Ride off center stand?
Discussion in 'Airheads' started by quietglow, Aug 30, 2021.
  1. quietglow
    quietglow Been here awhile Supporter
    Jun 24, 2021
    106
    Chicago
    My new 74 R90 has a ride off center stand. In my 2 days of ownership, I have already begun to dislike it. Not having the wheels off the ground means no makeshift bike lift. Worse, on my concrete garage floor, it's super hard to get off the stand any way other than actually riding off it. If you try to lift it off normally, it slides.
    Two questions:
    1. It is very much possible that I am missing something. If you like ride off center stands, please tell me why.
    2. If I opt to switch back to the stock stand, is the job a pain? I imagine getting the springs in place is no easy task.
  2. raywilson
    raywilson Been here awhile Supporter
    Oct 3, 2007
    614
    Portland, Or
    I think it's a Brown's ride off. My S had one too. And i felt the same about it. I swapped w an inmate for a stock stand. The springs are a PITA but very doable
  3. Disston
    Disston ShadeTreeExpert Supporter
    Aug 31, 2009
    19,100
    Silver Spring, Md
    The big problem with the center stands is usually the frame tabs it bolts to. They bend and the threads in the tabs get stripped. There are fixes and some have welded reinforce tabs that last longer. The stock stand does it too but the Ride Off is harder on the tabs.
    If the tabs are straight and the threads are good proceed. Now the question now is which year stand works best?
    SmittyBlackstone likes this.
  4. Disston
    Aug 31, 2009
    19,100
    Silver Spring, Md
    The Ride Off was made by Reynolds.
  5. bwalsh
    bwalsh Long timer
    Jan 15, 2009
    31,217
    Helltown
    What size tires are on the bike? The correct sizes or oversize. My bike came with oversized tires, 3.50x19 and a 120/90x18 and I experience the same sliding(especially on my lift) as you do. If I hold my bike upright with the center stand down, it doesn't touch the ground. It rests on one side or the other of the stand when sitting.
  6. r60man
    r60man Long timer
    Mar 14, 2013
    2,782
    Centralish PA
    I never had an issue with my Ride Off stand, whether taking it off while not riding it off. As Dissten said the issues with all center stands is typically what they connected to on the bike being bent, or missing springs, or things like that. This link is to Duane Asherman's BMW website, a fantastic resource and it has the installation instructions posted so you can take a look and see what the issue might be: https://w6rec.com/reynolds-ride-off-stand/
  7. quietglow
    Jun 24, 2021
    106
    Chicago
    Oh interesting. So if I have the correct size tires, and the mount is in good shape, the tires should behave like a normal stand? I'll take a look tonight.
  8. 100RT
    100RT Long timer
    Nov 4, 2009
    1,981
    NEWTON FALLS, OHIO
    I have a Ride off on my 81 R100RT and love it. I have the correct size tires and the correct ride off stand for that bike. Both wheels are on the ground, if I need height I put a piece of 2x4 under each leg of stand. This stand is very stable in wind and on asphalt as opposed to the OEM stand. It's a love or hate thing I guess. 177K and never a problem!
    #8
    kenstone, korinthias and Solo Lobo like this.
  9. quietglow
    Jun 24, 2021
    106
    Chicago
    Oh well that is a fine way to handle that issue. Do you put it on the stand first, then put a block under each side? Do you have any problems with getting it off the stand without actually riding it off?
    #9
  10. Solo Lobo
    Solo Lobo airhead or nothing Supporter
    Mar 16, 2004
    12,396
    Shoreline, WA
    I've had ride-off stands on several airheads, and had to use the old 2X4 under the stand trick when servicing the bike....
    #10
    JMforPres likes this.
  11. brg
    brg 1977 XT500, 2000 ST1100, 1995 r100r Mystic
    Dec 13, 2014
    880
    southern ca
    I like the stock stand too. I've never had a problem popping it off the C/S while sitting on the bike. That's how I do my st-1100, and it's a 700 lb. pig at standstill. I've never been comfortable taking a bike off the C/S from the left side, I like to be straddling the bike. I guess it's one of those "whatever works for you" things.
