romancing the SHREK
Discussion in 'Americas' started by oneway, Dec 31, 2013.
  1. oneway
    oneway Tehachapi CA
    May 2, 2008
    4,582
    Tehachapi, CA when I'm home
  2. oneway
    oneway Tehachapi CA
    May 2, 2008
    4,582
    They really seal up nicely
  3. oneway
    oneway Tehachapi CA
    May 2, 2008
    4,582
    All tidied up and zip tied
  4. oneway
    oneway Tehachapi CA
    May 2, 2008
    4,582
    Every electrical connection I can get to on the bike gets a shot of this.
  5. oneway
    oneway Tehachapi CA
    May 2, 2008
    4,582
  6. oneway
    oneway Tehachapi CA
    May 2, 2008
    4,582
    Like so...
  7. oneway
    oneway Tehachapi CA
    May 2, 2008
    4,582
    I've tried to figure where to mount my Denali Lights for awhile.....then I came across this bracket online
  8. oneway
    oneway Tehachapi CA
    May 2, 2008
    4,582
    It's a close fit under the fairing. I had to drill the holes out to 5/16
  9. oneway
    oneway Tehachapi CA
    May 2, 2008
    4,582
    Tucks up pretty nicely
  10. oneway
    oneway Tehachapi CA
    May 2, 2008
    4,582
    Denali DM led driving lights
    These are low draw 3/4 amp single intensity.
    They come with a 10 degree optic installed, and a 25 degree optic if you want to change.
    240 feet beam distance and 50,000 hours life span. Submersible to 3 meters.
  11. oneway
    oneway Tehachapi CA
    May 2, 2008
    4,582
    And they are small
  12. oneway
    oneway Tehachapi CA
    May 2, 2008
    4,582
    I can wire them to the high beam or wire them independent. I'm thinking I'll go independent. Here they are lit up for initial testing. I still have to wire them to the Denali fuse block I bought.
    When that's done maybe some more night testing trying to duplicate my previous methods for comparison.
  13. oneway
    oneway Tehachapi CA
    May 2, 2008
    4,582
    Time to replace the old fuses
  14. oneway
    oneway Tehachapi CA
    May 2, 2008
    4,582
    With this plug & play mini fuse harness
  15. oneway
    oneway Tehachapi CA
    May 2, 2008
    4,582
    This fan switch fuse gets cut out
  16. oneway
    oneway Tehachapi CA
    May 2, 2008
    4,582
    The old fuse holder is out and the new one replaces it.
  17. oneway
    oneway Tehachapi CA
    May 2, 2008
    4,582
    Shrink wrap on the Posi-Tap just because I can....I guess.
  18. oneway
    oneway Tehachapi CA
    May 2, 2008
    4,582
    I need to put in the fuse block. I called Twisted Throttle and they said to put it where ever I can shoehorn it in. I wanted somewhere near the fairing....so...
  19. oneway
    oneway Tehachapi CA
    May 2, 2008
    4,582
    I drilled a hole in this cover behind the headlight....
  20. oneway
    oneway Tehachapi CA
    May 2, 2008
    4,582
    Temporarily mounted with self taping screws here
