Replacing valve stem seals: Anyone ever do it?
Discussion in 'Dakar champion (950/990)' started by wiseblood, Jan 30, 2015.
  1. wiseblood
    wiseblood Denies further magnets Supporter
    Dec 29, 2008
    26,226
    New York City
    This is for my 2007 KTM 950 (SMR). My bike has always consumed oil, and it has been slowly increasing over time. In the past year, I've had spark plugs fail twice due to oil fouling.
    In past service, I've been able to see a small bit of oil on the top of the valve (looking down the intake). I got what I believe is a confirmation of my leaky stem seals a couple months ago: Doing a bit of mixed-surface riding, a friend riding behind me noticed a big puff of blue smoke when I twisted the throttle after a long slow downhill section during which I was entirely engine braking.
    My understanding is, engine braking will suck oil through the leaky valve stem seals. When I get back on the throttle, the accumulated oil burns, causing blue smoke for a moment, which is exactly what I got.
    FYI, I already replaced the balancer shaft seal last year.
    So, my questions:
    1. Can anyone think of any other reason, besides a leaky valve stem seal, that i would have these symptoms?
    2. Has anyone ever replaced their valve stem seals?
    3. Is there any realistic and safe way to replace these seals without removing the heads, and all the work related to that? :bluduh
    FYI, I'm just about to do my 20k miles valve check service. That's why I'm asking this now.
    Thanks! :beer
    Edit to say: This work has been completed, and the bike has been running GREAT! :ricky
    Index of thread:
  2. TheMuffinMan
    TheMuffinMan Forest Ranger Magnet
    Mar 31, 2010
    9,386
    Coeur d'Alene, ID
    You'll have to remove the heads and the valves to replace the seals if my memory serves correctly.
  3. Tobes2102
    Tobes2102 Been here awhile
    Feb 5, 2014
    168
    Knoxvegas
    I've done valve seals on a lot of engines but not the LC8. There is really no way to replace the seals without removing the heads. It's not hard though just take your time, snug the seals well and affix the springs correctly. Pay attention to your valve seats while you have the heads off. You can do a vacuum test OR...old school turn the heads upside down and pour some gas behind the valves to ensure your have proper seating. If gas leaks through you need to re-seat and lap (some modern engines don't allow for lapping), or grind the valves (take it to a respected machine shop). With your symptoms you need to pay attention to the seats since there may be some carbon build up around there.
  4. Sumi
    Sumi Long timer
    Mar 30, 2010
    2,239
    Hungary
    I had them replaced on the rear head by my dealer (who is a friend of me, so I was there during the operation, "helping"), and the head has to be removed - you can't remove the valves otherwise ofcourse, but IMO it's not a big deal to remove it.
  5. wiseblood
    Dec 29, 2008
    26,226
    New York City
    Yeah, that's the vibe I've been getting. Which makes me think: If I'm gonna do all that, seems like I might as well do a full top-end rebuild. (Which I've never personally done. :uhoh)
  6. TheMuffinMan
    Mar 31, 2010
    9,386
    Coeur d'Alene, ID
    How many miles are on your bike?
  7. wiseblood
    Dec 29, 2008
    26,226
    New York City
    Just about 21,000.
  8. TheMuffinMan
    Mar 31, 2010
    9,386
    Coeur d'Alene, ID
    Oh that's way too early for a top end in my opinion. I'd just do the valve seals and call it good unless you see something massively wrong with the piston or cylinder when you get the head(s) off.
    #8
  9. Sumi
    Sumi Long timer
    Mar 30, 2010
    2,239
    Hungary
    +1
    #9
  10. wiseblood
    Dec 29, 2008
    26,226
    New York City
    Stupid question: I've been looking at the service manual as well as Pyndon's rebuild page in the HOW, and it is never explained how I might remove ONLY the valve head, and not the cylinder. :dunno
    Is it possible? If not, sounds like I will have to remove the whole cylinder head in order to do this job!
    #10
  11. Oldebonz
    Oldebonz Been here awhile
    Nov 24, 2012
    304
    Ohio
    On some engines(not sure on 950-990) I have seen rope stuffed through spark plug hole(leaving enough rope sticking out to remove) into the combustion chamber just before TDC on compression stroke,bring up to TDC and lock in place,lever spring retainer down,rope will hold the valves in place,remove collets ,valve retainer top and valve spring exposing the seal,pry off and replace seal, reverse order to complete.not sure if there is adequate access space,cams removed as if doing valve shims,might be possible....smoking on over run due to valve seals,valve guides,dirt on valve seat would not cause oiling,just loss of compression on leak down test.Oiling all the time due to bad rings,worn bores,etc. 20,000 miles sounds awfully short in a modern engine with high tech valve,guide and seal materials,rings could wear from bad air cleaner in a very dusty environment but valve seals would be unaffected by this,only exposed part of valve stem when valve is open.Just stuff to think about!
    #11
  12. wiseblood
    Dec 29, 2008
    26,226
    New York City
    I've seen that process done (with the rope) on Youtube... crazy! :eek1
    98% of my riding on this bike is paved street-only, so it's not dirt. (Plus, I checked the air filter, and it's good.) Smoking doesn't happen on overrun. It happens on throttle AFTER a period of overrun. As I understand it, the vacuum pulls oil past the valve stem oil seals, if they are not great.
    #12
  13. Peanuts
    Peanuts Long timer
    Sep 12, 2009
    2,005
    Beautiful but often rainy North Yorkshire, UK
    Are you sure it's not oil from the engine breather?
    #13
  14. DirtyADV
    DirtyADV Long timer
    Jan 13, 2007
    4,352
    SWEDEN, Norsjö
    #14
  15. wiseblood
    Dec 29, 2008
    26,226
    New York City
    Yes. Pretty sure. I replaced the balancer shaft seal just a few months ago, specifically to exclude that as a possibility.
    I'll add: Prior to replacing that seal I did see a little oil in the brather, and on the carb intake stack. I've seen none since replacing that seal.
    #15
  16. bemiiten
    bemiiten League of Adventures
    Jul 10, 2003
    5,670
    Hamilton NJ.
    I recall one method was to hook up pressurized air through the spark plug hole to hold the valves in place, not that this is practical with the KTM.
    #16
  17. wiseblood
    Dec 29, 2008
    26,226
    New York City
    Yeah -- that's a variation on the "rope" solution. Seems like a half-ass way of doing it.
    At the moment, I'm wondering if there is a way to take off the head WITHOUT removing the cylinder. At very least, that would save me $50 in gaskets, not to mention, all the added work.
    If I'm gonna HAVE to remove the cylinder, too, then I'm really wondering if I shouldn't just to the whole damn top-end: Pistons/rings, hone the cylinder if needed, etc.
    Also... starts to feel like dropping the engine out of the frame to do the work would be the smarter thing to do.
    #17
  18. wiseblood
    Dec 29, 2008
    26,226
    New York City
    For the curious:
    <iframe width="560" height="315" src="https://www.youtube.com/embed/zFmC66YU6zI" frameborder="0" allowfullscreen></iframe>
    :lol3
    #18
  19. fast4d
    fast4d Long timer
    Jul 27, 2007
    3,103
    Los Angeles, CA
    it does not hurt to try.
    put piston @ TDC, compressed air through spark plug hole.
    this is done all the time in the automotive world.
    #19
  20. Sumi
    Sumi Long timer
    Mar 30, 2010
    2,239
    Hungary
    There is not a way to separate the head from the cylinder without removing the cylinder as well from the engine IMO. The added work is not that much if you leave the piston in the cylinder.
    #20
