Review: Highway Dirtbikes "big bike" kit for the 950.
Discussion in 'Dakar champion (950/990)' started by Geek, Feb 18, 2010.
  1. bEnt_bars
    bEnt_bars Been here awhile
    Jan 23, 2006
    147
    Vancouver
    I'd like to go with the HDB guards but I might have a clearance problem...
    The Dirtnblood submount riser setup that I have pushes the bars further forward than the BRP ones and I don't know if there's enough room left for the HDB guards without them smacking into the fairing
    Anyone out there with these risers and the HDB's that can let me know?
  2. bikyto
    bikyto Dans le doute...gaz!
    Jun 15, 2009
    2,348
    Northern Cali
    I had that setup for a while and did not run into clearance issue.
    Oh, I had the stock Ktm bar for reference.
  3. plumbtired
    plumbtired plunging into the farkle
    Apr 13, 2008
    184
    Slo Cal
    Stock bars seem to differ between years of release. Paul is lookin to make templates for more specific fitting on these KTM 9XX bikes. If ordering a set might be helpful to mention which model ur fitting. If you experience problems getting them to fit give Paul some feedback. :ear
  4. adiablolex
    adiablolex Lost again
    Jul 30, 2007
    3,692
    Third rock from the Sun
    same here, installed mine on my dirtinblood risers and other than rotating the throttle housing for some extra slack all's well :D
  5. Michhub
    Michhub Major Medical Supporter
    Aug 15, 2006
    4,308
    San Tan Valley
    Good to know on the Dirtinblood risers and stock Renthal 792 bend bars....I was thinking of switching to the Pro Taper Pastrana FMX bars with less sweep...any experience with these and the HDB setup?
  6. bikyto
    Jun 15, 2009
    2,348
    Northern Cali
    I had the pastrana and found them so similar to the 792 that I went back to 792 and gave them to a friend. The RC are my next choice.
  7. Michhub
    Aug 15, 2006
    4,308
    San Tan Valley
    So I got my kit today and promptly went to work....I got to this point and stopped as it seemed they were 'not even close'.....
    how much persuasion are you guys using to get these to line up? I have an email into Paul but thought I'd throw this out to the collective....
    Stock bars....I did not tap these bars as they are threaded for the 8mmx1.25....
  8. bikyto
    Jun 15, 2009
    2,348
    Northern Cali
    That's all good. You can work them in and they'll fit. It's a great setup and just needs a little bit of elbow grease.
  9. crazybrit
    crazybrit Defying any self identifying
    Mar 16, 2006
    9,701
    Portland, OR
    Yeah but they look as if they are rotated pretty far forward in the clamps. I can see the bottom marker line (on the bars) visible in the window on the upper clamp.
  10. StmbtDave
    StmbtDave AKA Invisible Dave
    Aug 1, 2005
    4,674
    Montrose, CO
    I agree. Roll them back towards you and the guards should fit just fine.
    Dave
  11. FYYFF
    FYYFF Forever young...
    Jun 9, 2009
    2,261
    SoCal
    Sorry for the noob question.
    I have an ADVdx Top Clamp on my 990 and need an on/off switch on the top clamp for the LED's.
    Is "12v 10amp On/Off Pushbutton" the right one to use?
  12. Michhub
    Aug 15, 2006
    4,308
    San Tan Valley
    Thanks guys....:clap
