose
    • I refilled the tank with the same vinegar using a drill powered pump. I attempted to filter the last half gallon or so of vinegar with coffee filter.
    • After all done, I rinsed the tank clean with warm sodium bicarbonate water solution, then fresh water rinse and air dried with a blow dryer. I brought the tank inside and waited a week(busy with other things)
    I’m now beginning a phosphoric acid coating/etching.
    #10
    TwoShoes likes this.
  11. Gismofx
    Gismofx Adventurer
    Oct 27, 2018
    14
    Florida
    I did the phosphoric acid soak, wash, and dry with a blow dryer...and tank looked good. I put the tank aside to finish some other projects. Two months go by and my tank is completely flash rusted.
    I resoaked the tank with phosphoric acid and the flash rust immediately disappeared. Soaked for a day with the occasional shaking. I flushed it with a detergent and then water and then blow dry all night. It still flash rusted almost immediately.
    Is the phosphoric acid supposed to prevent flash rust?
    I have a casewell liner kit but hesitant to apply it at this time
    #11
