O.k. so there's like boat loads of posts in the Royal Enfield Himalayan thread and the Royal Enfield Himalayan Owners thread. Time to list the hacks chops tips and mods. The list is going to get lots of changes and updates and morph and re arranges as time goes on. There's plenty to list and gathering it all is time consuming so please be patient. If you've done it or have something to add chime in, your input is valuable and folks want to know. If you're reading this want to help build or maintain it let me know. List of faster sizes and the tools to fit them ! #5951 Oil & filter change https://motohimalayan.wordpress.com/2018/10/11/vidange-moteur/ Valve check and adjustment #3567 and https://motohimalayan.wordpress.com/2018/04/10/296/ Idle speed adjustment https://motohimalayan.wordpress.com/2018/05/16/reglage-du-regime-de-ralenti/ Brakes & Pads https://motohimalayan.wordpress.com/2018/08/31/un-frein-avant-plus-puissant/ Replace your headlight bulb #4712 and #4713 How to re torque if an oil seep develops at the head https://motohimalayan.wordpress.com/2018/11/28/fuite-au-joint-de-culasse/ Re route your carb vent line to cure a stutter at high speeds or in strong head winds #4868 Cut down your windshield #5739 #5740 Bend your mirror arms to improve the view #5421 Super sick skid plate #5555 Chain Oilers - and https://motohimalayan.wordpress.com/2018/07/08/montage-dun-graisseur-de-chaine-tutoro/ License plate and light relocation mod #4470 Under seat storage insert hack #1974 Adding a powered accessory relay #3849 An ignition switched relay controlled aux power system with SAE and BMW ports #6188 Relocating the Ambient Temperature Sensor for more accurate readings mod #1518 and from France https://motohimalayan.wordpress.com/2018/03/02/mais-ou-est-la-sonde-de-temperature/ 12V Aux power outlets https://motohimalayan.wordpress.com/2018/10/28/montage-dune-prise-allume-cigare/ USB charger Heated grips #4260 Conspicuity lights https://motohimalayan.wordpress.com/2018/03/18/montage-de-feux-de-jour-a-leds/ Aux lights Aux tank Gas cans & mounting http://www.royalenfieldlesite.fr/spip/spip.php?article621 Pannier pucks for DIY & universal fit pannier mounting #4496 DIY soft luggage plates ( now with instructions ) #1 Probably the slickest tail rack to date #6180 Matching street duty side racks #6181 Cheap & easy ammo cans directly mounted #4487 Adjust muffler to tuck it in under pannier racks with aftermarket panniers #4676 This also shows the DIY pannier attachment hardware. DIY throttle tube cam Fuel transfer hose #3039 Turn signal beeper Four way flasher brake light flasher ABS on/off switch #3001 Headlight switch Fix a busted fuel pump connection #4621 thru #4627 Adjustable suspension links #5772 Grease your lower suspension linkage pivots Install grease fittings in your lower suspension linkage pivots The end of buttsweat - mesh seat over cover ( hijacked from another thread and way cool ) #1
Not everyone and yes. You'll find more talk on those questions in the Royal Enfield Himalayan and Royal Enfield Himalayan Owners Thread than you will in this one.
How about putting links to general technical procedures in this thread too, like oil change or valve clearance settings, etc.?
How to adjust muffler to tuck it in under the pannier racks, Post #4676 This also shows the DIY pannier attachment hardware.
We sell the Lextex cans. Great value & sound. https://www.lextekproducts.com/exhausts/silencers/for/ROYAL ENFIELD/HIMALAYAN 410/2018
If this stubby fits "under" the pannier it would solve the problem that I had, https://www.lextekproducts.com/XP10/for/ROYAL+ENFIELD/HIMALAYAN+410/2018#prettyPhoto I had to adjust the factory exhaust to tuck in behind the pannier. It works but it limited my pannier option to the medium size, because of where the bottom of the pannier lands with respect to the muffler. I have 1/4" clearance where they "intersect".
