Review: Highway Dirtbikes "big bike" kit for the 950.
Discussion in 'Dakar champion (950/990)' started by Geek, Feb 18, 2010.
  1. sven520
    sven520 Adventurer
    Oct 9, 2005
    95
    You might get a set of ROX Pivot risers and bring your bars both up and back.
    Thanks 6USMC6 I'll take a look at that. I noticed that Steverino notched out
    a C Baily so the hand guards would fit, looks clean.
  2. sven520
    sven520 Adventurer
    Oct 9, 2005
    95
    I checked out the ROX risers, not enough throttle cable for the two inch
    rise. talked to RTT this am they are sending out 4 1/2 inch risers.
    Keeping my fingers crossed:clap
  3. roundtripping
    roundtripping Adventourist
    Feb 21, 2009
    1,726
    Lake Elsinore, CA
    How is 4 1/2 inch risers gonna need less throttle cable than 2 inch risers?
    EDIT: unless you're saying you're getting four half inch risers, not 4.5 inch risers? I'm so confused! :lol3
  4. 6USMC6
    6USMC6 -U-
    Jan 5, 2009
    4,894
    Me too. The 1 3/4" Rox worked on my SMR - even with the short cables they have - and they're perfect on the Adventure.
  5. sven520
    sven520 Adventurer
    Oct 9, 2005
    95
    That is a little confusing. I wanted two one inch spacers, there not in stock
    so he's gonna send me four 1/2 inch spacers for the same price. That mite work out even better. You know were I can get a cable stretcher?:D
  6. jwdub
    jwdub Long timer Supporter
    Oct 2, 2005
    1,439
    SW Washington
    Has anyone installed the anti vibration inserts in combination with the HWDB handguards? If so, could you tell any difference?
  7. Jim Colombotos
    Jim Colombotos Been here awhile
    Feb 20, 2010
    323
    San Leandro, Ca
    I installed them honestly did not notice a big improvement.
    For extra cable length if you haven't done so, flip the throttle cable housing upside down on the handlebars.
  8. jwdub
    Oct 2, 2005
    1,439
    SW Washington
    Jim,
    Thanks - I just tried them on some ProTaper Windham Mid Bend bars w/o the handguards and I couldn't detect any difference either. I've had better success on other bikes by using extra heavy (17 oz) bar end weights. Don't know if the Anti-Vib inserts from HWDB are different from the Vibrinators from Ricor.
  9. the octopus
    the octopus The Chef
    Nov 26, 2008
    104
    Los Angeles, CA
    Just installed them today. No real difference. Minor decrease in vibration, but not necessarily worth the cost.
  10. Geek
    Geek oot & aboot
    Jun 8, 2003
    35,953
    8000ft.
    Yup... they're tough. :rofl
  11. ten_fiver
    ten_fiver Long timer
    May 4, 2008
    5,804
    SW Wyoming
    How is your handlebar control wiring routed? I just put a set of HDB guards on last night, but I'm not too happy with the cables resting across the handguards. On the left, they wouldn't fit under without rotating the clutch lever down further than my fingers would reach. On the right, they are tucked under the handguard, but still rubbing. Maybe I'm doing it wrong. Oh, it's a 990 if that makes any difference.
    *still waiting on the mirrors to show up, so that's why I still have the stockers on.
      File size:
      60.5 KB
      774
  12. Geek
    Geek oot & aboot
    Jun 8, 2003
    35,953
    8000ft.
    Do you have your levers rotated down to where they should be ergonomically? :lurk
  13. ten_fiver
    May 4, 2008
    5,804
    SW Wyoming
    Well, kinda. Where they should be rotated (ergonomically), the wiring won't fit at all. I can rotate them further down, but then I have a harder time reaching them. The only way I can get the wires to work is if I rotate the levers up a little too high.
  14. Geek
    Geek oot & aboot
    Jun 8, 2003
    35,953
    8000ft.
    :dunno I have no wiring issues whatsoever.. It might be touching the sheaths here & there but the cables move inside the sheaths- should have zero impact (and has had no impact in 20000 miles of hard riding) my wiring is stock :dunno
    My levers are all low - comfortable when standing (maybe 30-45 degrees below horizontal).
  15. ten_fiver
    May 4, 2008
    5,804
    SW Wyoming
    Hmm, ok. I loosened the brake line to rotate it back a little, that helped. As for the others that are rubbing, I might just wrap them with rubber tape or something where they make contact.
    Just a quick question: I have my clutch side wires routed over the handguard bar, and my brake side routed under (except the throttle cables which aren't a problem.) Is this how you have yours routed?
    Thanks for your help.
  16. Geek
    Geek oot & aboot
    Jun 8, 2003
    35,953
    8000ft.
  17. 6USMC6
    6USMC6 -U-
    Jan 5, 2009
    4,894
  18. Geek
    Geek oot & aboot
    Jun 8, 2003
    35,953
    8000ft.
  19. Flyin Phil
    Flyin Phil Been here awhile Supporter
    Mar 29, 2007
    271
    SouthWestern BC
    :ear
    curious about this too. I'm guessing the barkbuster model kaoko is the way to go, but since shipping over the line is a bit of a hassle, I'd like to make sure the right parts arrive the first time around.
    :freaky
  20. GlobalTech
    GlobalTech Adventurer
    Oct 26, 2010
    74
    Hampshire, UK
    I spent weeks back and forth with Kaoko SA on this and sent them drawings of the HDB (from Paul) to get them to design something that combined the HDB bar insert with the Kaoko.
    Unfortunately, I got nowhere, so I bought a used standard KTM Kaoko (off a Advrider Inmate) and modified it. All you have to do is cut the chamfer off the Kaoko and tap the bar end deep enough allow it to be sandwiched between the bar end and the handguard.
    It works a treat, but be aware that a heavy fall could misalign the Kaoko lock rendering it inoperative. I guess this goes for any impact the Kaoko recieves, since its made of very soft alloy.
