Replacing the rear 'wheel flange' on the R1200GS
Discussion in 'GS Boxers' started by inyang, Sep 2, 2009.
  1. inyang
    inyang 5secs away
    Jun 14, 2004
    461
    Lagos/Port Harcourt, Nigeria
    Was washing my bike when I noticed a crack on one of the ribs that the rear brake disc is bolted to. Hmmm, what could have caused that?
    6 months later and cracks on two more of the stuff, I never got round to ordering a replacement. Time to change rear brake pads in July and its more ugly than I thought, ok, I'll park up the bike while waiting for a replacement but I had to do one last 400km (to/fro) business trip next day and it was a GS type trip.
    120km into the trip, I slowed down for a police checkpoint and wham I hit a log on the road I did not see so pulled over. It was not really a log but the rear disc coming out from from its mounting. Not good
    Pulled over.
  2. inyang
    inyang 5secs away
    Jun 14, 2004
    461
    Cobbled up this and proceeded on trip.
    ABS thrown off and braking iffy to say the least.
    Still did 1500km more though.
  3. inyang
    inyang 5secs away
    Jun 14, 2004
    461
    Parts arrived late August
    So time to 'fix it'
    How do I get off the wheel flange?
    BMW Maintenance CD, no info (well I did not look at odd places)
    Online, advrider? More discussions on FD failures until I came across Mac's post.
    http://advrider.com/forums/showthread.php?t=273522&highlight=1200+final+drive+repair
    The correct topic I should have checked on the CD was 'Replace Wheel Set'. Very intuitive
    Thanks Mac.
    So, got a welder to do his thing with a 'blow torch' and pulled off the old unit
    Heated up and pushed in the new unit.
    Wheel refused to sit properly, hmmm, put wheel on and used bolts to pulled it into position.
    Doing a 600km test tomorrow to see how well it will hold up.
    Changed out my FD oil, leaking seal and seal cover at same time.
    No FD was harmed during the filming of this documentary.
    The GS has 100,000km + on the clock now and served its owner well through mud, water and other terrain.
  4. LTCOliverNorth
    LTCOliverNorth Peeping Tom
    Jul 2, 2009
    833
    Seattle, WA
    Crazy that the brake rotor mounting points broke off like that!
  5. JetSpeed
    JetSpeed Naviator
    Nov 28, 2007
    7,656
    Coronado, CA - KNZY
    Oh hell that's not even worth getting the toolbox out over you damn sissy.
  6. on2wheels52
    on2wheels52 Long timer
    Jun 14, 2006
    4,100
    northern Arkansas
    krikey, I haven't had my '05 long enough to have the rear wheel off yet. What induced a failure of that nature?
    Jim
  7. Disco Dean
    Disco Dean Long timer
    Jul 17, 2007
    1,449
    The Great White North
    Depending on the year - it was a known problem with a very few bikes. There are posts here that I cannot find.
    But they are worth a check to see - I think it was even fixed under warranty.
    But known...
  8. Redron
    Redron Adventurer
    Mar 13, 2006
    30
    Perth Australia
    Hi
    I have just replace flange for the sme reason. I had the wheel off for a clean up and at same time replacing rear brake disc. I noticed crackes on the lugs supporting the disc. I heated up the flange with a heat gun put a plug in the center of the axle and used a puller to pull of the flange.
    Ensure splines on shaft clean and in good condition. Keep shaft at ambient temeperature (less than 30 degrees C).
    Heat flange ( kitchen oven 100 deg C) . I had turned down a plug to fit in outside end of axle, Fit new flange, then old one against it followed by a threaded plate. Threaded bar goes through plug , flange and threaded plate. Nut on the threaded bar. Tighten up nut ,pulls the new flange on without having to hammer the flange on.
    #8
  9. inyang
    inyang 5secs away
    Jun 14, 2004
    461
    Don't know, but suspect riding through water when the rear rotor is hot may set up cracks in the metal. This cracks then propagate further when same heat quench cycle is repeated.
    Or could be caused by big hits on the rear wheel over ruts and bumps?
    GS doing ok so far, did the 600km trip post install no problems, doing another 600km this coming weekend. Notice the clunky sound from the rear more now but may be my imagination. On takeoff and throttling down.
