RK says: "DO NOT USE KEROSENE OR WD-40 on a sealed chain!!"
Discussion in 'The Garage' started by sajohnson, Jul 16, 2019.
  1. sajohnson
    sajohnson Adventurer
    Jun 29, 2013
    89
    Central Maryland
    If your post was meant for me, I have no idea what you're referring to.
    I'm primarily a messenger. Most of my posts have stated what I've heard from RK; Suzuki; and Marco.
    I'm not sure where, "...spray down the chain and wipe off the excess. WITHOUT CLEANING THE CHAIN" came from, but it wasn't me.
    #41
  2. Grreatdog
    Grreatdog Long timer Supporter
    Apr 6, 2007
    37,378
    Annapolis, MD
    Probably meant me since I said to wash the chain when the bike is washed then spray to disperse the water and wipe dry. Which is cleaning the chain for me because my chains never get greasy in the first place.
    I ride offroad. So the last thing I want is an oily chain collecting every kind of dirt I ride in. That's what kills chains in my world. That's why x and o ring chains have the sticky stuff on the inside not on the outside.
    Since I run x-ring chains dry I don't need to scrub or degrease them because they don't get greasy in the first place. I just need to wash mud and grit off the chain when I clean the bike then add something to prevent rust.
    I have never replaced an x-ring chain once I replaced whatever disaster I inherited from some previous owner. So what I am doing works well for me: clean with soap and water, spray with WD40 to get rid of the water, wipe dry.
    #42
  3. PunkinHead
    PunkinHead Moobless Adventurer Supporter
    Dec 10, 2005
    10,777
    Land of Walmart Shoppers
    So on one side of this debate we have people theorizing about kerosene or wd40 getting past the orings and destroying a chain and on the other side we have thousands of people who've been doing it for decades with no problem. Quite the dilemma. :hmmmmm
    #43
    JensEskildsen likes this.
  4. clammer14
    clammer14 Itinerant Boondoggler Supporter
    Apr 8, 2004
    195
    Isle of Long, New York
    I am not an engineer nor am I a chemist, but have a lot of organic chemistry under my belt.
    Years ago I was a salesman for Pennzoil in Tucson, AZ.
    I do know for a fact that in the oil industry at the commercial product level there is a lot of cross-labeling and marketing that occurs (sometimes locally).
    Different labeling is done to increase prices (and profits) in particular markets.
    My best advice...Use what works for you.
    To me, microscopic deterioration is total corporate CYA.
    #44
    bobw and mitchxout like this.
  5. dietDrThunder
    dietDrThunder Why so serious, son? Supporter
    Jul 29, 2009
    1,631
    Nashville, TN
    My last chain drive bike that I put a lot of miles on was a CBR1100XX. It had a brand-new chain and sprox when I got it, and I never did anything to it apart from spray with WD40 and rag-wipe. I sold that bike about 22000 miles later, chain and sprox still fine. I may have adjusted the chain twice. If the WD40 was doing damage, it wasn't very severe.
    #45
  6. C/1/509
    C/1/509 Think for yourself
    Jul 21, 2006
    14,329
    I wondered about this.
    #46
  7. Themastermike
    Themastermike Think you caught me in a coma Supporter
    Jan 20, 2011
    3,836
    So Ill
    I guess trying to lube and take care of a chain is costing 8k miles a chain.
    Dammit
    #47
  8. sajohnson
    Jun 29, 2013
    89
    Central Maryland
    OP here...
    Since the DR-Z400 manual specifies a "sealed drive chain cleaner or water and a neutral detergent", and the o-ring mfrs say detergent is compatible with nitrile o-rings, I ended up using straight Dawn dish detergent and a chain brush, along with a tooth brush.
    That worked great!
    Then I took it down the road and back to warm and dry the chain and applied Bel-Ray "Super Clean Chain Lube".
    https://www.belray.com/super-clean-chain-lube/
    Next time I think I'll dilute the Dawn some.
    #48
  9. Motomantra
    Motomantra Registered Lurker
    Mar 6, 2008
    3,186
    Beaverton, OR
    Dawn is awesome. Many uses.
    #49
  10. tominboise
    tominboise Long timer
    Jun 17, 2007
    3,652
    Boise, ID
    Yeah - I have used Simple Green for cleaning chains before, along with some hot water, and it works pretty well.
    #50
  11. tag3
    tag3 Doofus
    Jan 17, 2014
    16,926
    Inland from the coast of Santa Cruz and Trona.
    Does she cook too?
    #51
    LuciferMutt likes this.
  12. Themastermike
    Jan 20, 2011
    3,836
    So Ill
    Get up at the crack of Dawn
    #52
    bobw likes this.
  13. YesRush
    YesRush Long timer
    Aug 17, 2014
    3,940
    Va
    I put o’rings in my pan-cakes mixed with diesel.:thumb
    #53
  14. sajohnson
    Jun 29, 2013
    89
    Central Maryland
    I considered Simple Green, but IIRC it has something in it that does't play nice with nitrile o-rings.
    I may be misremembering that though -- I checked a lot of different cleaners.
    #54
  15. Castorp
    Castorp Adventurer
    Nov 16, 2016
    87
    So the Dawn flings off when you take the bike for spin? Any remaining Dawn doesn't break down the lube you put on after?
    This is a great thread, by the way. You're asking--and answering--the same questions I've been wondering about.
    #55
    9Realms likes this.
  16. 9Realms
    9Realms Drawn in by the complex plot
    Jul 23, 2010
    6,360
    Central Minn.
    What are the ingredients in Dawn dish soap?
    Ingredients: Inactive ingredients water, sodium lauryl sulfate, lauramine oxide, sodium laureth sulfate, alcohol denat., phenoxyethanol, sodium chloride, PPG-26, PEG-8 propylheptyl ether, methylisothiazolinone, fragrance, yellow 5, blue 1.
    (I'm thinking the yellow #5 is the secret here for chains!) :lol3
    #56
    Amphib likes this.
  17. SidewinderX
    SidewinderX Hey, watch this! Super Supporter
    Nov 3, 2009
    2,386
    NW North Carolina
    My wife is a chain and plastics sales person....
    I've had this debate with her for many many years...
    We have both given up and just smile at each other now.
    #57
  18. mung
    mung Long timer
    Apr 18, 2008
    1,233
    Idaho
    I am on the wd is ok for chains side of the fence. A good way to check for lube washout is to lube the chain like normal and after cleaning check the pins on the masterlink. If your lube is on the pins then you are good. If the lube is washed out you may need to consider a different lube or washing process.
    #58
  19. MotoChris521
    MotoChris521 motominded
    Aug 30, 2007
    3,374
    south west
    I use WD40 on the chain after a wash to remove moisture. Then hit it with BelRay super clean chain lube.
    Even plated chains rust.
    #59
  20. AUSSIEADV
    AUSSIEADV 2wo left foots
    Sep 5, 2006
    12,026
    Ned and Wild’s fight site
    Whats this “clean, lube, wipe” stuff?
    I fit a new chain, adjust it after break in and replace it when it starts needing constant adjustment.
    I cant fathom chain lube still being present after 1 mile up the road let alone penetrating well enough in the first place! Not worth the mess, cost, effort.
    In my opinion, the worst the chain has to endure is the raised ridges in your guides/slippers spinning the rollers!
    #60
    Suruppak likes this.
