Replacing Heated Grip rubbers...
Discussion in 'GS Boxers' started by MikeO, Aug 7, 2005.
  1. sykospain
    sykospain Been here awhile Supporter
    Jul 18, 2014
    153
    south-eastern Med coast of Spain
    I swear by the US-made Grip Puppies. They last and don't get marmelised by intense sunshine - like wot we 'ave 'ere....
    They're great for anybody who has piano-player's long fingers that find standard grips too thin.
  2. ontrip
    ontrip Been here awhile
    Aug 14, 2011
    835
    Toronto, Ontario
    Finally worked up the nerve to change mine on my F800r.
    Removed them using pliers and a sharp blade.
    Used hair spray to slip the new grips on. Shame to have to throw out the left grips from the 2 sets of grips..
    Left side was easy without any drama.
    The throttle side was more challenging as they must have used more adhesive as it is the throttle side.
  3. BandwagonJumper
    BandwagonJumper Adventurer
    Oct 15, 2012
    94
    Northam: West Aussie
    Guys..............I did this last week on a R1200RT-P.................ive screwed the pooch.
    I had the correct grips 2X Throttle grips
    I damaged both the grips as the R1200RT essentially looks completely different to the R1100 and R1150 elements Ive seen when exposed.
    There is a Plastic ring on the outside and its larger diameter hampers the fitment of the new Grips. I broke it away to enable the new grips to go on.............Ive now lost Heated Handgrips on Both sides.
    Im not a total clown( I did make a "sweet" spice rack once) but I just wanna warn people that its more complicated with a Hexhead.
  4. sykospain
    Jul 18, 2014
    153
    In your 2nd foto, Ontrip, showing the remnants of rubber bonded to the heating element at the bar-end, wouldn't the "heat to 250 degrees" tip in the workshop manual be the best way to remove all that remaining rubbish ? If the Spandau factory uses that particular Loctite as a rubber grips glue, it will melt at that temperature. Watching the assembly guys on a factory tour in Berlin a few years ago was clear proof of how much those guys love Loctite. They seem to dip most everything in a giant tub at the side of the conveyor as they assemble the bikes.
    ontrip and fcocca like this.
  5. ontrip
    Aug 14, 2011
    835
    Toronto, Ontario
    Skyospain, I should have done that but unfortunately if you look closely at the photo, I actually damaged the element and had to bring out the soldering gun to splice a piece in. Ended up using sandpaper to remove the rubber. Junk.
  6. Rogue_Ryder
    Rogue_Ryder
    Dec 8, 2005
    8,320
    Pinewood Springs, Colorado
    Just put the Ariete grips on my R1200GS. They are $35 on eBay and installation was a snap. I don't know why BMW went backwards on their grip design. The R1150 style is better ergonomically and looks better too.
    nervous likes this.
  7. ontrip
    Aug 14, 2011
    835
    Toronto, Ontario
    After changing my grips and repairing the element on the throttle side, it has stopped working suddenly. Any ideas on using a different type of solder or something else to splice the element?
    Replacement grip is $200 plus I would have to rip the factory grip off and replace it with the aftermarket progip to match the left.
  8. GS Addict
    GS Addict Pepperfool Supporter
    Sep 24, 2006
    7,346
    Sunshine Coast B.C.
    Conventional lead/tin solder won't work as the element is made of Nichrome wire.
    Silver solder or brazing is required. It takes a jewellers torch and a skilled hand to repair.
    Much care is needed to shield the surrounding area from heat damage.
    Sometimes (if space allows) a crimp ferrule can be used but there needs to be slack to overlap the broken ends. You can also use 2 ferrules and patch in a short length of tinned copper wire.
    sweatmark and ontrip like this.
  9. H96669
    H96669 A proud pragmatist.
    Nov 20, 2009
    5,883
    Hiding off Hwy 6, B.C.
    I remember fixing such grips a long time ago.Unwound the wire and rewound with one less turn.Twisted the ends together,snipped the excess...taped over and reinstalled the rubber grip.
    ontrip likes this.
  10. Learres
    Learres Adventurer
    Oct 11, 2017
    28
    24610 Gönnebek, Germany
    Duitser likes this.
  11. 396427454
    396427454 Been here awhile
    Sep 5, 2008
    175
    The BMW 32721458396 grip is now 28 clams - still better than 200 but.......
  12. Firebladeboy
    Firebladeboy n00b
    Nov 11, 2014
    1
    Many Thanks for this! Used the same technique on my Multistrada 1200 and it worked like a charm!
