Restoring look of rashed crashbars
Discussion in 'The Garage' started by texas_aggie, Nov 6, 2019.
  1. texas_aggie
    texas_aggie Been here awhile
    Oct 2, 2011
    469
    On a recent foray into Mexico, I managed to rash up one of the Altrider crashbars on my R1200GS. The original finish was what I would describe as "bead blasted" or a "matte" look. The bars are stainless steel. Looking for tips on how to restore the rash back to the original finish (or as close as original as possible). I was thinking of maybe hitting them with a flapper wheel but then they'll be too smooth and shiny I think. Thanks IMG_7344.jpg
  2. south
    south Long timer
    Mar 10, 2011
    1,003
    Florida
    Sand out (at least the worst of the) scratches, then bead blast back to the "bead blasted" finish; might end up doing both sides just to match, if that's an issue.
    sieg, texas_aggie and kantuckid like this.
  3. concours
    concours WFO for 48 years
    Dec 2, 2008
    7,406
    NH USA
  4. Maggot12
    Maggot12 U'mmmm yeaah!!
    Feb 21, 2010
    19,590
    Canada's ocean playground
    I'd file/sand that out, and finish over it. If there are much deeper gouges that I didn't want to keep filing, fill in with some JB weld, and file/sand a little more to have a smooth finish..
    texas_aggie likes this.
  5. kantuckid
    kantuckid Long timer
    Nov 29, 2007
    9,649
    Kentucky-Eastern that is!
    Depends on whats at hand. It could be a hand file then an abrasive paper of the least aggressive grit possible.
    In my own shop I'd do a flap wheel as the least aggressive removal that follows the shape too, then blast them and re-install. I might use a 2-3" dia 80 then 120 pad then follow with a 3" scrub pad on same tool- which could make a nice dull finish on these if you lacked a blaster. Mfg used either an abrasive flap wheel or beads to make them or they had satin tubing for starters.
    There's bound to be enough metal tubing thickness to avoid use of a filler material? The issue is how you can best remove the nasty.
    That is an area that shows when MC's upright so winters a great time to doll it up.
  6. Salsa
    Salsa Long timer
    Dec 12, 2006
    1,301
    Arizona, Alaska
    Nice badge of honor !!!
    Don't touch it.
    Don
    texas_aggie and Traxx like this.
  7. kantuckid
    Nov 29, 2007
    9,649
    Said like a true millennial...:rofl all about the "look" ?
    The flip side could be a poor rider who can't stay up,etc..:dunno
    sieg and texas_aggie like this.
  8. Salsa
    Salsa Long timer
    Dec 12, 2006
    1,301
    Arizona, Alaska
    Sorry, I'm no millennial. 30 years to old to be the oldest millennial.
    None of my stuff is shiny
    Don
    #8
    kantuckid likes this.
  9. yokesman
    yokesman Long timer
    Sep 12, 2008
    2,532
    SW. Idaho
    file it, then blend it into the radius, use your fav color paint to match, if ss no need eh?
    #9
  10. Houstrom46
    Houstrom46 Been here awhile
    Dec 3, 2017
    143
    Houston
    Not sure how it would ever look undamaged again. These are not superficial scratches; they are gouges that will never be concentric to the rest of the bar without adding material which would be alot of work. I'm not sure that simply matching the texture would mask the damage. If it were me, I would A) Leave as is because there's a story behind every adventure that you can recount, a fishing story of sorts, or B) get a new (or gently used) bar. Trying to fix something like this could turn out looking like something you tried to fix. This has been my experience anyway. Good luck on whatever you decide..
    #10
  11. DonM
    DonM Do-dah Do-dah Supporter
    Jan 13, 2008
    3,038
    Atlanta, GA
    It’s your history, embrace it :)
    #11
  12. Beezer
    Beezer Long timer Supporter
    Oct 26, 2004
    9,746
    Anchorage, formerly Spenard (hub of the universe)
    how about "fuck it" and just ride. belt sander and Krylon... or skip the sander part
    #12
    Wentwest likes this.
  13. Wentwest
    Wentwest How's that work?
    Feb 19, 2007
    3,379
    Northern California
    If you really, really want it to go away you can sand it down however you want and have both sides powder coated with a color of your choice, in a pebbly finish.
    #13
  14. AZ Pete
    AZ Pete Been here awhile
    Mar 11, 2013
    172
    smooth out the damage as outlined above and bead blast or hit them with plastidip spray..
    #14
  15. FTL900
    FTL900 White and nerdy
    Oct 3, 2005
    1,268
    Las Vegas
    When I bought my FJR1300, it had been a rental bike and was dropped on the right side, scuffing the saddlebag. Rather than repainting it, the owner just shot it with some gray primer.
    Funny thing is, I didn't notice until I took that bag off months later. Because it was on the bottom, it just wasn't visible as gray instead of silver. So gray primer may work well for you too.
    #15
  16. JAB
    JAB Unsprung Weight Supporter
    Dec 2, 2004
    1,674
    Beautiful Monrovia
    That's where you weld on the light tabs. Or use rattle can bed liner. Or clear coat to preserve.
    #16
    Stasher1 likes this.
  17. squish
    squish Out of the office.
    Dec 4, 2003
    9,160
    Where the Ghetto meets the sea.
    It's stainless, so you can sand the scratches down,
    Start by using a file 90 degrees to the scratch direction,
    Then using sand paper starting at about 400 grit wet or dry, start sanding 90 degrees to the filing directions.
    The idea is to keep doing that until all the scratches you are sanding out are gone, then you use the next grade finer on the sand paper, and sand against the last sanding direction.
    I'd go down to about 800 grit,
    Then I'd take the bars (both sides) into a shop that can media blast the bars. I'm guessing these bars are ball burnished... but a good media blasting shop will know how to get a finish that's close to whats on them.
    They won't look perfect, but they will look much better.
    Or, you could use some spot filler, fill the scratches, sand the tubes back to a round shape.
    Then paint them a bright silver. There are decent rattle can silvers out there, that are easy to work with and last a decent amount of time. Just remember that there are a lot of solids in good silver spray paint so it's a good idea to warm the cans up a little and make sure to shake the heck out of them, I like using towels warmed in a microwave and I'll shake the can for at least 2 mins rotating it in my hand as I'm shaking it to make sure that all the metallic flakes are picked up and are in suspension in the paint.
    Another option is having them powered coated, but then it's harder to repair them when they get scratched again.
    #17
  18. Riteris
    Riteris Dessert Runner
    Aug 26, 2002
    5,306
    A place many ADV Riders fear: The Nation's Capital
    I would rather be riding than dealing with something like this.
    But, you might consider wrapping the bars with bicycle handlebar tape and be done with it.
    #18
  19. r60man
    r60man Long timer
    Mar 14, 2013
    2,062
    Centralish PA
    Rattle can bed liner comes in cans, many colors and will fill in most of that with very little effort. If you scratch them in the future just shake the can and hit them again.
    #19
    Stasher1 and tvpierce like this.
  20. tvpierce
    tvpierce Been here awhile
    Sep 5, 2011
    942
    Maine
    +1
    File/grind off the high spots, paint it with black bed liner. Re-apply for future scatches.
    #20
