Royal Enfield Himalayan Owners Thread
Discussion in 'Thumpers' started by Anthiron, Sep 2, 2017.
  1. Doctor T
    Doctor T Gruppy old git
    Apr 2, 2019
    1,525
    Sussex UK
    Probably similar to older models but easier as the switch is already fitted. No wires have to be run to the handlebars. A JCW64 said but you may only need to fit small jumper wires to the Orange wire. Really need to see a wiring diagram first.
  2. ScottFree
    ScottFree Long timer
    Jun 7, 2011
    1,192
    Ill-Annoy
    I think it's a 4mm. I just use a #0 square-head deck screw with a 90º bend in it.
    Hitchcocks sells a nice English-made adjuster tool (wrench to turn the locknut with concentric socket to hold the adjuster) for what I think is a rather excessive amount of money. Motion Pro sells an equally functional tool that is quite a bit cheaper in the USA (through Revzilla, etc.). I suspect it's actually made in Taiwan, Korea or China, so it might be cheaper/more readily available where you are ("thl" is Thailand, I assume).
    dcoop and Kiwithl like this.
  3. ScottFree
    Jun 7, 2011
    1,192
    Ill-Annoy
    Wait... yours has an ABS on/off switch? According to YouTube, you should be able to turn off rear ABS by holding that switch (down next to the fuel gauge) for 10-15 seconds, until the ABS light flashes three times. I notice that while the video (at least the clip google found for me) doesn't say this explicitly, the guy had the ignition (key) on but the engine was not running at the time. That may be intentional--my '06 GS had an ABS on/off switch that required you to hold the switch on while turning on the ignition. Some safetycrats seem to think you should not be able to turn ABS on/off on the fly.
    I am probably going to make a stop by Randy's Cycles (my RE dealer) today, and if I remember I'll ask him. Or just play with one of the 2021 bikes on the floor. He leaves the keys in them...
  4. AlbySA
    AlbySA Adventurer
    Jan 14, 2020
    72
    Flagstaff Hill, South Australia
    I checked the battery 12.8 volts. I'll do some more testing tomorrow and let you know.
  5. peow42
    peow42 n00b
    May 1, 2021
    4
    Illinois
    Hi all. Just joined up. I did my first valve adjustment on my 2021 Himalayan. Triple checked clearances. Put it all back together and the bike will not idle at all. If I peg the throttle at 1.5k RPM+ it will stay alive. Engine doesn't sound any different, but it ran just fine prior to the valve adjustment. As far as I can tell, no hoses are loose, and everything is hooked back up. Can anyone help point me in the right direction?
  6. johnny42
    johnny42 Been here awhile
    Sep 11, 2018
    253
    New York
    Double check all the hoses and lines. If you adjusted the valves properly, that should not affect idling, but the if the hoses and lines are not correct, it could. Double check.
    Doctor T, peow42 and Eatmore Mudd like this.
  7. peow42
    peow42 n00b
    May 1, 2021
    4
    Illinois
    After triple checking the hoses, the overfill drain hose(one without the clamp) just goes in front of the air box and between the swingarm spindle. I see no connection for it, so I presume it is just a vent. Otherwise everything appears normal.
  8. Dool
    Dool Been here awhile Supporter
    Jan 9, 2021
    978
    Australia
    Did you set the Valve clearances on the Compression Stroke ? did they need Much adjustment or did you only Check.
    EFI or Carby
  9. peow42
    peow42 n00b
    May 1, 2021
    4
    Illinois
    Clearances on compression stroke, did confirm TDC. They were a little tight, so I loosened them up slightly. EFI.
  10. Dool
    Jan 9, 2021
    978
    Australia
    TDC by looking through the inspection Plug Hole. left hand front case ?
  11. CarstenB
    CarstenB Been here awhile
    Jun 9, 2015
    635
    NL
    it's 3mm. A Robertson (square drive) screw head will fit and is all you really need.
    Eatmore Mudd likes this.
  12. CarstenB
    Jun 9, 2015
    635
    NL
    the 2021 has a factory ABS switch button in the dash. No need to wire anything. Screenshot 2021-05-01 19.06.36.png
    Eatmore Mudd, sqeeezy and Dool like this.
  13. drdubb
    drdubb OFWG Supporter
    Dec 13, 2009
    2,437
    Durham, North Carolina
    The vent hose may be pinched under the tank.
  14. Doctor T
    Apr 2, 2019
    1,525
    Sussex UK
    I think he meant front. You have to forgive him at times as he is a bit old.:imaposer
  15. bomber60015
    bomber60015 Hold fast Supporter
    Sep 11, 2008
    80,675
    Chicago-ish
    I finally got it to work ... that button REALLY doesn’t want to be pushed ....