    #9
  10. Slaniac
    Slaniac Martini elbow
    Feb 16, 2003
    11,142
    Auburn, CA.
    What was the price of the new part? Mine has one crack in it, and I'm sure will need replacement before I do any long distance. Seems to me this a part that should not develope this sort of problem. I'[ve pranged the front wheel, but not the rear. Thanks,
    #10
  11. michnus
    michnus Lucky bastard Supporter
    Apr 14, 2005
    2,470
    South Africa
    #11
  12. Slaniac
    Feb 16, 2003
    11,142
    Auburn, CA.
    Thanks for the info. I have this issue as well. The common thought running through the posts is that BMW has not even listed this as a potential problem so mechs. and riders can be aware of it. I saw it because I was doing a FD fluid change and had the unit in hand so to speak. It worries me that the company has such low regard for its supporters. Lack of support for the motorcycle issues like fuel lines, cable fraying, warped rotors, FD failures, the infamous surging, etc. (and yes, some of these have been addressed, but only after much bitching) have caused me to look elswhere for my next motorcycle purchase. I doubt that when my ship comes in (2 years, 9 months) that I'll look into a BMW auto either.
    I'll admit that I've written this in the hopes that some big deal at the company reviews this site from time to time to see whats up. If they do, you'd never know it. I'll write my concers directly to the company after which I'm sure they'll send me a new flange...FOR FREE!
    I know that things break. I personally fucked up my front rotors, but hell, for only 500 USD I was able to get new ones. It's the safety issue involved here that worries me about the companies lack of 'give a shitness'.
    #12
  13. Slaniac
    Feb 16, 2003
    11,142
    Auburn, CA.
    If the cooling effect of water causes the problem then BMW has used the wrong material in the manuf. of this flange, and should make it right...I'll just hold my breath on that deal.
    #13
  14. Slaniac
    Feb 16, 2003
    11,142
    Auburn, CA.
    I phoned my local dealer, A&S BMW in Sacramento/Roseville. After a few hand off's I was advised that they would look at the flange and then contact BMW to see what if anything can be done to make it right short of my buying a new flange for 250 USD. I think I'll photograph the part in situ and take the copies to them...maybe avoid a service charge that way. Or, do youall feel they'll need the bike there?
    #14
  15. huggybear
    huggybear Been here awhile
    Oct 8, 2005
    384
    Mississippi
    On My 05 GS the final drive was replaced at just under 14K,in the bulletin the dealor had it said that two final drive failures were possible one was bearings and the other was worn splines on the part that you bolt the wheel too,mine was worn splines that caused side to side play, It should be plain as day that if the tire,wheel and brake rotor are wiggleing back and forth it would put a serious strain on the mounting holes for the rotor
    Check your flange for movement and have the dealor check the possible FD problems in their bulletin
    I think I have seen that bulletin posted on this site
    Good Luck
    #15
  16. michnus
    Apr 14, 2005
    2,470
    South Africa
    That was also another problem with the 04 and 05 flanges, people thought it was the FD going tits up but it was the flange splines that was wearing out to fast, this flange crack is just another part of the same part number problem.
    BMW in SA told me to sod off, won't replace.
    #16
  17. inyang
    inyang 5secs away
    Jun 14, 2004
    461
    I think 257.50 US Dollars.
    May have to heat the flange again to push in further, my rear wheel does not go in smoothly. Did a tyre change and it was difficult to fit back the wheel.
    #17
  18. TagBagger
    TagBagger Been here awhile
    Jun 17, 2008
    168
    Halifax, Nova Scotia
    They seem to have changed their tune with today's recall (erm "Technical Campaign") to replace the rear wheel flange on all R's and K's 2003-2011
    #18
  19. HighWay319
    HighWay319 Adventurer
    Aug 8, 2010
    50
    Charlotte, NC
    This is about one year too late for my 2005. Got lucky on the fuel pump flange recall, mine started leaking 2 days after the recall started.
    #19
  20. JimVonBaden
    Feb 11, 2005
    96,037
    Alexandria, VA
    You may be eligible for a refund if you can prove you paid for the repair.
    #20
