Royal Enfield Himalayan Owners Thread
Discussion in 'Thumpers' started by Anthiron, Sep 2, 2017.
  1. Kiwi59
    Kiwi59 Been here awhile Supporter
    Dec 7, 2019
    913
    New Zeaalnd
    Completely Agree with other comments. The Himma runs very lean so more fuel helps. Should not be left for long periods running stationary.
    tiltos and Dool like this.
  2. Kiwithl
    Kiwithl Been here awhile
    Apr 10, 2021
    113
    Thl
    What's the trick to get the male blades out of an electrical connection? Specifically the ignition switch connection about 6-8 inches from the switch. They don't want to push back or pull through.
    A previous owner has wired into the red/black(grey?) side to power the driving/spot lights. And I see the red/black insulation is cracked so I want to replace the wire.
    Tried to remove ignition switch prior to dismantling steering and triple clamps. Succeeded in rounding off my allen key without the bolt budging!
    If I can get the blades out of the connector I can try removing the ignition switch from the top triple clamp when it's off the bike, when I can see it right way up not upside down against the light with my glasses falling off... Or maybe I can replace the wire without removing the switch?
  3. MitchMan
    MitchMan Adventurer
    Jun 3, 2007
    77
    England, UK
    Does anyone use a Gold Plug magnetic drain plug in their Himalayan? If so which is the right size to go for?
    MitchMan
    Doctor T likes this.
  4. Kiwithl
    Apr 10, 2021
    113
    Thl
    Got the front end dismantled to the stage of loosening the fork top nuts prior to removing forks. Found out my fork top nuts are 22mm not 24mm as per manual and my socket set.
    Off to the shop to buy a 22mm socket. Luckily no lockdown here. (Probably should be. Over 15000 new infections per day. 4 months ago was 30ish per day. No vaccines in sight except sinovac from china.)
    No 22mm socket in stock so got a spanner. Spanner on nut, ready to use some muscle and turns without effort! 70nm must be tighter than that. In fact the fork top nuts were the easiest and loosest of the whole job so far, apart from the finger tight top triple clamp nut.
    Glad I'm doing it myself so when it all goes back together I'll know it's tight.
    Tomorrow I'll find out how tight the fork clamp bolts are...
    slownold and bomber60015 like this.
  5. Dool
    Dool Been here awhile Supporter
    Jan 9, 2021
    740
    Australia
    Could be like this, needs the Tang depressed to get it out, fancy tools are available , some times thin Jewelers screwdrivers will do it.
    Ignition switch has bolts that snap the stop theives?
    Kiwi59, CaptainTrips and bomber60015 like this.
  6. Dool
    Jan 9, 2021
    740
    Australia
    or use liquid insulation, nail varnish?
    Kiwithl and bomber60015 like this.
  7. Dool
    Jan 9, 2021
    740
    Australia
    They put plenty of glue on those ones. or they did on mine at least. Helps to work them back and forth like the reverse of cutting a Thread.
    Kiwithl likes this.
  8. johnny42
    johnny42 Been here awhile
    Sep 11, 2018
    229
    New York
    I fashioned a thin "probe" out of a plastic milk container with scissors. Other plastics could work too. Keep cutting it thinner and thinner until it slips in by the wire and depresses the "barb" or "tang". Then gently pull the wire out.
    Keep a bit of pull tension on the wire as you slip the probe in. You'll know you've released it when the wire pulls out.
  9. drdubb
    drdubb OFWG Supporter
    Dec 13, 2009
    2,384
    Durham, North Carolina
    Good tip
    Kiwithl likes this.
  10. Hondapaul
    Hondapaul Been here awhile
    Aug 24, 2019
    100
    Ipswich UK
    I always carry a Leatherman Micra with me and, strangely enough, the little thin flat screwdriver blade is the most used as it's the perfect size to pop the tang with
    dcoop, Kiwithl and Dool like this.
  11. bomber60015
    bomber60015 Hold fucking fast Supporter
    Sep 11, 2008
    80,486
    Chicago-ish
    After ordering something less than $20 of parts, this arrived in the mail today.
    I think they are upside down in our relationship, thus far ;)
  12. CaptainTrips
    CaptainTrips Long timer
    Nov 16, 2019
    1,138
    Vancouver(ish)
    Ooh, nice. I look forward to receiving mine!
    bomber60015 likes this.
  13. drdubb
    Dec 13, 2009
    2,384
    I think I have you covered.
  14. Kiwithl
    Apr 10, 2021
    113
    Thl
    Aw, gee, Mr Dool, Sir. I wasn't really trying to steal the motorcycle. Honest.
    I think the hex and bolt are still ok. Just the allen key's not.
    Decided to always look on the bright side of life. Can get another allen key easier than fixing a broken bolt...
    Thanks for the photo of the tang. Now I know what I'm dealing with.
    Dool likes this.
  15. Scottyhumbucker
    Scottyhumbucker Been here awhile
    Jul 19, 2020
    168
    Sacramento
    100 % normal
    tiltos and bomber60015 like this.
  16. Dool
    Jan 9, 2021
    740
    Australia
    31RWHP
    29.9 ft lbs Torque.
    Standard Head 477cc kit Tec Cam.
    Not Too Shabby !
    Check out the Charts.
  17. ToasTje
    ToasTje Been here awhile
    Jan 5, 2021
    116
    West Flanders
    What charts?
    I assume it's with a powertronic or something similar as well?
  18. slownold
    slownold Been here awhile
    Oct 14, 2020
    231
    Adelaide, South Australia
    Certainly not on mine, and I've had it out a couple of times. Just normal bolts, and they weren't overly tight. The only trick is to make sure the steering lock works when re-installing it, the first time, it was slightly out of position (there's built in slop) and the pin wouldn't drop into the hole (or however it works). Mine's a carby model, maybe the later ones are different.
  19. Kiwi59
    Dec 7, 2019
    913
    New Zeaalnd
    I hope I get one as well, spent enough with them.
  20. Kiwi59
    Dec 7, 2019
    913
    New Zeaalnd
    Nice tool set.:lol2