    #11
  12. Disston
    Aug 31, 2009
    19,100
    Silver Spring, Md
    The way I get my Ride Off onto blocks of wood is first I use two blocks, one for each leg. With the bike on the stand I push it over to one side and slide a block under that leg. The I go to the other side and push the bike over and again, using my foot, I slide the other block under. Have tried various contusions to do this. One leg at a times with two blocks seems to work best for me.
    #12
    spo123 and Texer like this.
  13. Disston
    Aug 31, 2009
    19,100
    Silver Spring, Md
    Something that has been alluded to several times. Both the stock and the Reynolds stands have various versions made for different years. Many of these stands can or can be made to fit different years. Sometimes this is an improvement and sometimes it's not. The stock stand we can usually identify from a pic, no number stamped, or I don't think there is a number. The Reynolds stands should all have a number stamped somewhere. If you can find the number I think there is a list that tells what bikes it's supposed to be on. Just an idea.
    #13
  14. Pokie
    Pokie Just plain Pokie.
    Apr 4, 2013
    8,358
    Fort Collins, CO
    Like Disston says, the Ride Off stand was originally made by Reynolds in Salt Lake. Reynolds made a number of accessories for BMWs of the 70s.
    Being a BMW mechanic of that time,... I hated the ride off stands! I only would think of them as an inexpensive replacement for a damaged stand and that's all. Any time I bought a bike with a ride off stand fitted, I would replace it with a stock stand as soon as one was available. Course, I've seen many stock stands get bent by folks trying to "ride off" them. They would rock forward, give the bike some gas, then the bike would rock back and start to damage the stand and stops. Mind you, after I've pulled the ride off stand off, I never had trouble finding someone willing to buy it and just give me their old stand.
    #14
    raywilson likes this.
  15. korinthias
    korinthias slightly behind the curve…
    Apr 29, 2019
    370
    Devon, UK
    Snowbum, as one might anticipate, has more information on Reynolds products than can be readily assimilated in one or even several sittings… Here’s a link to the page on his site.
    I went through a phase wanting a ride-off stand for my ‘no-buy’ ‘83 RT (opinion voiced in a different Snowbum commentary), but the likelihood of picking up a #R-348 here in the UK, is exceedingly remote!
    Here’s page from a Reynolds catalogue, via the aforementioned guru:
    If you can locate the number on yours, you can work out if it’s right for the machine…
    #15
    spo123 likes this.
  16. nmalozzi
    nmalozzi airheaded
    May 4, 2013
    3,336
    Arvada, CO
    Hell, I've tossed wood under the stock stand a few times to get the bike a bit higher when working on longer term projects. Usually with a strap on the stand to make things a bit more solid.
    #16
    globalt38 likes this.
  17. 100RT
    100RT Long timer
    Nov 4, 2009
    1,981
    NEWTON FALLS, OHIO
    I lift one side and use my foot to slide the 2x4 under then go to the other side and do the same. Reverse the procedure to remove. What I really liked over the years is having the bike fully loaded with camping gear and not having to figure out how to get on it without lifting my leg crazy high.
    #17
  18. Disston
    Aug 31, 2009
    19,100
    Silver Spring, Md
    I like my Ride Off that came with my R90 Twenty years ago but I will probably go stock someday, not sure why. I do use the ride off feature some times and I think that is cool as can be. Nobody else ever seems to notice how cool I am.
    #18
  19. korinthias
    Apr 29, 2019
    370
    Devon, UK
    …but it is a widely accepted fact, in this domain!
    #19
    Texer, BJMoose and Disston like this.
  20. ME 109
    ME 109 Long timer
    Jun 25, 2009
    9,009
    Albury Australia
    I made a ride off stand from my stock '81 c/stand about 7 years ago. I did it by limiting how far over centre the stand could go.
    Most excellent when the bike is fully loaded with camping gear.
    Front wheel 2-1/2" off the ground.
    It's easier to get the fully loaded bike on the stand than with nothing on the bike.
    #20
