ROADSIDE REPAIR PICTURES--Let's see 'em
Discussion in 'Photos' started by funhouse, Jul 6, 2007.
  1. funhouse
    funhouse Overdue
    May 6, 2007
    3,044
    Santa Barbara
    I"ll go first: 1965 on the way to the last AMA Death Valley Run / 1st long ride, brother-in-law helps newbie
  2. Air0ne
    Air0ne Adventure reader
    Mar 17, 2007
    170
    Montreal
    Pretty nice picture...
    Sorry... Never had the idea to take a picture for this kind of event... :rofl
  3. Stretch67
    Stretch67 Mad Scientist Supporter
    Mar 22, 2006
    18,772
    Bent, But Not Broken
    Cool vintage tank bag. :D
  4. Flat_Black_Rat
    Flat_Black_Rat Adventurer
    May 15, 2007
    90
    Seattle, WA
    I had swapped out the tank quickly before the ride (Quantico to Gettysburg) and has some issues, petcocks and fuel lines were rubbing the motor and later (rebuilding the carbs in a rest area) I found grass in a carb to boot. This isn't litterally road side, but a parking lot at a country club...
  5. scottcolbath
    scottcolbath Long timer
    Oct 18, 2004
    9,230
    Phoenix, Az.
    I just ripped the valve stem off a tire last weekend.
    S.C.
  6. DaleE
    DaleE TransAlp Adv
    Jan 13, 2006
    704
    Boulder, CO
    Large nail to rear tire in western Colorado
  7. RicH2
    RicH2 Ric H2
    Jan 18, 2007
    4,720
    North Alabama
    :huh How dare you post a pic of an old vintage bike without telling us exactly what it is !!!!
    I'm shocked I tell you ! Shocked !
  8. MIG
    MIG Edelweiss
    Apr 2, 2005
    86
    Black Forest, Germany
    Morocco april 2003 some where between Ouarzazate and Agdz
    Flat rear Tire in the Heat of Midday. Easily fixed with the standard factory supplied repair kit :clap
    Michael
    #8
  9. dwayne
    dwayne Silly Adventurer Supporter
    Feb 7, 2006
    7,486
    wheelie in purgatory, Calgary
    Somewhere in Montana, fixing a float needle that got stuck open. Turns out a good thump fixed it. Then I kinked the fuel line putting the tank on, I was paranoid for the remainder of the trip about carb problems.
    And here is Bejebus in Dawson City YK., removing brake pads with no lining left. Actually we removed the rotor stuffed a wrech into the caliper (so the pistons didn't pop out) bolted the caliper back in place, 'till we found pads in Anchorage.
    And after an exciting day on the Dempster Hwy. I needed to tweek my pannier mount
    and 650freak wanted to adjust his head steering head bearings
    #9
  10. DirtyDog
    DirtyDog Omnia mea mecum porto Supporter
    Apr 27, 2007
    11,760
    Tulsa... it's OK
    Dwayne- That's the creative crap I like to see!:lol3
    ...and I assume the spirit in which this thread was intended...
    We've all got boring pics of flat tire repair.
    #10
  11. Hambone950
    Hambone950 Mas Naranjas Por Favor!
    Jun 30, 2005
    676
    Calgary/ Houston/ Neuquen
    Texas Hill Country
    #11
  12. CA Stu
    CA Stu Like a drunken rodeo clown... Super Moderator
    Aug 27, 2004
    58,756
    Riverside, CA
    CA Stu
    #12
  13. clang
    clang Not lost, Exploring!
    Sep 18, 2003
    2,806
    Denver/Aspen
    Rear wheel lug nuts worked loose while riding through the canyon :eek1
    <img src="https://murgatroid42.smugmug.com/photos/26258317-M.jpg" border="0" alt="" /> <br />
    <img src="https://murgatroid42.smugmug.com/photos/26384537-M.jpg" border="0" alt="" /> <br />
    #13
  14. BoxHead
    BoxHead Adventurer
    Mar 22, 2006
    23
    Serpentine, Western Australia
    Where did you get those side frames for soft bags??
    #14
  15. brad21
    brad21 We have a pool... and a pond.
    Aug 3, 2006
    3,710
    Minden/Gardnerville, NV
    #15
  16. LC4nicator
    LC4nicator Certified Wino
    Jun 1, 2007
    551
    Adelaide, South Australia
    Not sure if you already know this but when IHad new tyres fitted last weekend I learnt that the locking nut on the valve stem should not be screwwed all the way down to the rim.
    This enables the tube to move and not shear the valve stem off.
    As for the clearance gap between Valve stem and rim, a bit of rubber hose on the stem pushed towards the rim closes this up and stops dirt/mud/water gettin into the rim.
    Cheers
    #16
  17. curbjumperjones
    curbjumperjones Compulsive Lane Changer
    Jun 19, 2006
    5,247
    Upper Canada
    Stopped in the middle of a water crossing to take a photo of the bike in the water for my kids- when I got back on I put my foot down- down, down, down... into empty space between two rocks.
    Filled up the airbox and engine with Pure Rocky Mountain Spring Water... :tb
    Which is fine if you're talking about beer... :dunno
    Exhaust header was full, muffler was full, cylinder full, crankcase contaminated- 3 and a half hours of work, alone in redneck country and during snack time for bears.
    I bought oil from a passing motorist- I was just off the Alberta Forestry Trunk Road.
    Luckily I had water bottles to drain the used oil into.
    Buttoned back up, hit the starter- and after 40 minutes of rough running I had my XRL back! :lol3
    #17
  18. tpunzy
    tpunzy liquid cooled
    Apr 1, 2006
    2,331
    Edgerton Wi
    not road side.............repaired it on the test track behind work
    Last road side repair I did was tues when my clutch cable snapped on the way home, ended up turning the engine clutch lever 180 and used my right foot to actuate the clutch to get home.
    #18
  19. PapaYolk
    PapaYolk happy camper
    Apr 10, 2006
    1,601
    Roswell Idaho
    Good Stuff
    #19
  20. K44rll
    K44rll Been here awhile
    Jul 1, 2007
    277
    Shropshire England
    Broken valve spring @ 11.15pm on a garage forecourt in Gent Belgium during a 800mile 4day 4 country Monkeybike ride...........had a spare head in the Givi topbox:D
    Back on the road 45mins later!!:clap
    Ride report/pictures/videos here www.myspace.com/cheapwayround
    Karl
    #20
