1. Livestream Tonight at 9pm EST / 6M PST! Any Questions for Marc?
    Baldy + Alta CEO & Co-Founder Marc Fenigstein YouTube Live Chat here
    Dismiss Notice
Replacing valve stem seals: Anyone ever do it?
Discussion in 'Dakar champion (950/990)' started by wiseblood, Jan 30, 2015.
  1. TheMuffinMan
    TheMuffinMan Forest Ranger Magnet
    Mar 31, 2010
    9,342
    Coeur d'Alene, ID
    Heck yeah, that's definitely valve stem steals. I'm looking forward to more!
    :lurk
    Oh and I get the unheated garage. Mine is unheated and I've been slacking on getting my 525 back together (so I can then start work in the 950 :lol3).
    #41
  2. wiseblood
    wiseblood Denies further magnets Supporter
    Dec 29, 2008
    26,226
    New York City
    Hey Doc! :fyyff
    1. Yes, it's probably me. First, as you know, I'm not exactly what the motorcycle manufacturers had in mind when they designed their vehicles. I'm trying to get a gig battle-testing motorcycles. If anyone at KTM wants to true endurance test (Dakar? Pfffffft. Too easy!) give me a bike for a couple years. I'll ride it with my sasquash-self every day, commuting in the shittiest roads in the Northeast, in the coldest/hottest/wettest weather. I'll even get it knocked over a few times by cars. Want an ABS test, too? I can do that. :nod :thumb
    2. Lemon law applies only to dealers, not to private sales. Also, this bike kicks ass! :ricky
    As far as hiring a "professional" -- aside from saving money, I like to build up my wrenching skills. I was raised by folks who were not very mechanical (though, my mother as an artist/sculptor does have an impressive wood workshop!). I discovered late in life that wrenching on bikes is a very satisfying thing! Especially when I manage to fix it, and not break it more. :augie
    #42
  3. mechcanico
    mechcanico Adventurer
    Feb 28, 2015
    51
    UK
    Hello , that plug is heavily oil fouled , i am not convinced that that is all from valve stem seals , there is no white oil ash build up on the plug that you get with excessive oil burning .
    The other plug doesnt look so bad yet the valves and seals have only done the same work and are the same age .
    Have you done a compression test ?
    Does the crankcase breather system 'favour' a particular cylinder ?
    Does there seem excessive crankcase pressure ?
    Is the breather system working properly , is there seperator gauze in the pipe work to take the oil mist out of suspense before it gets to the air box .
    Is the air box standard or has it had any modifications , was there oil in the air box
    I have done valve seals on car engines where the seals have not been wiping the valve what so ever and the plugs have not been that badly oil fouled .
    Does it smoke under load aswell as on the over run , is the bike using alot of oil
    #43
  4. Rharr
    Rharr Been here awhile
    Apr 5, 2014
    924
    Tucson Az
    Smoke on over run aka engine breaking from higher revs will be the tell tale sign of a bad valve seal. Do the guys you ride with joke and call you for mosquito abatement?
    Engine breaking at high rpm with throttle shut will create a lot of vacuum and will pull oil past the seals if they are bad.
    #44
  5. wiseblood
    Dec 29, 2008
    26,226
    New York City
    I'm still chugging away at this. Work & family pulls me away for a bit, but I'll get there..... eventually! :hide
    So, since last I posted, I finally got the damn exhaust off. The clamp bolt which connects the small rear header pipe to the rest of the exhaust was a solid block of rust. I finally got the pipes off by removing the oil tank and swinging the pipes around to the left side and dropping it through the swingarm.
    Anyway, here's what I did so far:
    Leak down test. Rear cylinder (the one which is fouling the plugs!) actually had good seal. Only 4-5% leaking, and that was past the rings. (Coming out of the crank case breather, to be specific. :deal)
    The FRONT cylinder, OTOH, was a bit more problematic. On that one, I am getting 9-10% loss, and it's coming from the intake valves. :bluduh I created a separate thread for that. Question I had was, "should I renew the head & valves?" General consensus seems to be "ride it like you stole it. It's probably nothing." Here's to hope! :freaky
    Valve clearance check. Seven of the eight were spot-on. The right side, rear, exhaust was a little tight, by about 0.05mm. (Was between 0.2 and 0.25 -- should be between 0.25 and 0.3.)
    Before I left the garage last night I took a look into the exhaust to check out the valves. I saw a LOT of carbon. Is this normal? Plus, the front cylinder valves had what appeared to be some white calcified crap on the stems. Anyone have a clue what this might be? The exhaust valves don't seem to be leaking. Any suggestions?
    Pictures of front exhaust & valves:
    Pictures of rear exhaust & valves:
    #45
  6. Bowber
    Bowber Been here awhile
    Feb 27, 2012
    559
    Cumbria, UK
    Not much help with the look of the valve stems but I've changed valve stem seals on a DR350 in situ, bit harder on the KTM though as the valves are down in the bucket holes but it's doable.
    I'd be looking at the rings as well, get your bore scope in the bore and check for marks left by a broken ring.
    Steve
    #46
  7. wiseblood
    Dec 29, 2008
    26,226
    New York City
    That's gonna be my next step. I'm a little bit nervous, because (apparently) I'm a ham-handed gimp of a mechanic. But.... :lol3. What's the worst that can happen? :hide
    Good idea. I'll run it down the spark plug hole next time I'm at the garage.
