Royal Enfield Himalayan Owners Thread
Discussion in 'Thumpers' started by Anthiron, Sep 2, 2017.
  1. Doctor T
    Doctor T Gruppy old git
    Apr 2, 2019
    1,388
    Sussex UK
    Won't these stop you from using the steering lock?.
    jcw64 likes this.
  2. WitchCityBallabio
    WitchCityBallabio Guzzi weirdo
    Oct 23, 2008
    2,724
    Wales, Massachusetts
    Is there a good good handlebar cross brace that works with the Bark Busters? I'd like to stiffen the bar assembly up a bit before big offroad trip.
  3. Doctor T
    Apr 2, 2019
    1,388
    Sussex UK
    Had a little ride out today and found i may have a problem. Am sure i remember that am meant to pull the clutch lever to enable me to start the bike. I can start mine without doing that. I've had a look at the plug and wires that has a micro switch attached. Cleaned up the switch with an electric cleaner but still the same. Where do the 3 wires go?. I can't start the bike whilst in gear with the side stand deployed but am sure the switch on the bars stops me from starting without the clutch pulled in.
  4. byteofthecherry
    byteofthecherry Been here awhile
    Nov 20, 2020
    258
    west somerset UK
    I can't see it...??... starting a vehicle in neutral without a depressed clutch is 'normal'(however I had 'special' training :-) so depress the clutch as a reflex on any vehicle)…I'll check my bike tomorrow(unless those west of GMT beat me to it) and let you know.
    Kiwiscoot and Eatmore Mudd like this.
  5. bomber60015
    bomber60015 Hold fucking fast Supporter
    Sep 11, 2008
    80,496
    Chicago-ish
    I just went out to the Entropy Lab to check. Side stand down, gearbox in neutral, clutch lever out, starts fine.
    IN gear, clutch out ... no spinning from the engine room.
    hope this helps
  6. Kiwiscoot
    Kiwiscoot Been here awhile
    Feb 14, 2010
    770
    Christchurch, New Zealand
    Doctor T and buckthedog like this.
  7. byteofthecherry
    Nov 20, 2020
    258
    west somerset UK
    Ahh;...!!...so no 'jerking forward/rearward' whilst in gear(sometimes a useful feature in 4X4's low gear when pulling tree stumps to tension steel cable in slippery conditions)...might miss this when the time comes to pull a GS upright/out of the sh*t...:-)
    P.S. yes I know 'battery'…it's a wishful thinking 'concept thing'
    Doctor T and bomber60015 like this.
  8. buckthedog
    buckthedog Eastbound and down
    Oct 21, 2011
    1,216
    South Mississippi
    @Doctor T I hope you get your bike starting issue sorted. On the KLR there is a semi-adjustable clutch bypass screw under the left handlebar control that few people know about. There is a screw and an adjustment, maybe 2mm back and forth movement in total. Maybe ours has this? You just unscrew it, and move the movable part one way or other and try to start it, screw it down when it does. . I've only done it once, so cannot recall.
    To answer your question about using the steering lock with the steering stops now "rubberized" the official answer is ... I don't know, I didn't think to try. All of this is conjecture until I get my new screen (and oil filter ;) ) from India. It may be different? Cut different? a slightly different mold from different years? I honestly rarely use the steering lock. Guess I should.
    My bike is in a fenced, locked yard under a covered awning "car port" type thing, under a cover. My cat likes to sleep under there on her piece of foam, and she doesn't take kindly to...well, people, other animals, other cats, amoebas, helminths, single celled organisms...really any living thing.
    I'll try it and let you know.
  9. CaptainTrips
    CaptainTrips Long timer
    Nov 16, 2019
    1,157
    Vancouver(ish)
    Gotta love cats... er, I guess...
    buckthedog likes this.
  10. UtahGuido
    UtahGuido Long timer Supporter
    Nov 29, 2007
    12,504
    Spine 'O the Wasatch
    Went down to the local dealership at "test sat" the Himalayan. Fits nice. Only a matter of time I think. We'll see. I like the blue. Nice dash too.
    dcoop, modiorne and Eatmore Mudd like this.
  11. 770
    770 Adventurer
    Mar 15, 2018
    14
    Estland
    Hi guys,
    if anyone still wants a headlight and/or an instrument panel bracket, I still have some left.
