Repeatedly flat front
Discussion in 'The Garage' started by apostis, Sep 30, 2019.
  1. Bigger Al
    Bigger Al Still a stupid tire guy Supporter
    Oct 12, 2004
    9,778
    Auburn, CA
    Pinches from tire irons are almost always along the circumference, not radially located. I've pinched a looooot of tubes in 30 years of tire work. :bluduh
    #21
  2. apostis
    apostis Adventurer
    Jul 10, 2013
    59
    Good to know. Again, the tube in the picture is the original one though so this hasn't been messed with. At least not by anyone else than at a factory.
    #22
  3. yokesman
    yokesman Long timer
    Sep 12, 2008
    2,362
    SW. Idaho
    if add some air to the tube to remove the folds, no pinch flats.
    #23
    Sonny S. likes this.
  4. 9mm
    9mm Been here awhile
    Apr 18, 2006
    594
    "Southeast of Disorder"
    Ain’t motorcycles fun!
    #24
    Bigger Al likes this.
  5. Sonny S.
    Sonny S. Long timer
    Nov 23, 2015
    2,351
    Maryland
    There could still be a small burr on the rim straight from the factory. Just because it's new doesn't mean it's right.
    #25
  6. Boatman
    Boatman Membership has it's privileges ;-) Supporter
    Mar 9, 2005
    14,316
    Mill Spring, NC
    That's funny I found a tire iron in a tire a few years ago,,,,, maybe it was yours!!
    #26
  7. sieg
    sieg Wearing out tires......2 at a time, day after day. Supporter
    Jul 9, 2008
    7,808
    Southern Illinois USA
    Send it back!
    #27
  8. trumpet
    trumpet Group W Bench
    Aug 2, 2008
    3,432
    Connecticut
    So true, had this happen. Found a shard of glass embedded in the tire.
    #28
    Bounder likes this.
  9. bwringer
    bwringer Gimpy, Yet Alacritous
    Jan 22, 2008
    3,096
    Indianapolis
    Yeah, fresh blood makes a decent tire mounting lube, at least until it goes all sticky.
    I've stuck my fingers a few times locating punctures... :becca
    I like the toilet paper idea above -- wipe around and see what sticks. Safe, and you could do the same with cloth, fleece, or microfiber.
    #29
    victor441 likes this.
  10. bisbonian
    bisbonian Long timer
    Nov 8, 2007
    1,429
    Tucson, AZ
    The 2 flats don't have to be related. I had a tube which was folded over on itself when installed, it lasted a good long time until all of a sudden it lost all air.
    Let's face it, the only common element between the 2 flats is the wheel itself, so unless you've but a burr or something going on with the wheel then it's coincidence.
    #30
    Beezer and sieg like this.
  11. apostis
    apostis Adventurer
    Jul 10, 2013
    59
    Yeah makes sense.
    I had some time today and inflated the tire again. And it seems to hold the air so far! Very odd.
    I haven't mounted the tire again yet so I haven't used it yet. I put my whole 80kg/180?lbs on it to see if it affects the pressure. It did seem to lose about 0.5psi from that initially. But after repeatedly putting my weight on it it didn't seem to change any further.
    Not sure this is helpful for my issue now.
    I'd really like to not bother opening the tire again but I'm assuming it will lose pressure again eventually.
    There must be some kind of damage of it leaked air once, right?
    Or could this possibly be from the valve being unhappy for being in a position that's 1mm off or something and that got fixed now?
    Then again the tire did stay inflated before as well, but then leaked after a few weeks. Or it leaked right away after installing it already and I never noticed. But I was riding every day so that seems odd but who knows.
    #31
  12. Sonny S.
    Sonny S. Long timer
    Nov 23, 2015
    2,351
    Maryland
    Schrader valve tight? Leaking?
    #32
  13. apostis
    apostis Adventurer
    Jul 10, 2013
    59
    I actually hadn't touched the valve at all. What I meant was if by the tire being flat the tube and therefore the valve may have shifted within the tire and now is not leaking air anymore. Not sure, that might not make much sense.
    I haven't removed the valve stem at any time, neither when first fitting that tube and tire nor now when re inflating it.
    Do you think that's an issue? Should I remove the valve stem and put it back in again? Would there be any purpose to that?
    #33
  14. Sonny S.
    Sonny S. Long timer
    Nov 23, 2015
    2,351
    Maryland
    Take the cap off and wipe spit on it and see if it bubbles. That's my method anyway. You can spray glass cleaner or something on it. Ya never know.. Can't hurt.
    #34
    Bigger Al, Yinzer Moto and trumpet like this.
  15. sieg
    Jul 9, 2008
    7,808
    Well?
    #35
  16. Coma
    Coma Long timer Supporter
    Jul 11, 2012
    2,263
    The Emerald Coast
    First thing I do with a new tube is tighten the core in the valve.
    #36
