Rescuing a ttr225
Discussion in 'Some Assembly Required' started by Puregonzo279, Aug 27, 2018.
  1. dbc
    dbc Adventurer
    Aug 12, 2015
    94
    N. Cal
    Nice job !
    Hey, if your thinking about re-covering your seat, give this stuff a shot.
    https://www.yourautotrim.com/al4stvi.html
    I've redone a few seats with their "High tac black," has a real nice grip to it.
    If your patient and have a good stapler, it's not too hard.
    My KDX with the high tac..
    flinders_72 and oic like this.
  2. Puregonzo279
    Puregonzo279 Ms wanderer
    Apr 12, 2015
    282
    Tupelo, MS
    I was looking at seat covers and that is cheaper and better looking than the stuff I was finding on eBay. Thank you very much. I will be ordering some of that. You did an excellent job on your kdx. It looks good.
  3. Puregonzo279
    Apr 12, 2015
    282
    Tupelo, MS
    How many yards did it take to cover your seat ? I would think one would be more than enough to do it .
  4. dbc
    dbc Adventurer
    Aug 12, 2015
    94
    N. Cal
    Way less than 1/2 a yard. Fabric is sold kinda weird. A yard of it is 36" x what ever the bolt width is. A yard of Allsport is 54"x36".
    Just like on your seat, the KDX has a big curve in it that is kinda tough to deal with- it can be dealt with buy tugging & pulling, but I cheated. After cutting off a piece big enough to cover the seat plus a few inches in all directions (little extra helps while tugging,) I sprayed a little contact adhesive on the curve & on the underside of the material where it's going to hit the curve. Not much, about a 2 1/2" square. Makes the job easier.
    What's amazing is how much the stuff stretches, follows tight curves and rolls over tight edges with no sewing required.
    dave0 likes this.
  5. Puregonzo279
    Apr 12, 2015
    282
    Tupelo, MS
    That is pretty amazing. I appreciate the info and the tip on the adhesive. I'm definitely gonna try it .
    LandsVW likes this.
  6. Puregonzo279
    Apr 12, 2015
    282
    Tupelo, MS
    20190122_153017.jpg I almost forgot to get a before of the back wheel before I scrubbed it down for paint. The majority of the rust there was surface rust and after a good bath with some steel wool it cleaned up so nicely I decided not to even paint it. I couldn't get the spokes to shine like this but oh well. It as after all made for dirt. 20190122_203128.jpg a little after the cleanup action. So shiny. I look forward to getting the front wheel cleaned up getting the new tune and tire mounted. Any pointers for doing it myself ? I have a friend with a tire machine and he give a me the buddy hookup. But it is still close to forty dollars. I could wash a couple of bikes for him and he would put it on for nothing. The last time I attempted to put a tube on a rim I pinched it . I guess practice makes perfect. But the tube itself was 20 bucks . 20190122_211221.jpg
    Rear wheel mounted. 20190123_020505.jpg so so close. Just waiting on parts as usual.
    flinders_72 and LandsVW like this.
  7. LandsVW
    LandsVW Been here awhile
    Oct 20, 2012
    770
    Tri City, Oregon
    I love how that thing is looking! Keep up the good work!
  8. Puregonzo279
    Apr 12, 2015
    282
    Tupelo, MS
    Thank you. It is getting there.
    LandsVW likes this.
  9. Puregonzo279
    Apr 12, 2015
    282
    Tupelo, MS
    20190123_020535.jpg I got the rear brake lever put back in place and cleaned up. My wife doesn't like that this is going on in the piano room/living room. She asked me how much it would cost to enclose my work space in the back so that next year we don't have this issue. if I don't get anything else out of this I will at least get an enclosed work area. It will be easier to keep clean that way as well. I won't have leaves and dirt blowing in constantly . 20190123_020527.jpg rear brake assembly put back together and ready to stop this thing. 20190123_021638.jpg I didn't realize how blurry this was until it uploaded. But oh well here it is . I cracked the manifold a bit on accident wedging the carb into place. I hope it doesn't cause any major issues. I doubt it will. These things are pretty tough. I got the choke cable back in place on the carb and then mounted the other end to the handle bars in the appropriate place. 20190123_021644.jpg
  10. LandsVW
    Oct 20, 2012
    770
    Tri City, Oregon
    On the intake manifold - if the crack goes all the way through and it can suck air, and then run lean, you should replace it. I think they are about 15-20$ on eBay. I had to replace my because it was cracked and running lean. But if it’s just a small crack where the carb metal is and/or etc should be ok. Just make sure it’s not all the way through and/or won’t develop into a problem some day on an epic ride. :)
  11. Puregonzo279
    Apr 12, 2015
    282
    Tupelo, MS
    I think you might be right. Replacing it will be the way to go. I am gonna get it running first and that will be one of those things i will order to finish up the project.
