Rotary LED Light Dimmer
Discussion in 'Vendors' started by sanjoh, May 31, 2012.
  1. sanjoh
    sanjoh Purveyor of Light
    Feb 13, 2007
    7,990
    ADVmonster
    Just released!
    More information available here.
  2. GsVs
    GsVs Goin' Somewhere
    Dec 30, 2002
    1,783
    Hoosier (IN) USA
    I've been waiting on these .... just ordered two ...
    Do I get a bonus for being the first to order :D .... just kidding ..
    Thanks ...
  3. Jazz62
    Jazz62 Long timer
    Oct 5, 2009
    1,889
    PNW
    Does this have a left detent click for on/off?
  4. sanjoh
    Feb 13, 2007
    7,990
    ADVmonster
    Thanks, you were in the first 10 to purchase, will send some nice reflective stickers:D with your order.
    It has a detent for on/off. Not sure what you mean by left:ear
  5. Jazz62
    Jazz62 Long timer
    Oct 5, 2009
    1,889
    PNW
    Sorry, I meant the detent click for the off position is in the counter clockwise direction?
  6. sanjoh
    Feb 13, 2007
    7,990
    ADVmonster
    Yes, counter clockwise reduces the light output until it reaches off with a detent.
  7. sanjoh
    Feb 13, 2007
    7,990
    ADVmonster
    Fits nicely behind the brake resevoir.
    Another angle
    Easy to reach with a thumb. I don't recommend adjusting while underway:D
  8. Yellow Pig
    Yellow Pig Allergic to asphalt! Supporter
    Oct 28, 2004
    9,269
    SoCal -T.O.
    Fantastic, and it even has a High Beam by-pass.
    Great work.
    Can it be panel Mounted?
    INFO:
    Rotary control of led output.
    Dimming is accomplished by PWM.
    Rotoray detent in off position.
    Connect your high beam to provide full light output when you turn on the high beams.
    Includes connectors male/female for 2 lights.
    Includes connector for 12v DC power (male and female).
    1.5"x1.3"x.8" or 38mmx33mmx20.3mm
    IP67 waterproof
    Suitable for up to 6 amps or 72 watts.
    #8
  9. FL Pepper
    FL Pepper OMGWTFFTW
    Jul 3, 2008
    1,714
    Central Ridge
    I mounted mine to an existing bracket that I already had on my handlebars.
    It is controlling a set of Model 30s that are mounted on both sides of my headlight. It's across from my wireless dimmer fob that controls a set of Model 60s.
    Here are the input and output connections from the unit. 1 male JST plug and 2 female JST receptacles and the high beam bypass wire.
    I pigtailed one of my outputs to run an extra output from the dimmer because I also have the LED indicators on my instrument cluster.
    LED panel mount indicators mounted on my instrument panel.
    #9
  10. sanjoh
    Feb 13, 2007
    7,990
    ADVmonster
    Panel mounted as in hole through the panel then bolted. No, it is designed to be surface mounted.
    #10
  11. sanjoh
    Feb 13, 2007
    7,990
    ADVmonster
    How did you attach it to the bracket?
    #11
  12. FL Pepper
    FL Pepper OMGWTFFTW
    Jul 3, 2008
    1,714
    Central Ridge
    It is attached with RTV. That and my voltmeter are held on with RTV and I have had no issues with them staying put.
    #12
  13. See red
    See red Been here awhile
    Nov 7, 2010
    167
    Do I need to use the high beam wire? I will only be using these on the back roads.
    #13
  14. sanjoh
    Feb 13, 2007
    7,990
    ADVmonster
    It's not required. The high beam bypass only uses the high beam signal to trip a relay, no substantial power is used but you will be missing out on a great feature. On the back roads is where it will come in handy, a car or tractor once in a while and you just flick your high beam switch to go to the dimmed setting, pass em by and flick the high beams on for full LED light output.
    #14
  15. sanjoh
    Feb 13, 2007
    7,990
    ADVmonster
    So you spent the big bucks for that awesome LED off road light only to find out that its too bright for the road or it kills your battery when riding the tight stuff!
    The Rotary LED controller will tame the beast and give you full control over light output. Get the amount of light you want, when you want.
    No FOB to lose:D
    Waterproof
    Gloved hand friendly
    Small size 1.5"x1.3"x.8" or 38mmx33mmx20.3mm
    #15
