ROX Riser Install Pictorial (2 sets plus cable/line relocation)
Discussion in 'GS Boxers' started by JimVonBaden, Apr 30, 2017.
  1. tactical1
    tactical1 Been here awhile Supporter
    Aug 19, 2012
    143
    Lexington, SC
    Wouldn't worry too much about the warranty implications as only items at risk would be those modified ie: cables and lines - don't think you can properly install the risers w/o relocating the cables and lines though so I would install the risers and reroute the cabling as needed and not look back
    #41
    Roundel and JimVonBaden like this.
  2. Roundel
    Roundel Been here awhile
    Jul 31, 2012
    149
    Chicagoland
    Good and smart people on this forum. Thank you!
    #42
  3. gregp
    gregp Been here awhile
    Jun 19, 2008
    319
    Alaska
    Any luck finding the thread you mentioned?
    #43
  4. JimVonBaden
    Feb 11, 2005
    88,045
    Alexandria, VA
    #44
    Mr. Clean likes this.
  5. slowfall
    slowfall Been here awhile
    Feb 4, 2014
    144
    Yes. I have an opinion: If you ride more comfortably with bar-risers, install bar-risers. If you you are very comfortable without them, do not install them. If you are not comfortable riding the bike without bar-risers and keeping up the warranty is more important to you than enjoying your ride, do not add bar-risers. If maintaining the warranty on a bike is what you crave, go for it.
    Personally, I like riding my bike and using it to its fullest extent. As an example, I am a tall person and the bar-risers allow me to stand on the pegs comfortably while keeping my arms and hands relaxed for optimal handling of the controls while riding in dirt, sand and over rocks. With the adjustable risers, I can quickly adjust the handlebars to street riding position as needed, to optimize for that.
    As an example, when I am riding in 5 inch deep sand at 60 miles an hour, I prefer the optimal setup that suits me. The reason is that any poor clutch, throttle or brake input has the potential of flipping the bike and destroying it. No warranty will be coming to the bike's or my rescue.
    So weighing the risks and benefits, for the riding I do, optimization of the ergonomics is paramount as well as cheaper and safer than worrying about the warranty.
    I hope that helps.
    Sent from my iPad using Tapatalk
    #45
    Roundel likes this.
  6. KHud
    KHud Survivor Supporter
    Jun 24, 2008
    4,649
    Big Sky Country
    I installed the 2" Rox risers yesterday. In the instructions provided with the risers they specify 18 ft/lbs for the cap bolts. That is a huge error from the actual 19Nm that you and the Haynes Manual provide. Glad I read this thread before my install.
    I also found that zip tieing the cables to the point recommended in the instructions (small "tic-tac" (oval) shaped opening) seems to put some stress on the cables. I did it, but was tempted to not zip tie them at all. It looks to me like leaving them unattached would work okay.
    #46
  7. BladeRun
    BladeRun Daywalker finally!
    Jul 5, 2009
    84
    Massachusetts
    Just got finished installing the pivoting set of Rox Risers on my '04 1150 GS. After installing the risers I noticed the brake line had some tension and needed to be re-routed. I am NOT very handy so this procedure was causing me to sweat. After reading and re-re-reading your post Jim, I went ahead and did it....success! It was very easy, I just followed the pictures. haha. The cables are fine now and my heart rate has returned to normal. A big thanks to you Jim!!!
    #47
    JimVonBaden likes this.
  8. ryno23nv
    ryno23nv Been here awhile
    Apr 28, 2017
    145
    Northern Nevada
    I thought ziptieingbthem in recommend spot put steas on the cables too. I left the free.
    #48
  9. sykospain
    sykospain Been here awhile Supporter
    Jul 18, 2014
    153
    south-eastern Med coast of Spain
    What fantastic fotos Jim ! And a really great write-up.
    Trouble is, to fit risers of any kind to a bike like mine, yr-04 Rockster, new braids are required for each side, 'cos the OEM ones are so tight in view of that stupid straight bar. Switching to a Roadster bar for greater wrist-comfort involves a deal of re-routing for the same reason.
    #49
  10. ATCguy
    ATCguy Been here awhile
    May 22, 2010
    513
    Arizona for the winter...
    Thanks, Jim, for your excellent pictorial write-up of the cable relocation & install process. Just did mine this morning with a set of the 2" anti-vibe risers. Using your notes, took about 45 minutes total, and that was with me taking my time. :)
    #50
