    Dismiss Notice
Rok Straps vs Mosko Backcountry Cinch vs Green Chile Mondo
Discussion in 'Equipment' started by Wveniez, Sep 19, 2020.
  1. Wveniez
    Wveniez Been here awhile
    Jun 30, 2020
    104
    Orlando, Florida
    Hey guys.
    Just picked up a Mosko Backcountry 30L and I’m looking for some opinions on the best straps to secure the bag to the bike.
    What do you guys think of Rok Straps vs Mosko Backcountry Cinch vs Green Chile Mondo straps?
    Is the metal cam mechanism a big benefit over plastic buckles? Does the elastic give a significant advantage over standard webbing?
    Thanks in advance for your input.
  2. brgsprint
    brgsprint Long timer Supporter
    Apr 26, 2012
    1,502
    Endicott, NY
    Never tried the others but I love the Roc Straps. I've never had a problem with plastic buckles on them. I like the elastic. they are strong enough to pull tight so they don't give. I would think the elastic would make up for and settling or slippage of the load. A metal cam would be good, but without elastic, I could see the load loosening.
    i'm curious to hear of experiences with the others.
    Melensdad likes this.
  3. Wveniez
    Jun 30, 2020
    104
    Orlando, Florida
    Yea that’s why I’m trying to compare the three options.
    Rok straps: Plastic buckles with elastic
    Mosko Backcountry: Metal cam with no elastic
    Green Chile: Metal cam with elastic
    I can see the argument for metal cams and no elastic in the name of durability, but I want to know what experiences others have had.
  4. abraham_lincoln
    abraham_lincoln Been here awhile
    Nov 10, 2019
    209
    USA
    Depends on how heavy of a load you're carrying. If I have a small dry bag stuffed with some extra thermal layers and a flannel and maybe snacks then anything with elastic seems to work fine.
    Anything that has some weight to it though can be a little bit more trouble, and in those instances I use ratchet straps. Ratchet straps are less convenient and take a little more time to load up, but they'll make your cargo completely secure and solid with the bike. For example my dry duffel bag packed with camping gear (~30lbs) will only be secured with ratchet straps.
    Blissed likes this.
  5. Emmett
    Emmett Been here awhile Supporter
    Mar 9, 2017
    472
    New Orleans
    Get anything with a metal buckle, plastic buckles break, and you don't need elastic, a duffel bag has enough give in it already.
    These people, they are in the US and will make whatever you want, and they make all sorts of things besides cam straps https://www.strapworks.com/default.asp
    You can also check out these folks https://www.rollercam.com/ -another US company, they claim to make a better strap based on their buckle design.
    If you want a locking strap that is cut resistant due to a steel cable running through it see these folks https://steelcore.com/
    Mosko recommends and sells Steelcore straps, but you may find dealing with Steelcore directly to be useful.
    Oldsport79, 9Realms and Sonny S. like this.
  6. engineman
    engineman Been here awhile Supporter
    Sep 26, 2012
    970
    Eastern Iowa
    I've got rok straps and the Green Chili straps. The GC ones are much beefier both in buckle and elastic. I like the rock straps but they are def lighter duty
    Glenn247 and Fosters like this.
  7. Ro0K
    Ro0K Adventurer
    Apr 20, 2013
    75
    Gainesville, GA
    +1 for the Green Chile Mondo straps.
    Had multiple Rok strap buckles break and got fed up with it.
    I have been ver happy with the Mondo straps durability and features. While i feel the elastic isn't required i appreciate the added capability it provides.
  8. radmann10
    radmann10 Derf Supporter
    Apr 29, 2014
    1,451
    Valley of the Sun/hot part of AZ
    Never had a Rok Strap buckle break, 7 + years of usage. They are my go to strap!
    #8
  9. LiquidSilver
    LiquidSilver Adventurer Supporter
    Nov 26, 2006
    66
    SW Washington
    I have several years of using Rokstraps on bikes with zero failures. I've used in all weather and with some heavy loads.
    The elastic makes all the difference! I Everything stays where I put it.
    They don't seem to break down under sunlight either. I have a couple straps that I used to fasten some steel weights on a tow-behind aereator. Surprisingly, they're still holding after sitting outside 24*7*365 for the last five years.
    Cheers!
    #9
    brgsprint and Sonny S. like this.
