Repeatedly flat front
Discussion in 'The Garage' started by apostis, Sep 30, 2019.
  1. apostis
    apostis Adventurer
    Jul 10, 2013
    59
    Hi,
    I had a flat tire on 2018 KLR650 a month ago.
    The inner tube had a slit like puncture. I couldn't find anything on the tire thought.
    I put in a new heavy duty tube and a new tire.
    Today about a month later or less I have another flat tire, front tire again.
    What the heck is going on?
    Has anyone experienced this before?
    I'm riding about 6 miles a day, just commuting, no offroading or anything like that.
    New tire is a Shinko sr244. Before it was the original one from when it was new.
    Is this a warranty case?
  2. Beezer
    Beezer Long timer Supporter
    Oct 26, 2004
    10,045
    Anchorage, formerly Spenard (hub of the universe)
    a slit... where? there was a thread here a month or so ago where a tube let go on the welded seam and others chimed in with similar examples. the post also have a video on how tubes are made.
    what brand and do you have a picture
    SmittyBlackstone likes this.
  3. Hohmie
    Hohmie Long timer
    Jan 23, 2013
    1,972
    Bend Or
    I had a broken rim lock that would pinch the tire, I didn't figure it out until I fully dismounted everything.
  4. Bigger Al
    Bigger Al Still a stupid tire guy Supporter
    Oct 12, 2004
    10,019
    Auburn, CA
    Pictures of the slit in the tube would be a huge help.
  5. bwringer
    bwringer Gimpy, Yet Alacritous
    Jan 22, 2008
    3,212
    Indianapolis
    No rim locks on KLRs.
    There are tubes and then there are tubes. Some no-name tubes are shitty tubes, so if you got a shitty one and it split at the seam, is it possible you got another shitty tube?
    It's also quite possible to have a rim with a little burr that's flattening your tubes over and over. I've seen this on bicycles more than once.
    The number one cause of tube punctures is installing them, but AFAIK these always leak immediately. Never really heard of a time delay pinch puncture.
    Edit: Just remembered something... it's possible for something like a shard of glass or a nail to get embedded in the tire tread and only poke through under pressure. Even if you can't see or feel anything on the inside, figure out where it's deflating and give the area a VERY thorough inspection close-up.
    Or install another Shinko 244. They cost about the same as a decent cheeseburger.
  6. Beezer
    Oct 26, 2004
    10,045
    a "slit" in the tube sounds like a tube fail unless there is a really big gash in the sidewall from something sharp, or wrong with the rim (can't picture what). now I'm talkin about clean edges on the cut and not some rub through like you might get from a rimlock. KLRs did not come with locks, but it has been done
  7. Grreatdog
    Grreatdog Long timer Supporter
    Apr 6, 2007
    36,810
    Annapolis, MD
    Every time I have seen someone get repeated flats despite hardly riding there was a thorn, nail or something through the tire they didn't see. My BIL being the last victim after using up all my tubes. When I ran fingers over the inside if his tire I found the thorn he swore wasn't there.
    KeithinSC, dtysdalx2 and sieg like this.
  8. sieg
    sieg Wearing out tires......2 at a time, day after day. Supporter
    Jul 9, 2008
    8,236
    Southern Illinois USA
    What the heck is going on? Well tell us what you found on the second tube, besides that it had no air in it. Was it the same slit as last time?
    Has anyone experienced this before? Experienced what? Two front flats in a month, lots of times.
    #8
  9. apostis
    apostis Adventurer
    Jul 10, 2013
    59
    Firstly thanks for the answers so far.
    To clear a few things up.
    The bike is 8 months old.
    The first tire and tube were the original ones.
    The tube had a tiny slit of maybe 2mm in length. Pic attached.
    On the the tire itself I couldn't find any issue.
    The tire was at the end of it's thread life with 2-3mm of tread left.
    As we all know 2mm is when you should get a new one.
    So I took that opportunity and did that.
    I bought a new heavy duty tube as well, I will see if I can find the brand but it was about $18 in USD, and a new Shinko sr244.
    I installed those and everything was fine for about 600km.
    Now the new tube is flat as well.
