Repacking Modern Trials Bike Muffler-Ends
Discussion in 'Trials' started by motobene, Feb 24, 2019.
  1. Yinzer Moto
    Yinzer Moto Long timer Supporter
    Jun 13, 2008
    36,182
    Pittsburgh PA
    :lurk
    #41
  2. Navin
    Navin Long timer
    Sep 22, 2009
    28,233
    If it was a GasGasp yood not have to choose!
    #42
    Yinzer Moto and Ride Sally Ride like this.
  3. Yinzer Moto
    Jun 13, 2008
    36,182
    Pittsburgh PA
    This does not look enjoyable
    #43
    jonnyc21 and Navin like this.
  4. riabma77
    riabma77 Been here awhile
    Nov 29, 2018
    425
    Ruidoso, NM
    Repacking isn't enjoyable, no matter what type of muffler!
    Is there an aftermarket option to replace the OEM?
    #44
  5. Yinzer Moto
    Jun 13, 2008
    36,182
    Pittsburgh PA
    I don’t know. Having to cut it open and weld 30” of aluminum back together is going to suck.
    #45
    jonnyc21 likes this.
  6. riabma77
    Nov 29, 2018
    425
    Ruidoso, NM
    It's hard to tell from the pics, but maybe is possible to adapt the muffler from a newer model? Probably less work than cut and weld?
    #46
  7. Yinzer Moto
    Jun 13, 2008
    36,182
    Pittsburgh PA
    A torch and put a shit ton of heat through it worked pretty well. We did the head pipe and the muffler. Sally’s bike is nice and quiet again. I just burnt it till it quite smoking. I did melt the outlet on the muffler a bit but I got it fixed back up.
    #47
    Buschog and Navin like this.
  8. Yinzer Moto
    Jun 13, 2008
    36,182
    Pittsburgh PA
    #48
    Navin and jonnyc21 like this.
  9. Beatprojim
    Beatprojim Beatprojim Supporter
    Sep 2, 2015
    275
    Acme, PA
    Both Boomboom and I have cut open older Sherco mufflers, cleaned out the old junk, repacked, and then sealed it up again. I had a friend weld mine back together but Boomboom did something else? I forget what he did.
    #49
    Yinzer Moto likes this.
  10. Takataka
    Takataka Been here awhile
    Sep 26, 2014
    514
    NZ
    Just finished burning out the front section of my TRS pipe with great success.
    I used an LPG gas torch to get the fire going in the gunk and then used compressed air to stoke it.
    If you don't have a compressor you could probably use a leaf blower or even a vacuum cleaner with blow option.
    No need for oxygen as air works fine.
    There is absolutely no need to fear melting the alloy exhaust as you can keep the casing cool with a garden hose throughout the process. You need to hose it regularly though as it generates serious heat if you blow it hard with air!
    I actually rubbed some soap in a few places on the exterior as a warning for over heating ( soap turns black well before alloy melts).
    It took about 30 minutes before the smoke stopped coming.
    Result- my bike sounds like brand new again!
    It was so noisy before!
    #50
  11. y4m4
    y4m4 Calvin
    May 24, 2009
    506
    Federal Heights, CO
    I miss living in the middle of nowhere. I would have the whole fire department up my ass if I tried this.
    #51
  12. Takataka
    Sep 26, 2014
    514
    NZ
    The Mrs and I live a few hundred meters from the nearest neighbor so I only got one complaint..
    #52
  13. Takataka
    Sep 26, 2014
    514
    NZ
    OMG the bike has so much more torque now! Wasn't expecting that.
    Anyone with a barky/crackly exhaust has to do this.
    I had forgotten what the bike used to run like.
    #53
  14. Junglejeff1
    Junglejeff1 Long timer
    Oct 20, 2016
    4,626
    Upper Michigan
    I think I stunted the growth of the corn field across the road when I burnt out my last exaust.
    #54
