that teensy looks like it could guide the re-usable rocketry of spacex so "simple code", I dont know. I am a bit disappointed it does not have a GPS receiver onboard or else we could emulate the stuff they put on the Meteor and I always wanted an altimeter, either by air pressure or by gps. that "rolling display" thingy would be such a cool toy to put on the Himma .... who else is interested ? (You'd have to put it into the console yourself though! selling an updated complete console is way too expensive)
You can when you are stuck in traffic on a hot day, which is when I would want to use it on an air cooled motorcycle.
Single LED Voltage Monitors - Gammatronix (gammatronixltd.com) These indicate immediately a problem starts in the charging system and give you a chance to stop and find out what the problem is - have them on all my bikes and have been saved a few disasters!
Went ahead and bought this. Wherever it goes, my hobby lathe and I will make it smaller! Update on my temp sensor relocation. Much better and only about 1.5 degrees over. A chilly 2.3 Celsius this morning outside London.
Nice crisp spring day here, 30C when I left, quickly rose to 40 C so cut the run short, grabbed a quick double shot expresso and was home before it was much more than 44C. I have a temp gauge on my tire pressure monitor, reads within a degree of the on board one so I won't be relocating my sensor. And on a day like today when the tires were out in the sun before I left the pressures actually went down when they got out in the cooling breeze. Mind you I run 35/37so the don't usually rise more than a pound or two.
Without getting too 'Zen and the Art of Motorcycle Maintenance', I draw the line at gadgets such as TPMS's, but the fact of the matter is that I don't really get out much on my Himalayan. I have engine bars, hand guards, auxiliary spotlights, heated grips and a twin USB socket. I'm lucky if I get to exceed 45 mph commuting to work and back! The voltmeter idea spiked my interest, because as others have suggested, the Hima's compass would be more useful inside a Christmas cracker.
Well, had a nice day yesterday pulling apart the steering stem. I was having what felt like forks bottoming out very easily both on and off road. And the apparently ubiquitous loosening of the top nut of the steering stem. Pulled it all apart, cleaned checked and greased the bearings (all seems fine...only 2700 miles...but hearing lots about failures first 5k so wanted to look). Re Assembly and tightened to recommended "tighten till to feel a little friction turning while tipped back on center stand, then back off a little." Results were immediate. I'm betting that the main nut under the triple tree was loose and the bearings were un seating a bit over bumps. Hopefully on the dirt tomorrow to verify. Thanks for all the knowledge here.
True. You'd have to get innovative with the use of the other segments. Maybe use the "clock hand" position of the direction arrow for 12V, 13V, 14V, etc. It's a moot point anyway, because I can't see anyone going to the effort required, for so little reward...
Thinking of dumping my Satnav and using Maps on my new to me Samsung S8. This is the first smartphone I've ever used, my usual Nokia is over 20 years old and has served me well. My son gave me this S8 after what must be about 5 years of sitting in a draw. My tech is always up to date. Back to the subject, where and how have you mounted your phones. Pictures please.
For standing voltage/percent charged, the difference between 100% charged and only 60% charged is 12.7 to 12.2 volts. So, you need at least 3 characters and a separator. BTW, here is my Christmas cracker compass. Even less accurate than the Hima. It actually points to the metal keyring that it came with.
Built mine out of RAM mount parts that clamp to the handlebars. I have shown the X-Grip only in the pics. The rubber sheet pulls up around the phone corners as an extra restraint.
But if it drops as low as 9V or gets as high as 20V you will know all about it, so you could really drop the 1. 22 means 12.2V 27 is 12.7V 34 is 13.4V.
True, if you know the code. A dead battery is 10.5v or less, so could be 05. Under charge, it would be 37 to 47.
I have mine lower on the Hima. The ball is clamped on the handlebar next to the handlebar clamps. I have a variety of RAM extensions of different lengths. But if it is a phone, I would want to keep it low behind the windscreen for protection from the elements.
Some of us might consider having the correct pressure in our tires a vital safety measure, and something which helps us to maintain that is worth having. Others might prefer a twin USB, presumably to power gadgets which keep them connected to the social media, but in this state "driver inattention" has overtaken speeding as the prime cause of accidents, so some might question this approach. In sixty years / 1,350,000 km of bike riding I have had five punctures and never had an off I haven't ridden home from, so I think my attention to detail has been worth it. And despite being in my 75th year and usually having three bikes road legal at any time I have still managed to put 25,000 km on the Hima in little over a year - helps that my usual coffee runs are more than a 200 km round trip, of course, and that we have a 52 week riding season. And my TPM is solar powered, IMHO the entire electrical system on the Hima is underspecified and I have no intention of adding any load to it in any way!
Some of us might like to follow our GPS or reinflate our tyres by the side of the road. Social media whilst riding a motorcycle? Whatever next!
