Royal Enfield Himalayan Owners Thread
Discussion in 'Thumpers' started by Anthiron, Sep 2, 2017.
  1. little ackman
    little ackman Been here awhile
    Mar 3, 2019
    173
    Bundaberg Australia
    I can only get a big toe down on either side, and that's with wearing thick soled boots. I preferred to get used to riding the bike the way it is as I would hate to lose any cornering clearance. I should also mention that I am 70 with a destroyed left knee. Getting a new one in 2 weeks, so will not be able to ride for a while, but the point is, just get used to the height. It is not necessary to have your feet flat on the floor. Just need to exercise more care when stopping and starting. Also practice persuading the bike back onto its feet after it gets tired. This tends to happen a lot when you are a short arse.
    zefnerd and Doctor T like this.
  2. Owain-ap-Dewi
    Owain-ap-Dewi Adventurer
    Jan 7, 2021
    26
    Brycheiniog
    The flange actually already has a slight curve to it, but that seems common. PSG don't do exhaust studs, I meant stainless engine casing bolts.
  3. byteofthecherry
    byteofthecherry Been here awhile
    Nov 20, 2020
    271
    west somerset UK
    Fit a new copper 'crush washer'...not essential, just the way I do it and pull down a couple of alternating turns each side until you feel it crush and the plate seats firmly and is even, use a standard L or T shaped Allen key… you don't need massive amounts of force…it's a feel thing...regarding the washers…spring one goes on first so against the head of the bolt followed by the plain washer...let the bike run or go for a short ride...after it cools just check for 'snug tightness'
    zefnerd, Doctor T, Dool and 1 other person like this.
  4. CaptainTrips
    CaptainTrips Long timer
    Nov 16, 2019
    1,226
    Vancouver(ish)
    Me too. I found a cheap LED H4 replacement bulb.
    Doctor T and bomber60015 like this.
  5. bomber60015
    bomber60015 Hold fucking fast Supporter
    Sep 11, 2008
    80,560
    Chicago-ish
    I’m running a Chicom LED headlamp … cheap, and has held up well so far.
  6. Dool
    Dool Been here awhile Supporter
    Jan 9, 2021
    827
    Australia
    Silastic the same stuff the Plumbers use, copper washer is left in situ. Tight enough that it doesent move.
  7. excollier
    excollier n00b
    Jun 20, 2021
    8
    Ireland
    I like this.....
  8. drdubb
    drdubb OFWG Supporter
    Dec 13, 2009
    2,417
    Durham, North Carolina
    Reminds me of 60's motocrossers.
    excollier and Doctor T like this.
  9. Doctor T
    Doctor T Gruppy old git
    Apr 2, 2019
    1,437
    Sussex UK
    Like the idea of using the tank guard as a pannier frame. You can just see it on the other side of the exhaust.
    excollier likes this.
  10. toslow
    toslow Been here awhile
    Nov 18, 2010
    231
    western colorado
    Got a question on putting a booster plug on a 2021 all the bikes Ive seen so far in the US look like they are basically 2020 sold as 2021 the 2021's on the internet show the they have the navigation gauge and the cat on the exhaust is on the down pipe instead on the bottom and some other differences Booster plug says their plug won't work on the 2021 model and it will throw a code so will it work on the so called 2021's that were in the dealers this spring and summer thanks
  11. JustinP
    JustinP Bike Curious
    Jun 19, 2011
    13,595
    Delmar NY
    Do you have the air intake sensor pictured here?
    https://accessories.hitchcocksmotorcycles.com/92120-3-AIT.jpg
    If so, it will work.
  12. toslow
    Nov 18, 2010
    231
    western colorado
    yes I have the white sensor bolter to the air box and a grey plug plugged into it doesnt the new 2021 models have that?
  13. JustinP
    Jun 19, 2011
    13,595
    Delmar NY
    From the product page:
    "During 2021, we saw the introduction of the Euro 5 compliant Himalayan models. The BoosterPlug is not compatible with these Euro 5 models and the air intake sensor is no longer present. You can confirm this by checking if you have the sensor present on your bike and compare it to the photo above. Please see the photo and ensure you have this fitted to your Himalayan before ordering this kit."
  14. toslow
    Nov 18, 2010
    231
    western colorado
    oh boy I've found another thing to spend money on (my wife will be so proud of me) thanks for the reply
    CaptainTrips and JustinP like this.
  15. benebob
    benebob Been here awhile
    May 25, 2016
    361
    PA
    Is there a specific sequence to tightening down the valve cover? Got my Hitchcock' cam in place, timed right and can't seem to find any mention of a sequence in the FSM.
    JustinP likes this.
  16. Doctor T
    Apr 2, 2019
    1,437
    Sussex UK
    Under the newish euro 5/6 rules, manufacturers have to safeguard the tampering with the emissions limits and rules. From 2024 tamperproof seals must be fitted, from 2025 motorbikes/cars must be fitted with a speed limiter set at the countries max speed limit. This is said to be fitted with a GPS system that will automatically issue speeding fines. For us in the UK it will be set for 20.30,40.50,60, and 70 mph. The exact date has yet to be set but must come into law by the end of 2025. Some countries state 2023. These are all European rules coming in and will also affect vehicles sold outside the EU. For me, it going to be Big Brother is always watching. Welcome to the USSR.
    DON'T HAVE A DIG AT ME AM JUST THE MESSENGER
  17. CaptainTrips
    Nov 16, 2019
    1,226
    Vancouver(ish)
    Sounds like the resale value of used vehicles is going up...
    Doctor T and little ackman like this.
  18. bomber60015
    Sep 11, 2008
    80,560
    Chicago-ish
    Man, I just love this bike.
    53D49832-4A92-450C-A114-8F968320CCAC.jpeg 6DF4514A-3BC9-43DF-822D-A6A76EF89A99.jpeg 73872DE8-06CD-4AD4-B4A0-85BB656B0830.jpeg
  19. dcoop
    dcoop Been here awhile Supporter
    Mar 31, 2010
    197
    Anchorage AK
    I’ve used pin lock without success. Maybe I’m just a heavy breather?
  20. CaptainTrips
    Nov 16, 2019
    1,226
    Vancouver(ish)
    The trick is to get the inner shield seated evenly. I find that if I ride with the visor open the wind can move the inner shield a bit and break the seal.