    LandsVW likes this.
  12. Puregonzo279
    Apr 12, 2015
    282
    Tupelo, MS
    So I got this oil filter. And a heavy duty tube for the front tire. 20190124_124718.jpg
    I put the filter in and out a little over a quart of oil in. In my service manual it says to use 20w40 , but I didn't have any of that. What I did have was some ecstar 10w40 for a 200cc dr I had a while back. I figured if it will work for Suzuki it should work for the Yamaha they are almost the same displacement. Then I had to endure another slow day at the shop so I figured I would strike out at the first opportunity and head over to my buddies bike shop and hang out do some work and get that front tire mounted. 20190124_151917.jpg 20190124_152108.jpg it looks pretty rough from out here. Let's see what the inside looks like.
  13. Puregonzo279
    Apr 12, 2015
    282
    Tupelo, MS
    20190124_152547.jpg it doesn't look any better that's for sure. Some elbow grease a wire brush and a file should be able to take care of this. 20190124_153142.jpg 20190124_155026.jpg 20190124_155040.jpg it's not perfect but it's smooth. So I don't think I will have any problems in the near future out of an unexpected flat. Let's hope not anyway.
    flinders_72 likes this.
  14. Puregonzo279
    Apr 12, 2015
    282
    Tupelo, MS
    There are a few he is working on. See the dent in the center of the tank on that sporty closest to the camera ? Rumor has it, that guys balls did that as he was sliding over the handlebars after being rear ended. Talk about balls of steel. 20190124_233717.jpg 20190124_233728.jpg
    One step closer.
    LandsVW and oic like this.
  15. Puregonzo279
    Apr 12, 2015
    282
    Tupelo, MS
    Well I ran into a bit of a problem I rebuilt the petcock valve and place it back on the tank while it was full of vinegar (I was getting the varnished gas out with the vinegar) it has a pin hole in it that is just spewing. Is there a fuel resistant patch similar to J B weld that I can use to patch it ? Or should I just buy a new valve ?
  16. Puregonzo279
    Apr 12, 2015
    282
    Tupelo, MS
    I got the chain slider in the mail. You can tell it was injection molded because of the bubbles. 20190126_145114_001.jpg 20190127_020953.jpg 20190127_020959.jpg
  17. Puregonzo279
    Apr 12, 2015
    282
    Tupelo, MS
    20190127_191847.jpg well. I planned on knocking all the rust off these things. And I got a good start on one. I got a lot of the rust off. 1548641062475785932153.jpg but the rust I couldn't get was bothering me. So I attempted to knock it off with the old trusty wire wheel on a die grinder trick. 15486411587052060322699.jpg The grinder kicked like a mule at a rodeo and decided to make tracks up the side of my face and nose. It moved quick too. I didn't even have time to react, till the grinder was on the ground jumping around. Then I reached down and turned it off. And went inside to assess the damage. 20190127_192458.jpg
    I think my beard and mustache saved me from it being a lot worse . It was a bunch of cuts from my cheek , up my lip and across the tip of my nose. I rinsed it off with some water and sprayed it down with some bactine. My lips are numb but so are the cuts. Can this be considered a motorcycle related injury?
  18. NoelJ
    NoelJ Long timer
    Apr 7, 2016
    2,044
    USA
    Drop those pegs in a bowl of vinegar for a few days and go to bed. Safer there!
    Puregonzo279 and JimVonBaden like this.
  19. LandsVW
    Oct 20, 2012
    770
    Tri City, Oregon
    Oh My! Sure, maybe embellish the story a little tho. ;)
    Puregonzo279 likes this.
  20. JimVonBaden
    Feb 11, 2005
    94,916
    Alexandria, VA
    Lesson learned. When using wire wheels on a grinder, use this:
    severely likes this.
