Reverse installed!
Discussion in 'Hacks' started by L8Braker, Feb 14, 2020.
  1. L8Braker
    L8Braker Adventurer
    Jun 15, 2011
    21
    I just installed the MMD reverse kit on the 2008 Road King with 2008 Harley sidecar. Install went as smoothly as could be. The only fly in the ointment, was the fitting up of the exhaust. On, off, on, off... Checking for clearance, checking for interference etc. I became a better man for the lesson in patience. Exhaust nuts are no longer my hated enemy. The best part of finishing any project is in the test ride! I quickly learned to: NEVER ,EVER, while in reverse, twist the throttle while the bars are turned. In one nano-second the bars went to full lock and the beast spat me unto the ground. To install the reverse unit I had removed the tub from the frame and this made the rig very unstable. The flip and spit caused no damage to the rig as it landed on the crash bars. Oh well, lesson learned. Don't gas it in reverse. I must have watched the reverse burnout on the Baker Reverse Kit and was feeling inspired. HA,HA,HA
    Bar None, brstar, DRONE and 3 others like this.
  2. TurTal
    TurTal Long timer
    Jul 30, 2015
    3,852
    When in reverse does it go otatop otatop otatop
    Jeff 8, zaxrex, Ridn3 and 14 others like this.
  3. L8Braker
    L8Braker Adventurer
    Jun 15, 2011
    21
    Yeah, and it sucks up all the oil on the driveway. :imaposer:imaposer
  4. FLYING EYEBALL
    FLYING EYEBALL out of step
    Mar 18, 2008
    12,196
    north of seattle
    pics?
    Looks like the MMD Kit is a little more affordable than some of the other options.
    My Champion setup has been great.
  5. ChiliPepperGarage
    ChiliPepperGarage Spork
    Oct 4, 2014
    282
    Smith Valley, NV
    Did you take any photos of the install? I'm going to put a reverse on mine someday.
  6. L8Braker
    L8Braker Adventurer
    Jun 15, 2011
    21
    The CD , which is included in the kit, is very basic, still pictures etc. This is a very easy install. The only difficult issue was the fitting of the exhaust pipes. The reverse unit is aprox. 3/4 on an inch thick. Even with the included spacers it is now very close to transmission . I will admit I'm anal when it comes to clearances. In a former life my tolerances were one micron roundness, straightness, and taper, MAX. If you'd like, I'll gladly share the CD with you.
  7. ChiliPepperGarage
    Oct 4, 2014
    282
    Smith Valley, NV
    I have staggered duals and the rear pipe has some clearance but not sure if I'd have to space it out or not. Where did you buy yours from?
  8. L8Braker
    L8Braker Adventurer
    Jun 15, 2011
    21
    Bought my reverse kit off e-bay $1099.00 shipped. The real issue with my exhaust is that I have a crossover pipe behind the transmission, when I jiggled, cussed and persuaded it to provide clearance for the reverse shifter, the lower front exhaust clearance would diminish. I'm still thinking of true dual exhaust which would eliminate my issue.
    #8
    ChiliPepperGarage likes this.
  9. Bar None
    Bar None Long timer Supporter
    Mar 2, 2007
    12,426
    SWFL WNC
    #9
  10. CrapKerouac
    CrapKerouac Been here awhile
    Sep 19, 2019
    508
    Canada
    I'd be concerned with the addition to the bikes weight. Lean and mean right?
    #10
  11. ChiliPepperGarage
    Oct 4, 2014
    282
    Smith Valley, NV
    I can't imagine it would weigh more than about ten pounds or so. I certainly don't think you'd notice the difference.
    #11
    Bar None and Bobmws like this.
  12. ChiliPepperGarage
    Oct 4, 2014
    282
    Smith Valley, NV
    How about posting a picture of your rig? Not a lot of HD's here in the hacks section. Here is mine.:super
    #12
    Bar None, TurTal, Bobmws and 4 others like this.
  13. CrapKerouac
    Sep 19, 2019
    508
    Canada
    I was joking. I'd love a reverse on every bike I've ridden. It should be standard on a Harley.
    #13
    L8Braker likes this.
  14. FLYING EYEBALL
    Mar 18, 2008
    12,196
    north of seattle
  15. Strong Bad
    Strong Bad Former World's Foremost Authority Supporter
    Oct 29, 2007
    10,944
    Omicron Persei 8
    Someone have a picture of this device before and after installed so the rest of us can get a clue as to what is being discussed??
    #15
    Wolfgang55 likes this.
  16. FLYING EYEBALL
    Mar 18, 2008
    12,196
    north of seattle
    Mounts on the end of the Tranny.
    #16
    Jimr80gs and brstar like this.
  17. Wolfgang55
    Wolfgang55 Long timer
    Dec 24, 2006
    4,226
    Only N flowin river emptying in an ocean
    WOW
    A real live reverse, headed your way soon.
    #17
  18. L8Braker
    L8Braker Adventurer
    Jun 15, 2011
    21
    The weight of the reverse unit is only ba few lbs. I normally carry a 50 lb. sack of sand in the sidecar, so I don't think it makes any difference.
    #18
    Bobmws likes this.
  19. L8Braker
    L8Braker Adventurer
    Jun 15, 2011
    21
    Here's one of the old girl. All cleaned up, ready for the dance!
    #19
  20. Jeff488
    Jeff488 Aspiring Profligate
    Feb 15, 2008
    55
    East Texas
    Oh my! That’s real pretty.
    #20
    FLYING EYEBALL and Bar None like this.
