For those of you that use Ride-On Tire Sealant or want to try it, I worked out a group buy to get 10% off your order. The discount is good for any order of any product. So, here's how it works: The group buy is no longer functioning but it's still a good product. I'll work on getting a new code and will update here. (edited Nov 2015) Here's my little testimonial YMMV: I really like the Ride-On, I've used it for coming on eight years now. I know it works on punctures, which saves all kinds of head-ache on a trip, because I've picked up nails and been able to keep on riding. I first bought Ride-On because I was planning a big solo trip and was worried about flats. On that trip I picked up a nail. I did my tire check each morning and one morning I'd lost 2 pounds of air. I checked out the tire and found the nail, aired it back up and it kept pressure the rest of the trip (another 1000 miles) with only Ride-On - no patches or plugs. BTW, that was a tubed tire and it sealed the tube - that was pretty impressive and from then on I was convinced that it's good stuff. I also think it improves tire balance, wear and mileage. The few times when I've put on new tires and not used it (because I didn't have any on hand and didn't get around to ordering it), I've found that the tires wear much less evenly and much more quickly. With the Ride-On, I get about 1/3 more wear out of a tire. That makes the extra $$ per change worth it right there. Plus, b/c Ride-On stays liquid, it works as a dynamic balancer for a smoother ride as well. Finally, I've had no problems with Ride-On being in any way corrosive (unlike Slime - bad stuff, stay away) and it handles high speeds with no problems (trust me, I've pushed it to triple digits). It's not even terribly messy when you pull off the tire and washes right out with a quick spray of the hose. So, I like the stuff 'cause it works for me. YMMV but I put together the group buy for another forum and figured some of the folks here might benefit as well.
Thanks for setting up the discount, rave! Good summary. I use it in tube-type and tubeless tires on bikes as well as cars and trucks, and my experience agrees with yours.
Just talked to George at customer service...they are out of stock at present in small bottles, should have some in a few days. He offered to take my name/number and call me when in stock, and will discount 10%.
Thanx for the Promo Raven, just had an order overnighted for the big Tour at the end of the week. Thanx for the info too I hope I like it half as much as you do!!! It will be getting a 16,00 mile 6 week workout dirt and asphalt
But then I started reading reviews on the stuff. So, Slime works well in my wheel barrow and dolly, but it will never go in any of my motorcycles. I hope to make the TAR ride in April and I will add Ride-on to my Transalp before I head that way. BTW I put Dyna Beads in my Wing tires and removed several wheel weights. It was smoother than ever But I like the idea of Ride-on also protecting for leaks so when I replace those tires in it will go. Jim
I tried it in an RT and did not get very good results for the leak stopping. The wheel had weights so I cannot comment on that, but it was ridden for a few weeks with no bad side effects. You really couldn't tell it was in there. I drove a smallish nail into the tire to see if it stopped the leak and it didn't. Had the dealer talk to a rep afterwards, and they said you have to ride it for a bit to get it to work, which we were not able to because the air went out so quickly. I was kind of skeptical about their comment on having to ride it to get it to work since the stuff quirted out around the nail quite a bit (enough to bubble and make a mess) and I would have thought it would have sealed. We did ride it some, but apparently not enough to help, mostly due to it being so flat. Either way the tire was flat and we would have needed a pump. It might make good extra insurance, but probably not as good as a pump and plug kit. I was really bummed to since this looked like a really good product. YMMV as this is just my experience.
Promo still good. Ordered some after just having the wheel weights fall off, and I really don't want to pull it back off and drive them the 60 mile round trip to have them rebalanced. Read that this well work for balancing, so i'll give it a shot.
