romancing the SHREK
Discussion in 'Americas' started by oneway, Dec 31, 2013.
  1. Chad05gsa
    Chad05gsa Been here awhile
    Feb 4, 2012
    218
    Ithaca ny
    Did you ever have a look at Photobucket? I've never used smugmugg but in Photobucket you just copy the link and paste. Might be a little less technical then smugmugg idk?
    samsung galaxy note 2
  2. oneway
    oneway Tehachapi CA
    May 2, 2008
    4,582
    Tehachapi, CA when I'm home
    My understanding is that the smugmug creator sponsors this forum, so I want to support him.
  3. oneway
    oneway Tehachapi CA
    May 2, 2008
    4,582
    and I just tried copying a link from embeddable video on smugmug, I selected the small choice, and tested it elsewhere. still no luck. I can play the video in smugmug with no problem so I know it's there and working.
  4. renogeorge
    renogeorge Let's ride!! Supporter
    Apr 7, 2007
    6,923
    Reno
    An indication that you should be going to Mexico and spending less time on the computer.
  5. ian408
    ian408 Administrator Administrator Super Moderator
    Apr 12, 2003
    65,832
    Santa Clara, CA
    Can you post a link to the gallery it's in?
    First though, make sure the gallery is public and viewable by others.
  6. oneway
    oneway Tehachapi CA
    May 2, 2008
    4,582
    here's what I have learned: if you click on the photo posted above it does not play directly, but it will link to my smugmug video and play from that page.
  7. oneway
    oneway Tehachapi CA
    May 2, 2008
    4,582
    George your killin me !!
  8. oneway
    oneway Tehachapi CA
    May 2, 2008
    4,582
    " First though, make sure the gallery is public and viewable by others"
    all I can figure out right now is this:
    I went to my smugmug account, under privacy... turned family view on, and friends view on. I don't see anything under privacy that allows public sharing specifically.
  9. ian408
    Apr 12, 2003
    65,832
    Santa Clara, CA
    Here's the help section for Gallery Settings.
  10. oneway
    oneway Tehachapi CA
    May 2, 2008
    4,582
    first, thanks for the help.
    I went into the gallery settings, under security & privacy, and verified that public view was on. so I'm still lost. but I can post pics, and I follow the same protocol for the video embedding.
    guess it's something else
  11. oneway
    oneway Tehachapi CA
    May 2, 2008
    4,582
    Man I have been seriously screwing off!!
    I'm doing more in preparation for Alaska now so I'm gonna try resurrecting this thread with Tapatalk in case someone else with a gen 1 can benefit.
    I had these laying around. 1" supplemental filtered air inlet from uni.
  12. oneway
    oneway Tehachapi CA
    May 2, 2008
    4,582
    Layed out so you can see both sides. They just snap in after cutting a 1" hole. Just have to figure out my spacing...
  13. oneway
    oneway Tehachapi CA
    May 2, 2008
    4,582
    Maybe 3 here in the air box door.
  14. oneway
    oneway Tehachapi CA
    May 2, 2008
    4,582
    Looks ok
  15. oneway
    oneway Tehachapi CA
    May 2, 2008
    4,582
    3 in the top of the air box
  16. oneway
    oneway Tehachapi CA
    May 2, 2008
    4,582
    I made sure to vacuum up all the shavings and de-burr the holes before fitting them in.
  17. oneway
    oneway Tehachapi CA
    May 2, 2008
    4,582
    There it is....six 1" filtered air inlets.
  18. oneway
    oneway Tehachapi CA
    May 2, 2008
    4,582
    Here is where the clutch bypass switch ended up. Just enough room to install on the plastic shroud that covers the wiring below the tach/speedo pod.
  19. oneway
    oneway Tehachapi CA
    May 2, 2008
    4,582
    Today's project was to run a secondary set of throttle cables, heat shrink tubing on the ends and tie them in place
  20. oneway
    oneway Tehachapi CA
    May 2, 2008
    4,582
