1. eNewsletter Sign Up
Replacing valve stem seals: Anyone ever do it?
Discussion in 'Dakar champion (950/990)' started by wiseblood, Jan 30, 2015.
  1. keener
    keener Speed changes you.
    Feb 24, 2010
    2,251
    Toronto, Canada
    Great info, thx for documenting it.
  2. wiseblood
    wiseblood Touching my face Supporter
    Dec 29, 2008
    26,005
    New York City
    Small steps forward....
    Final valve adjustment, done:
    Engine all buttoned up! Surprisingly satisfying!
    Last item for tonight: Roll the bike/frame back up front in the garage, in preparation to re-install the motor. :clap
    FYI on Valve Shims: As has been noted in OC many times over the years, some Hardley Davidson (:D) bikes use the same size valve shims (10mm) as the KTM LC8. (V-Rod, I think.) Two advantages of getting shims from your local H-D dealer:
    1. They have "intermediate" sizes. KTM only sells shims spaced every 0.05mm. H-D sells sizes every 0.025 mm, and they have a greater range of sizes available.
    2. To my SHOCK, my local H-D dealer actually has all these shims in stock! Local KTM dealer? :photog "That'll take two weeks."
    On the HOW, there is this very excellent Excel valve shim calculator, WITH H-D part numbers:
    :bow
    DirtyADV likes this.
  3. Rharr
    Rharr Been here awhile
    Apr 5, 2014
    913
    Tucson Az
    I just buy a shim kit from hotcam for 80 bucks and throw it in my tool box. then i don't have to run across the city for shims.
  4. wiseblood
    Dec 29, 2008
    26,005
    New York City
    A friend let me raid his hotcam shim kit, but he was out of one particular size I needed, and he didn't have any intermediate sizes (only sized every 0.05 mm).
    I think I spent $7 on shims. :D
    Jesse
  5. DirtyADV
    DirtyADV Long timer
    Jan 13, 2007
    4,250
    SWEDEN, Norsjö
    Used to order Harley shims before but they cost 3 times what OEM KTM cost, and they are not even chromed =(
    But when they change minimum order to 5 of each I took the hit of buying 2 shim kits, Pro-X I think was the brand, both half sizes and quarter sizes so should be covered. Should I run out of any size Ill order more that day.
    Lets just hope it fires right up after all that work =)
    /Johan
  6. wiseblood
    Dec 29, 2008
    26,005
    New York City
    So close...
    Just finished installing new swingarm bearings, and now installing new chain and sprockets.
    I estimate no more than another four hours of work to get it running. Just cleaning up a bunch of little bits as I go.
    unaweep likes this.
  7. unaweep
    unaweep Uses lotsa band-aids
    Jan 2, 2006
    41,694
    Western Colorado
    This is like waiting for a jury to return its verdict. :lol3
    Good luck, brother. :thumb
  8. wiseblood
    Dec 29, 2008
    26,005
    New York City
    An update shortly, but for now:
    :D
  9. Rharr
    Apr 5, 2014
    913
    Tucson Az
    now ride it like you stole it.
  10. wiseblood
    Dec 29, 2008
    26,005
    New York City
    :evil
    That'll be tomorrow.
  11. Dusty
    Dusty Long timer
    Jun 15, 2007
    1,554
    Bismarck
    Excellent!...:thumb
    Thanks for taking the time to post all this.
  12. wiseblood
    Dec 29, 2008
    26,005
    New York City
    An update --
    I've started the break-in process, more or less using the "Motoman" technique, described on the HOW:
    In short, I'm managing engine heat and running the motor hard with loads both on the gas and using (heavy) engine braking.
    After the first 45 or so miles, I did the first oil change. (I'm using NON-synthetic 10w40.) Here is what the oil screens looked like:
    The morning after my first break-in ride (first <20 miles) there was a big belch of smoke out the tail when I started the bike. This, I assume, was oil which had been sucked up past the rings into the combustion chamber. I got a similar belch later that day (I rode the bike to work and back.)
    Yesterday I did the first really "hard" ride -- a 120 mile twisty route with some highway miles. BTW, it's totally possible to vary the rpms on the highway! You can't do this in traffic, but when the road is clear it's pretty simple to run in low gear (2nd or 3rd) and roll UP, and then Roll down -- like the earth is just a giant dyno for your benefit. :lol3
    Anyway, this morning when I started up there was no smoke anymore. :D
    Not to say it won't come back -- it's only up to 167 miles, but that's where I'm at. Next oil change will be about 500 miles. I'll run NON-synthetic until about 1000 miles.
    BTW... It's impossible to not look like a clown/jackass/hooligan/n00b when you're trying to roll up and down the RPM range all the time. :lol3 :deal Also, it's fun to hear/feel the rear wheel skipping and chirping behind you. :augie
  13. wiseblood
    Dec 29, 2008
    26,005
    New York City
    BTW #2: I had forgotten how freeeekin' fun this bike is! :ricky
    keener likes this.
  14. keener
    Feb 24, 2010
    2,251
    Toronto, Canada
    What's the reason behind running non-synthetic during the engine break in period?
  15. wiseblood
    Dec 29, 2008
    26,005
    New York City
    Probably nothing but superstition. But "everybody" :rolleyes says that non-synthetic oil facilitates running in the piston rings. But, it can't hurt, I don't think. The oil is JASO MA, and within the oil weight spec. So, maybe it does, maybe it doesn't help.
    There is ONE place it does help, for sure! Co$t! Definitely much cheaper to use non-synth than synth, given that I expect to have at least three or four oil changes before 1,000 miles! :deal
    On the note of break-in, I dug up a couple pictures from the FIRST oil change I did on this bike after I bought it used. This was at about 3750 miles:
    I suspect that this bike, of which I was the THIRD owner at 2,400 miles(!!) was never run-in very hard. The result was that my riding style (and size -- I'm a friggin' giant :lol3) did some late break-in on the bike! It never had any notable amount of metal in the screens or magnets after that first oil change. But, it always consumed oil! :deal
    chainbreaker and keener like this.
  16. unaweep
    Jan 2, 2006
    41,694
    Western Colorado
    :clap
    Congratulations on a job well done! :thumb So glad it all came together for you. You've been working on this for a long time!
  17. wiseblood
    Dec 29, 2008
    26,005
    New York City
    Thanks! :beer
  18. Mercury264
    Mercury264 Once you go Triple...
    Nov 7, 2005
    24,938
    Masshole
    Great thread - always love to read these kinds of threads as it gives me hope that one day, I can do something like this.
  19. docgonzo
    docgonzo Old Gadfly
    Mar 1, 2002
    20,323
    within 20 miles of the Center of the Universe
    :clap:clap:clap
    Amazing job! Have to admit, I never thought you would get the motor back together. How many extra parts did you have left over?:-)
    Seriously, a monumental, incredible job for a computer guy!
    Now that you have a big duelie again, are you going to rescue the Big Apple game?
    wiseblood likes this.
  20. wiseblood
    Dec 29, 2008
    26,005
    New York City
    Reminds me of a sign in Boston during the Big Dig. Edited slightly for this thread:
    "Rome wasn't built in a day. But, if it was, I should have hired their mechanics."
    :lol3