    Both brackets are made of 5 mm thick aluminium and anodized to matt black. All fixing hardware is included and no changes to the triple clamp or frame is required.
    Instrument panel bracket and hardware is 50€. Shipping to UK and EU is 11.20€, to USA is 14.95€.
    Headlight bracket and hardware is 55€. Shipping to UK and EU is 16.90€, to USA is 21.50€.
    Shipping both brackets together to UK and EU is 16.90€, to USA is 21.50€..
    For EU individuals, VAT is added to the price of the brackets.
    If these brackets are of interest, please email me at himalayan@krown.work
    Krownwork_REH_headlight-and-instrument-panel-brackets_01.jpg Krownwork_REH_headlight-and-instrument-panel-brackets_02.jpg Krownwork_REH_headlight-and-instrument-panel-brackets_03.jpg
    bomber60015 and Doctor T like this.
  12. Kiwiscoot
    Feb 14, 2010
    770
    I don't think you have a problem, except if you are able to start the bike in gear without pulling in the clutch. This is dangerous and can wreck the starter motor.
    Normal to not be able to start bike in gear with the starter without pulling in the clutch. Only able to start bike in gear when doing a bump start.
    Normal to be able to start bike when not in gear and not pulling in the clutch, this is able on/off sidestand or centre-stand.
    So bottom line...you only need to pull in the clutch when using the electric start with the bike in gear, which sorts of makes for common sense.
  13. Kiwi59
    Kiwi59 Been here awhile Supporter
    Dec 7, 2019
    927
    New Zeaalnd
    Eatmore Mudd, Doctor T and xy3 like this.
  14. Hondapaul
    Hondapaul Been here awhile
    Aug 24, 2019
    102
    Ipswich UK
    Hi Doc.
    Swaped my whole clutch lever assembly out not long after getting the bike. Do not like clutch assemblys that have a single pinch bolt... just means you either have to break it or take eerything off (grip/switchgear) to remove/relpce it.
    Realised the three wire switch is the same as Kawasaki use on a ton of there bikes so picked up a really nice assembly of a ERF6/ER6N (2012 - 2016), as it had a mirror mount, for penuts of fleabay.
    Personally I find the overall action of the lever far better/more feel/smoother than stock.
    Anyway enought selling the swap... long story short i have a spare Kawasaki swicth if you would like it just in case yours has an intermitant fault
    Sidestand switch has been my only problem to date but now I just pull off the rubber and fill with dialetric grease every few months, or after heavy rain/puddle jumping :happay
    Drop me a pm and will send it.
  15. Dool
    Dool Been here awhile Supporter
    Jan 9, 2021
    749
    Australia
  16. xy3
    xy3 Adventurer
    Apr 13, 2021
    22
    Greece
    Thanks for the welcome. As far as oil goes we only use Extra Virgin Olive Oil here in Greece so I won't get into that discussion :-)
    dcoop, little ackman, jwaller and 6 others like this.
  17. xy3
    xy3 Adventurer
    Apr 13, 2021
    22
    Greece
    I have seen some comments and information on different luggage solutions in this thread and I wanted to contribute with some more info.
    Motea in Germany has a lot of luggage options at extremely good prices. Add the discount code EXTRA25 (changes over time) at checkout to get an extra 25%. Shipping to Greece was cheap (€9 each time for me) and very fast. They use DHL.
    Here is one example:
    ✨ Crashbar Bag for Royal Enfield Himalayan Bagtecs K5 Set for engine guard in black ✔ buy here (motea.com)
    Eatmore Mudd and Dool like this.
  18. Dool
    Jan 9, 2021
    749
    Australia
    If you bought them you have good taste ! IMO
    Eatmore Mudd likes this.
  19. Dool
    Jan 9, 2021
    749
    Australia
    And the Smell ? anything like Castor Oil ?
  20. Doctor T
    Apr 2, 2019
    1,388
    Sussex UK
    Thanks for the comments. So what is the point or what is this plug with 3 wires meant to do?. On my Tiger 1050 unless the clutch was pulled in the bike wouldn't start.
    I used to run a long wheel base 4x4 Mitsubishi Shogun, on pure veg oil. Ran lovely, only problem it smelt like a fish and chip shop.