    Eatmore Mudd and Doctor T like this.
  16. drdubb
    Dec 13, 2009
    2,437
    Mounted a 14T sprocket and DID chain today. Did the river thing. Been awhile, but satisfying.
  17. MadMotoMods
    MadMotoMods Adventurer Supporter
    Apr 16, 2021
    75
    India
    Was reviewing the forum, but found pretty old posts. So thought of asking.
    Is anyone using 18" rims for the rear on the Himalayan.
    Basically, I was looking at Aluminium rims for the Himalayan and the only ones available are Excel (Front 21*1.6" and Rear 18*2.15")
    Wondering if anyone has been using 18 rims and how good or bad would that be.
  18. Doctor T
    Apr 2, 2019
    1,525
    Sussex UK
    Finally got out in the rain this morning. Heavey rain with hailstones, nice mixture with an open face helmelt. God did they sting or what. These days all my riding is for enjoyment only so if it's chucking down it's a no-no. Don't get me wrong if am out and i starts to rain it doesn't dampen my mood.(see what i did there) :rillaI crack myself up sometimes. Anyway back to the reason for going out. I was to test the Conti TKC80's that i fitted during the lockdown and believe it or not, the first time it's rained properly for months. Doesn't always rain in the UK as some think it does. Anyway back to the test. I know these tyres are great in the dry. I can get to the edge of the tread on the rear without any slippage and when they do give a bum twitch they instantly grip again. Why my bum checks gripping the saddle i gingerly pulled out of my road at 20 mph. I gently road out of my village trying to miss the mud that the tractors had kindly left for me on corner apexes. When i thought the tread had warmed up i hit the back lanes, slowly building up my speed on each turn then i came to a corner a bit too fast, and at the last nanosecond, i notice loose gravel in my line. I must have prayed to every God under the sun, the front moved sideways out of line then one of these Gods must have heard me as i came out of the bend saying loudly Thank you, Thank you. I had to stop after this for a cold drink and a fag. Cheeks back in place and checked my pants were still clean off i rode again. After over 2 hours it was still raining but i found myself hitting the bends nearly as fast as in the dry. Due to this grip, you may find yourselves riding back lanes like a hooligan. These grips better than some track tires I've used in the past. They get warm very quickly and perhaps this is their downfall. Due to having soft compound longevity is minus. I think that the recorded mileage with these is just over the 1.5/2000 miles mark but this is on much larger bikes. My son wore a rear out in 800 miles fitted to his KTM 1250 adventure.
    The Conti's were what i was looking for, good road manners and good for the tracks available to me. Ok, they don't last as most but grip means more to me than the cost.
    Overall am very impressed with the tyres and if nothing else betters them, the next pair will be the TKC 80's again.:getiton
  19. ScottFree
    Jun 7, 2011
    1,192
    Ill-Annoy
    I experimented with the 2021 at Randy’s. Yeah, that button does not want to be pushed. Successful one try in ten. Actually, I think the computer in the pod only looks at it now and then, because I could feel the contacts close.
    Wow is it windy today! Just about blew me off the road a few times. Had to keep going back and forth between 4th and 5th to maintain 55 mph. After 100 miles of this I wonder how I’d deal with a full day of it crossing Kansas. Oh well, taking a well-earned break at Wishful Acres...
    70 miles to Madison, and all downwind from here. Hooray! Of course that means all upwind coming home tomorrow. But they say it won’t be as windy.
    They say...
  20. Owain-ap-Dewi
    Owain-ap-Dewi Adventurer
    Jan 7, 2021
    26
    Brycheiniog
    I've also recently done the valves for the 15Km service, it's the best thing i've done, the combonation of the tappets now being correct (the exhaust was a bit tight), and a 3k thermistor to slightly increase the fueling has resulted in the bike being really smooth, bike no longer stalls on start up, no longer have to give it a bit of throttle when starting it, it instantly starts and runs perfectly at 1.3K revs, with no bogging or eratic ideling. Also replaced the HT Lead and Plug cap before hand, but that didn't seem to make much difference.
    Also got around to changing the stearing bearings, as you can see from the photo below they were absolutely dreadful, looks like someone put some compost in my headstock, was very wet as well despite no rain for two weeks, the bottom bearing crumbled in my hand when I wiped it clean. Everything went very smoothly when changing them surprisingly, used a Dremmel to cut the the old bearing off, then flipped it upside down and used it in conjunction with a metal pipe to place the new one in, also brought a threaded rod and some large penny washers to insert the races into the headstock, costing £10 and making the job a lot easier.
    Only problem I have had is that I broke the connector that goes onto the bottom of the fuel pump, I thought I had to lift the tab, rather than squeeze it... Does anyone know what the connector is so I can replace it? Cant find anything on the parts lists.