    BTW... Piloting a borescope is friggin hard! :jerko
    #47
  8. wiseblood
    Dec 29, 2008
    26,226
    New York City
    Did I mention that I work slow? :fpalm
    So, I finally dropped the motor last night:
    I confirmed the valve clearances. Tonight I'm planning on going back to the garage and finally pulling the cams and replacing those stem seals. :clap
    By the way: I had a plan for a bit in which I would remove all the bolts except the swing arm, which I would just loosen, and then rotate the engine down in front. The benefit of that would be getting access to the rear cylinder without having to completely remove the engine. That won't work. :nono
    The engine, it turns out, rests on the frame, preventing it from rotating down in front. You can see that a bit in the first picture above, and also in this picture:
    The cross piece below the swingarm bolt prevents the engine from pivoting. So, anyone who wants to replace the seals should assume they have to remove the motor (unless you have a smaller tool for pulling the valve keepers/springs).
    #48
  9. DirtyADV
    DirtyADV Long timer
    Jan 13, 2007
    4,324
    SWEDEN, Norsjö
    Remove the swingarm axle and it can be rotated down on the lower engine mount enough to lift rear cylinder.
    /Johan
    #49
  10. wiseblood
    Dec 29, 2008
    26,226
    New York City
    Top End Selfie...
    :lol3
    #50
  11. TheMuffinMan
    Mar 31, 2010
    9,342
    Coeur d'Alene, ID
    Nice! :clap
    #51
  12. wiseblood
    Dec 29, 2008
    26,226
    New York City
    In my situation, the only reason I was trying not to remove the engine was to avoid removing the swingarm. But, it turned out to not be that big a deal. (Bike didn't fall over or apart.)
    Certainly a heck of a lot easier to work on now! :freaky
    #52
  13. wiseblood
    Dec 29, 2008
    26,226
    New York City
    I found this interesting... probably old hat to most of you, though.
    Cam bridge underside:
    Very interesting how the oil travels to the cam lobes. You can see where the passages are next to the big bolt holes on the head:
    I guess the oil returns by spilling down the vertical space where the cam chain lives.
    Anyhoo, I'm up to the hard bit. Was too late to get to it last night (11:30 pm on a work night), but I'll be getting to the seals in the next couple days.
    #53
  14. wiseblood
    Dec 29, 2008
    26,226
    New York City
    Hey All --
    So, worked last night to remove the valve keepers and springs. I has planned to get through them all in one night, but the process of removing the keepers, and even more so INSTALLING them has been difficult.
    Here's a video of the attempts and process.
    First shot:
    :lol3
    Now, actually getting one out:
    So, here was the removal process:
    1. Remove cams & buckets/shims.
    2. Using a threaded air hose, pump 50-70 psi into the cylinder.
    3. Using valve keeper remover/installer tool, carefully (but firmly!) tap to remove keepers.
    4. Remove retainer and springs
    5. Extract old seal
    6. Install new one (coat w/ oil to avoid damaging seal)
    Installation was SUPPOSED to be:
    1. Pump 50-70 psi into cylinder.
    2. Install springs.
    3. Put keepers into retainer, and place retainer/keepers in place on top of springs.
    4. Using valve keeper remover/installer tool, push firmly down until keepers lock into place.
    5. Drink beer.
    This did not happen. :bluduh
    I have not yet been able to get the keepers back in place for the one valve I removed. One lesson learned, however: You can remove air pressure from cylinder without any risk of losing a valve (assuming you're at TDC). First, valve only will move maybe half an inch down before resting on the piston. Second, there is enough drag from the seals and guides that the valve will stay put unless you physically move it.
    In fact, I'd say, this is an excellent time to see if you have any free play in your valve guides! My right, rear exhaust valve guide appears good: Zero play at all.
    #54
  15. wiseblood
    Dec 29, 2008
    26,226
    New York City
    Here's what you see when you do finally get the keepers off:
    Magnet inside tool catches keepers, which is what you see inside the tool.
    Down the rabbit hole:
    You can see the valve oil seals at the bottom of the stem. You need some long grabby tool to get it out:
    Seal removed:
    You can see some wear at the top. I never know how to evaluate these things, but you're looking at the seal which caused the most leakage:
    #55
  16. unaweep
    unaweep Uses lotsa band-aids
    Jan 2, 2006
    42,292
    Western Colorado
    Is the valve keeper remover tool necessary for this motor? Or, can any valve spring compressor tool be used?
    #56
  17. Rharr
    Apr 5, 2014
    924
    Tucson Az
    would it be easier to jerry rig up a spring compressor stand like this out of 2x's and bolt it to a table?
    https://youtu.be/up00AC7QcZs?t=59
    FYI, triple check the valve guide after you get the seal off to make sure there is no rubber remnants from the old seal stuck on the guide anywhere.
    #57
  18. wiseblood
    Dec 29, 2008
    26,226
    New York City
    Valve spring compressors usually need you to remove the heads. But, no, a regular compressor will work.
    #58
  19. wiseblood
    Dec 29, 2008
    26,226
    New York City
    Good tip about checking for old rubber!
    That bench compressor is pretty awesome!
    #59
  20. unaweep
    Jan 2, 2006
    42,292
    Western Colorado
    Thanks. I really don't want to remove the heads if I don't have to. $50 for the tool is cheap if it means I don't have to do that. :thumb
    #60