  10. mouthfulloflake
    mouthfulloflake Not afraid
    Aug 21, 2008
    32,716
    The Berkeley of Arkansas
    Elastic for SURE.
    and I use both Rok and Green Chili
    the green chili are MUCH beefier, I use them when I am for instance carrying a group 27 trolling motor battery for 40 miles on the back of my bike.. did that this morning.
    the rok straps are ok, for a case of beer, or a dry bag.
    The roks are breaking down faster in the sun ( fading on the buckles and straps)
    but that might only be a color difference thing.
    either will work, and work well, replace any of them after a couple of years out in the sun to be safe.
    Maybe you can see the difference in color from top of strap to bottom ( that never sees the sun)
    less than one year on this bike, out side 24/7/365
    #10
  11. Wveniez
    Jun 30, 2020
    104
    Orlando, Florida
    Great feedback everyone. I really appreciate it.
    Haven’t heard any feedback on the Mosko straps. Anyone have any experience with those?
    #11
  12. slow24
    slow24 Been here awhile Supporter
    Dec 26, 2004
    177
    Santa Barbara Ca
    I have them. They’re strong they’re sturdy. But for my use they are a little bit of an overkill! I’ll stick with my ROK straps. So far they have not let me down.
    #12
  13. MiteyF
    MiteyF Long timer
    Jul 23, 2010
    2,727
    Bay Area
    This is my useless post to tell you that of the 3, I've only used Rok Straps. But they're the shit, and I haven't found a reason to use anything else after 5+ years.
    #13
  14. NSFW
    NSFW basecamp4adv Super Supporter
    Feb 20, 2007
    25,439
    Burbank CA
    for many years, i'm a rok strap fan and even today.
    i bought the mosko straps which i thought, was heavier in weight. anyway, all my rok straps are gone and have to use the mosko. for 8 weeks or 12k miles, they never failed me. it is solid and i trust it so much that they will be the only strap i will use for securing a duffle bag containing valuable items. the loaded bag has enough give that it never loosened up. not so much for an empty bag.
    my rok straps are about 3 years old but 2 of them i broke the plastic buckle. one got stepped on and the other i pulled it out through a hole that's too small. i will still buy replacement rok straps and at the same time will never give up the mosko straps.
    #14
  15. WADE-O
    WADE-O Been here awhile
    Jun 18, 2011
    788
    SAN DIEGO, CA
    i also really like that the Mosko straps can be used as tow straps in an emergency. If going for a day ride i use them to tie down my tool roll which is way overkill but i used them in case i need them as tow straps. i also like that since the get pulled tight from two different directions you can really adjust where the bite point of the strap is vice the others. I also have green chili straps that are bullet proof that.
    #15
  16. Shaolin
    Shaolin Been here awhile
    Dec 9, 2013
    384
    While I love my Rokstraps, I did have an issue with 2 sets I bought from different places, Cycle Gear and Cross Country BMW. I bought the same kind/size from each place. Had I kept them distinct from each other, they worked perfectly. But I mixed them up and for some reason, they wouldn't release at the buckle. Who was selling the fake Rokstraps? Who knows. Ended up destroying the Cross Country BMW set because the buckle with the release buttons wouldn't function. I can still use the Cycle Gear set.
    #16
  17. MiteyF
    MiteyF Long timer
    Jul 23, 2010
    2,727
    Bay Area
    They could have very easily just switched suppliers for buckles. It's always best to keep straps like that as sets for that very reason.
    #17
  18. Xsv
    Xsv Going nowhere, fast Supporter
    Sep 11, 2017
    1,401
    Spokane, Washington
    I am using the mosko moto cinch straps on my MM40. They are solid and it’s nice to be able to center the strap with the 2 cam buckles.
    I use their basic cinch straps for holding soft sided cooler (along with 2 rok straps).
    I copied their basic cinch strap design and use them to secure my pannier top bags.
    I don’t think I’d be using rok straps for my duffle.
    #18
  19. Pch123
    Pch123 Bar Crossings
    Dec 19, 2012
    1,547
    East Coast Australia
    ROK straps
    #19
  20. PNWet
    PNWet Long timer
    Nov 2, 2014
    1,181
    Puget Sound, WA, USA
    I prefer GCAG straps. I've also used Rok Straps, and they're good too. Just not as stout. The Mosko straps are on par with GCAG (in terms of ruggedness), though they have no elastic. I've found straps will loosen some as soft bag contents shift. Elastic takes up this slack, buying some time until things get too loose. Thus, I prefer GCAG or Rok over Mosko.
    Whichever you use, secure the excess. I like to use a short chunk of paracord and a Canadian Jam Knot to wrap around the excess.
    #20
