RevZilla Gear Discussion / Q&A
Discussion in 'Vendors' started by BoochZilla, Jan 21, 2009.
  1. Jeff_S2R1K
    Jeff_S2R1K Adventurer
    Jun 22, 2010
    57
    Way up in the hills among the evergreens.
    Thanks!!!
  2. scootertrog
    scootertrog Jedi Fart Master
    Mar 26, 2011
    1,042
    Missouri USA
    Looking at the new Cortech Fusion jacket. How breathable, or how well does air flow through it (without the rain liner), i.e. would it be OK for a summer jacket? All the photos that I have seen do not really zoom in close enough to see the actual weave. With a Warm&Safe heated liner, would it be OK for a cold-weather jacket?
  3. levain
    levain STILL Jim Williams Supporter
    Oct 29, 2005
    10,013
    Charlotte, Vt
    Can you stick either a wolfman or enduristan bottle holster onto a Kriega os 18 and see how it fits? Preferably, strapped onto the os base? While you're at it, stick the base onto a 690 and do a video:clap:clap
    I'm sure Kriega will say it won't work, but we all know what that means:lol3
  4. UPSHIFT_D
    UPSHIFT_D n00b
    Jan 5, 2018
    5
    USA
    No, never stick any non Kriega accessory onto the bag :jack.
    My personal preference is the Wolfman, it can be strapped to the top two tethers of the OS-18. The longer nylon straps give you a bit more leeway when mounting. It would be mounted horizontally atop the bag, but as long as the cap is tight, any spills should be prevented.
    With a bit of muscle you could also strap it to the side of the US Hook Straps(side of bag), it would be a pretty tight fit, but it can be made to work if you're ambitious enough.
    The OS-Base has been mounted to the 690 without issue, but no one thought to take photos, I'll see what we can do to make them available.
    FWIW we found some cool photos here(http://advrider.com/index.php?threads/ktm-690-luggage-rack-thread.365169/page-58) of the old Overlander 30 System. It mounts in the same position as the new OS-Base(the new one actually adds some more flexibility in terms of mounting) so it's the best reference we can provide for the moment.
    -Jeff
  5. levain
    Oct 29, 2005
    10,013
    Charlotte, Vt
    Thanks. I won't tell if you won't
  6. CowboyRR
    CowboyRR Been here awhile
    Jun 18, 2014
    728
    Powhatan, Va
    Interested in the Olympia Airglide 5 jacket but not sure about which color I will order. Is the neon yellow a fluorescent yellow/green or just a bright yellow? I ask because the pewter on the ivory/pewter looks lighter in the video than the photo.
  7. RevZilla
    RevZilla Best on Two Wheels!
    May 18, 2011
    675
    iladelphia
    Hey scootertrog,
    So the Cortech Fusion is more breathable than traditional textile jackets, but it's definitely not as breathable as a mesh jacket. I'd say that with the liner out, I'd probably be comfortable up to about 80 degrees Fahrenheit or so, perhaps a little more with low humidity. If your avatar bike is still correct, then the extra airflow from riding that Triumph should help as well. With a heated liner and perhaps a neck gaiter, you should be able to push it for cold weather use too.
    Hope this helps!
    -DrewZilla
    2012 Triumph Tiger 800XC
    2003 Suzuki SV650S (Sold...it was a good 11 years)
    1986 Honda XR250R (Needs some love)
    scootertrog likes this.
  8. RevZilla
    May 18, 2011
    675
    iladelphia
    Hey CowboyRR,
    With the Airglide 5 Jacket, the neon yellow is a true neon yellow (chartreuse, halfway between yellow and green), so the photo is pretty accurate. However, the photo for the ivory/pewter is darker than in real life. In this case, the video is a more accurate representation for that color.
    Hope that clears it up!
    -DrewZilla
    CowboyRR likes this.
