Resealing Seams on a tent, tarp, or rainfly
Discussion in 'Camping Toys' started by dredman, Nov 10, 2019.
  1. dredman
    dredman Dirty Moto-Tourist
    Jul 18, 2007
    691
    Driving around in a Steel-Tent
    It started out as a small repair on my tarp that had some slight oozing on two pull-outs. I figured while I was at it, I would experiment with an old tent I was about to retire that had a significant leak in the vestibule. I wound up treating all the seams on both, but when the tent treatment did not work I sprayed the entire fly for giggles. I was really impressed with the result.
  2. DCrider
    DCrider Live from THE Hill
    May 7, 2008
    8,558
    Washington, DC
    Interesting fix, did you notice any appreciable weight gain on the tent rainfly once fully coated with the spray bottle and dried? Rainfly still just as flexible?
  3. dredman
    Jul 18, 2007
    691
    No weight gain on the tent fly, and the even coat did not show any odd shades. That fly was crusty already, so flexible is not something I would describe. I only treated the seams on the other, but it did a show a sheen on those spots. Well that, and it stopped the leaks :)
  4. DCrider
    May 7, 2008
    8,558
    Washington, DC
    Good to know, recently replaced the fly on my 10yr old ALPS tent as seam sealer did not do much. I may give your approach a try on my old REI tent as they don't have replacement rainflys.
  5. dredman
    Jul 18, 2007
    691
    I am thinking seam leaks are just one of many paths for rain to penetrate. The more I think about the tent, the more I consider WHERE the most wear comes from - rolling up the vestibule 1-5x every day I am inside it means it will lose its coating that much faster. So surprised it has lasted me this well for so long, and just now showed small leaks?
    $12 worth of supplies and you can spray 10+ entire rainflys, instead of just 'seam-sealing' one for the same price? I would like to know your experience?
  6. DCrider
    May 7, 2008
    8,558
    Washington, DC
    Well I did use the $8 bottle of seem sealer on the REI tent then sprayed the entire fly with the KIWI Camp dry $6.95, did seem to fix the leaks based on quick hose shower but not yet used it in a steady all day rain. If/when it fails again I'll go with your technique as I suspect it's a better approach, plus cheaper and as a former KLR owner I appreciate cheap fixes that work!
  7. CROSSBOLT
    CROSSBOLT Been here awhile
    Sep 4, 2018
    742
    Hillville, TN
    How 'bout spraying with Scotch-Guard?
  8. DCrider
    May 7, 2008
    8,558
    Washington, DC
    Kiwi CampDry is essentially the same thing, it works but tends to wear out after a couple uses.
    #8
  9. JR356
    JR356 Long timer
    May 4, 2005
    6,982
    Way Northwest
    Here is method I used,materials available at nearby hardware store.
    Have used SeamGrip,etc in past,this works just as well.
    Use NikWax Tent and Gear SolarProof on the rainfly as a protectant and waterproofing.
    JR356
    #9
    DCrider likes this.