    I will dismantle it on the weekend but my guess is it's the same failure, I don't know why else it would be flat. The Sr244 is very knobby so I would have assumed it would take a lot to either penetrate those big knobs or get through valleys of the knobs. The walls of the tire don't have any apparent damage on the outside. I haven't seen anything in the center area either but I have to take a better look.
    Edit: picture is the old tube mind you. I haven't had a chance to take out the new one that's also broken yet.
    #9
  10. Bounder
    Bounder Typing...
    Mar 2, 2011
    2,140
    West Cork, Ireland
    Put the tube next to the Tyre (Tire) and see where the slit is in relation to the tyre and run your bare fingers around the tyre inside. You might find some debris in the tyre that isn't apparent to the eye.
    #10
    trumpet likes this.
  11. apostis
    apostis Adventurer
    Jul 10, 2013
    59
    The picture is the old one but yes if I do find a puncture in the new one I will do that.
    #11
  12. sieg
    Jul 9, 2008
    8,236
    So different tire, different tube, different tube of tube. Seems to be totally unrelated, you just got unlucky.
    #12
    Beezer, Bigger Al and MotoChris521 like this.
  13. Yinzer Moto
    Yinzer Moto Sloppy 300 rider Supporter
    Jun 13, 2008
    40,147
    Pittsburgh PA
    Flat tires are usually just bad luck. There is nothing wrong with 2 flats in 8 months. On a recent trip, we had 7 flats in 12 days of travel.
    When there is a slit, that is usually from the tub getting pinched. A pinch can happen when the tube is low on air. The tube could be low because of a small hole that is elsewhere on it. Just finding a pinch is not the end of your search. Hold that closed with your fingers and reinflate and look for another hole. Another thing to look for, it was rumored that the Shinko factory left foil backed ID tags in tires and people were blaming them for flats. I have not witnessed this first hand.
    #13
  14. apostis
    apostis Adventurer
    Jul 10, 2013
    59
    That just seems so extremely unlikely. On a new knobby tire especially.
    Edit: it's not 8 months, the bike is 8 months old. It's two flat tires within about one month. Just from commuting on asphalt. That just doesn't seem realistic to me. ESPECIALLY considering there is no puncture. And the second tire is a new heavy knobby one with 1cm deep knobs. And the new tube being extra thick. It just seems super fishy to me.
    If I was using the same tire still, or the new tube wasn't an extra thick one or I don't know. But under these circumstances it seems really unlikely to me that this is a coincidence.
    I'll make sure to look for multiple holes on the new broken one when I have it removed.
    #14
  15. Bigger Al
    Oct 12, 2004
    10,019
    Auburn, CA
    The pic looks like a split along where the tube was folded in the box, telling me that it's an older tube. Happens once in a while.
    #15
  16. ohgood
    Sep 21, 2010
    10,086
    alabama
    that looks like a snake bite (pinch flat) to me.
    pull the tire off and wipe it with a dry was off toilet paper. if there is a thorn/staple/etc it will pull paper and mark the spit for you.
    sometimes you need some pressure on the tire to push the thorn through far enough to feel it.
    #16
  17. Sonny S.
    Sonny S. Long timer
    Nov 23, 2015
    3,070
    Maryland
    Are you sure that part of the tube is against the tire and not the rim? Feel the rim for a burr. Clean it up with scotch pad on a die grinder or good by hand. Check the rim strip for damage or a spoke poking through. Then give the rim a few wraps of duct tape or gorilla tape. Also put some powder in the tire when installing the next new tube.
    #17
    katbeanz, Wentwest and JohnE65c like this.
  18. JohnE65c
    JohnE65c Been here awhile
    Mar 14, 2010
    647
    Florida
    +1. Check the spoke nipples for burrs. Check to make sure that no spokes are extending beyond the nipple end. Especially if you happened to tighten any spokes over time.
    #18
    katbeanz likes this.
  19. Sonny S.
    Sonny S. Long timer
    Nov 23, 2015
    3,070
    Maryland
    Yeah I've also seen where someone accidentally nicked the rim with a tire iron when changing a tire. Things happen. Always good to inspect and clean the rim real well before installing a tire or tube
    #19
  20. sieg
    Jul 9, 2008
    8,236
    I left a tire iron in the tire once. Yeah I don't know how that could happen.
    #20
    nickguzzi and Sonny S. like this.