  9. cblais19
    cblais19 Long timer
    Nov 3, 2017
    2,445
    VA
    I was looking at ordering the Knox Dalton single layer jeans and the new Spidi J-Dyneema jeans in to compare the two and pick one...but it seems that over the weekend all the Knox products went out of stock. Did you guys stop carrying them?
  10. RevZilla
    May 18, 2011
    675
    iladelphia
    Hey cblais19,
    We're definitely continuing to carry Knox. We're just waiting for the rest of our stock order to arrive. You should expect to see stock within the next few days. If you haven't already done so, you can select your size on the product page and request to receive an email notification when inventory replenishes.
    Hope this helps!
    -DrewZilla
  11. cblais19
    cblais19 Long timer
    Nov 3, 2017
    2,445
    VA
    Ok, thanks! It was just odd seeing everything go to an "out of stock" indicator on the same day!
  12. Hammerdown77
    Hammerdown77 Long timer
    Apr 24, 2014
    2,258
    North Alabama
    Zilla crew,
    I really like the TCX Hero WP boot and am close to pulling the trigger, but am not thrilled about having a waterproof boot for around town riding during our Summer heat/humidity. Is there anything similar in style and protection that does not have a waterproof membrane?
  13. RevZilla
    May 18, 2011
    675
    iladelphia
    Hey Hammerdown77,
    If you like the look of the TCX Hero WP Boots but don't want a full waterproof liner, definitely take a look at the Stylmartin Ace Boots. They're lace-up with a side zip, have really nice leather, a lugged sole, and they aren't waterproof, so they'll breathe better. For additional options, also consider the Spidi X-Goodwood and Spidi X-Nashville Boots. They're oiled for a bit of water-resistance but don't have a full waterproof liner, so they'll still breathe like the Ace Boots.
    Hope this helps!
    -DrewZilla
    2014 Triumph Trophy SE
  14. Hammerdown77
    Apr 24, 2014
    2,258
    North Alabama
    Thanks for the suggestions! I looked all those over, read the reviews, and decided to get the TCX anyway. I've had TCX boots before, confident in the sizing, and even with the warmer waterproof membrane they still looked to be the best blend of style/protection/durability for my uses.
    Looking forward to trying them out!
  15. Rockhopp3r
    Rockhopp3r Been here awhile
    May 4, 2014
    921
    SoCal
    Hey Revzilla.
    So, which tank bag that you have in stock will fit nicely with a Tiger Explorer? Looking for something that isn't magnetic and that follows the contour of the gas tank as close as possible.
  16. RevZilla
    May 18, 2011
    675
    iladelphia
    Hey Rockhopp3r,
    In my opinion, the best option is the Givi UT810 Ultima-T Tanklock Tankbag. It has the cleanest install with a Givi tank adapter ring and fits the profile and size of the tank nicely. No magnets and no straps to worry about.
    Regards,
    DrewZilla
    Rockhopp3r likes this.
  17. Rockhopp3r
    May 4, 2014
    921
    SoCal
    Thanks Drew!
    No chance of getting a picture of a TEX with it installed?
    Sent from a phone
  18. RevZilla
    May 18, 2011
    675
    iladelphia
    Hey Rockhopp3r,
    I don't have a photo of it on a TEX, but I used my best judgment by comparing a photo of it mounted on a GS and then comparing the tank profiles of a GS and a TEX. The TEX tank takes a more vertical slope closer to the seat, but the profile from the filler cap towards the middle slope of the tank is quite similar.
    Regards,
    DrewZilla
  19. Rockhopp3r
    May 4, 2014
    921
    SoCal
    Thank you!
    Sent from a phone
  20. Parx400
    Parx400 Long timer Supporter
    Jun 17, 2010
    7,154
    Sacramento CA
    Old post but is the newer stow away cut the same? I wear an XL in mojave Jersey but I have a large old school badlands pro. Jacket is a little snug but the XL is massive with no layers.
    Should I get a large or xl stowaway? I don’t plan to wear it over anything.
