ROTTWEILER intake
Discussion in 'Parallel World (790/890)' started by Nowwhat, Nov 17, 2020.
  1. David_Moen
    David_Moen Long timer Supporter
    Apr 23, 2006
    2,148
    Salmon Arm, B.C. Canada Eh!
    Thanks, what's the racket level like with the Wings slip on? Hopefully not too obnoxious.
  2. markgrolex
    markgrolex Been here awhile
    Jul 23, 2017
    514
    West Grove PA
    all I know is the sound in the garage haha -it sounds only slightly louder. I have not ridden it yet -nothing but bad weather since i bought the bike last month.
    I had one on my 1290 R and loved it--looks good, lighter, and had a deeper sound but not too loud at all.
    You'll be pleased -its not too loud
    David_Moen likes this.
  3. SoilSampleDave
    SoilSampleDave Dr. Zaius was right!
    Jan 21, 2005
    11,462
    The Delta Ghetto, GA (aka PTC)
    braaap! and TrailTrauma like this.
  4. David_Moen
    Apr 23, 2006
    2,148
    That's what I'm hoping for!
  5. AdvDna
    AdvDna Adventurer
    May 25, 2017
    60
    Calgary
    I soaked mine in almost boiling water and they went in like..... well you know!
    drrod1, markgrolex and TrailTrauma like this.
  6. OrangeDesert
    OrangeDesert Adventurer
    Jan 3, 2021
    15
    Dubai - UAE
    Decat done, Rapidbike Evo done, waiting for the Rotty intake...
    TrailTrauma likes this.
  7. kirill_k
    kirill_k Adventurer
    Aug 9, 2013
    86
    Moscow
    Hi everybody,
    I've never used foam filters on anything except mx bikes, where we had them serviced after every trackday. So I wonder how ofter is the owner supposed to clean and oil RWP's foam in case he uses it when ordinary commuting?
  8. kubcat
    kubcat Riding is Eudaemonic Supporter
    Sep 22, 2016
    2,527
    Upstate NY
    Just take a look at it every now and then and use common sense and judgement. If its really dirty, clean it. If you're going on an offroad adventure, clean it first and bring an oiled spare. If its just a bit dirty and you're street riding then ride on.
  9. TrailTrauma
    TrailTrauma Nemophilist Supporter
    Jan 17, 2012
    6,867
    Planet Fucking Earth
    @kirill_k , RWP offers choices at checkout/product selection - You can add the pre-filters which are a great idea for anyone, and extra filters. I chose to order a pre-oil'd filter so I'd have time to research and source a good biodegradable oil. If you buy the pre-filters (3-pack) then just pull that off and clean it, replace it with a dry clean one, and continue. Commuting shouldn't be bad.
    OrangeDesert, BHoward and kirill_k like this.
  10. Olaf972
    Olaf972 Pirate of the Carribean
    Oct 9, 2020
    47
    French West Indies
    I've never used foam filters too, so when you only drive on road for a moment at normal conditions, you don't need to use an oiled filter ?
    I ordered both...and they arrive tomorrow :clap
  11. kubcat
    Sep 22, 2016
    2,527
    Upstate NY
    foam filters need to be oiled in order to correctly filter the intake air, no matter how or where you are riding. the conditions you ride in only determine how quickly the oil will saturate with dirt and therefore how often you must clean or replace them.
    kirill_k and Olaf972 like this.
  12. DCGH
    DCGH Been here awhile Supporter
    Nov 30, 2020
    150
    Salmon Arm, BC
    I think the pre-filters Rotty sell are more like a filter sock that fits over the normal filter, this lengthens the amount of time needed between cleaning of the main filter...in my experience (mainly racing I have to admit) I would always oil the main filter...there are spray on filter oils (K&N make a good one) that stop the process being too messy...that's how I understand it anyways..open to correction as always though :lol3
  13. Olaf972
    Oct 9, 2020
    47
    French West Indies
    OK thanks, that's what I thought
  14. markgrolex
    Jul 23, 2017
    514
    West Grove PA
    Ill add my 2 cents since I have used foam filters on KTM dirt bikes for many years.
    I have used No toil oil and cleaner with excellent results -NO DIRT behind filter even after very dusty rides -I like and trust it.
    Its super easy to use. I clean the filter in home wash tub with hot water and no toil powdered cleaner- rinse it right down the drain.
    Let filter air dry completely and then oil the foam and really work it in and gently squeeze out any excess- you dont need to over oil it but make sure it totally oiled.
    No need to squeeze or ring foam filters too hard either-- it can hurt them. Let it sit out for a good 15 minutes so the alcohol in oil evaporates and THEN install filter. I used a thin coating of filter grease on the rim where it contacts the airbox but in looking at how big and good the surface area of contact is on the RP filter dont think Ill need rim grease unless I knew I was riding in a dust storm. Also filter skins over top are not bad idea in off road. Prob not needed at all for street or light off road.
    There are lots of good bio oils and cleaners ( ones that work with hot water ) easy to clean and tons of great conventional filter oils/ cleaners like Bel Ray etc. But they need solvents to clean, and then you have left over dirty solvent to dispose of. As for how often just look at it and its getting dirty clean it. Its better to do it too often than not!
    and always after a dirt ride if its dusty. Street rides -you can wait until it visibility looks dirty but if its been a while-- like a few months a clean and re oil won't hurt.
    braaap!, kirill_k and sims159914 like this.
  15. David_Moen
    Apr 23, 2006
    2,148
    +1 on NoToil. I've used with great results on a string of dirt bikes going back at least 15 years.
    braaap! likes this.
  16. SoilSampleDave
    Jan 21, 2005
    11,462
    Has anyone found an affordable US dealer for Rock Oil bio oil?
  17. braaap!
    braaap! Long timer Supporter
    Mar 16, 2005
    5,498
    Melbourne - AU
    We can't get Rock Oil Bio down here either! Local importer / distributor claims C19 has foobared their supply chain... :dirtdog
    Wanted to compare it with my goto filter oil - No Toil.
    I've been using it for years and as others have said, like the fact that it requires no harsh solvents to clean a filter plus the new aerosol cans eliminate a lot of the mess. Been using a large cardboard box as a spray booth.
  18. DCGH
    Nov 30, 2020
    150
    Salmon Arm, BC
    Where do you get the stuff from Dave?
  19. David_Moen
    Apr 23, 2006
    2,148
    Shuswap Xtreme. I love the fact that you can clean the filters up in the laundry tub and because you aren't using solvents or gas, you can wash, re-wash and rinse until they are super clean.
    DCGH likes this.
  20. squid61
    squid61 Adventurer Supporter
    Oct 23, 2015
    73
    Alberta
    Pegasusautoracing.com
    Dan D. and SoilSampleDave like this.
