Restoring Faded Pelican Cases?
Discussion in 'Equipment' started by Lucky_Devil, Feb 13, 2014.
  1. Lucky_Devil
    Lucky_Devil Master Lurker
    Jun 11, 2007
    253
    San Francisco, CA
    I have Pelican cases for luggage on my KLR (top and sides), and they've all faded to a chalky gray.
    Anyone have any experience, or tips, on how to get them black again? I tried searching the forum, but apparently it couldn't handle the term "restore faded pelican"
    Hesitant to use something like Amour All, as I don't want them to be shiny and greasy... just black again.
    Thanks in advance!
  2. lilolita
    lilolita fahr mit mir
    Dec 18, 2008
    1,362
    Probbydense, RI
  3. Lucky_Devil
    Jun 11, 2007
    253
    San Francisco, CA
    I've used that stuff before, and it has a sheen to it...
    I might have to get over my aversion to having them be shiny.
  4. bomber60015
    bomber60015 Hold fucking fast Supporter
    Sep 11, 2008
    76,057
    Chicago-ish
    tried aerospave protectant 303?
  5. Lucky_Devil
    Jun 11, 2007
    253
    San Francisco, CA
    Have not... never heard of it!
    Thanks for the tip, I'll check it out.
  6. tiger seven
    tiger seven Been here awhile
    Nov 7, 2011
    122
    Louisville, KY
    You might try peanut oil. I know it works well on restoring the color to a lot of faded black plastic parts (like on '60s and '70s Japanese motorcycles) and it may work on a Pelican.
    Derek
  7. Creation
    Creation Been here awhile
    Jan 20, 2011
    663
    PNW
    Heat gun works for me
  8. dfwscotty
    dfwscotty Long timer
    Apr 9, 2006
    4,059
    Denton, TX
    Ditto on the heat gun. It works for faded KLR fenders and jeep wrangler fender flares. Start far away at first!
    Don't laugh, I have a couple of black trim pieces on my '99 GS that had faded. I used the black shoe polish that has the dauber on the end. Wasn't perfect but it was blacker.
    #8
  9. Derangedrover
    Derangedrover Adventurer
    Jul 10, 2009
    14
    :earMight want to try just wd40 works pretty good at keeping mine clean
    #9
  10. watchmen
    watchmen Been here awhile
    Jun 4, 2008
    359
    Santa Barbara, CA
    #10
  11. squish
    squish Out of the office.
    Dec 4, 2003
    9,366
    Where the Ghetto meets the sea.
    What's happening is the top surface of the case is breaking down from UV damage.
    All the back to black, shoe polish, black paint. Those just dress up the case with a covering some lasts a little longer then others. But after a while the grey chalky finish will come back.
    Pop open the case and look inside there should be a calender and a material mark, it will say something like PPO or HDPE or PET, or it might have the recycling arrows with a number in the middle. (I think those cases are Polypropylene,)
    If you use oils, then it will be near to impossible to paint the case later on, and they still will not stay black as the oil dries up.
    I'd try a heat gun or a propane torch with a very wide fan tip, Lightly go over the surface just until it flashes.
    You might be able to burnish the warm case with a smooth tool, like the back of a spoon.
    If this doesn't work then you still have the option of painting the case. I had decent luck painting a very chalky Givi bag
    I just used a standard Rustolom semi flat black, no fusion no primer none of that. I just cleaned the case well with dawn dish soap then water then a red scotch bright pad to give the paint a little tooth.
    That was five years ago and the paint is just now starting to wear off. But that case was ABS, Polypro doesn't so much like paint to stick, but if you flame treat it, (see above) and then paint it right after that you have a little more luck getting paint to stick
    #11
  12. 9Realms
    9Realms Drawn in by the complex plot
    Jul 23, 2010
    6,128
    Central Minn.
    Hurculiner ! :clap
    #12
  13. Woodcock
    Woodcock Been here awhile
    Jul 30, 2013
    355
    Satin black paint, did mine. 5 years ago still looking good
    #13
  14. CollinsB
    CollinsB Long timer
    Aug 17, 2003
    1,116
    Orange Co., CA.
  15. Wlfman
    Wlfman Long timer
    Sep 6, 2011
    1,299
    TN
    Use this stuff -- http://www.trimshine.com/ -- I used it on the plastic trim of my truck that is red interior and the trim had faded to chalky white. Its now 6 months later and its still nice dark red like it was off the factory floor.
    #15
  16. worwig
    worwig Long timer
    Nov 30, 2009
    1,998
    Hog Mountain
    303 is good stuff. It is water based, so it is very safe.
    But, it is water based. It washes off in the rain.
    #16
  17. H96669
    H96669 A proud pragmatist.
    Nov 20, 2009
    5,943
    Hiding off Hwy 6, B.C.
    A good coat of leather dye. Turns the plastic an ugly purplish color. Apply paste shoe polish, let dry well and buff. Works for me, I have intentionally defaced black plastics if just to learn cheep and easy refinishing under the shade trees.
    And then applied the processes to my bike.:D
    #17
  18. bomber60015
    Sep 11, 2008
    76,057
    Chicago-ish
    Thanks -- I learned something today.
    Time for a nap.
    #18
  19. JCANRUN
    JCANRUN Adventurer
    Apr 19, 2013
    40
    Probably a dumb question, but would fading be covered by the lifetime warranty?
    EDIT: Just looked up on the Pelican site, it says "Pelican Products, Inc. guarantees its products for a lifetime against breakage or defects in workmanship."
    I'm not sure fading would be considered a defect in workmanship, more than likely, it is just normal wear and tear. But, it might be worth a phone call just to find out for sure.
    #19
  20. Lucky_Devil
    Jun 11, 2007
    253
    San Francisco, CA
    I went ahead and picked up some of the "Forever Black" Bumper & Trim product. Just wanted to update everyone on the results... which were outstanding. I got exactly what I was looking for, Pelican cases that were black again without being shiny or greasy. I ended up using a cheapie .99c paint brush instead of the foam tip applicator so I could get into all of the nooks and crannies better.
    Thanks for all of the tips and suggestions everyone :freaky
    #20
