Royal Enfield Himalayan Owners Thread
Discussion in 'Thumpers' started by Anthiron, Sep 2, 2017.
  1. Kiwi59
    Kiwi59 Been here awhile Supporter
    Dec 7, 2019
    979
    New Zeaalnd
    Thanks found them.
  2. Kiwi59
    Dec 7, 2019
    979
    New Zeaalnd
    Nice, have fun.
  3. Doctor T
    Doctor T Gruppy old git
    Apr 2, 2019
    1,514
    Sussex UK
    KTM 390 adventure bars are very similar.
    bomber60015 likes this.
  4. BarKnee
    BarKnee Been here awhile
    Feb 11, 2012
    734
    Portland, OR
    These Renthal 789 bars look very close to stock. Found them in my big box of bought and never used parts (leftovers from VFR800 clipons to bars conversion).
    https://www.revzilla.com/motorcycle/renthal-street-fighter-handlebars-78?sku_id=952867
  5. benebob
    benebob Been here awhile
    May 25, 2016
    397
    PA
    Well did my 300 mile valve adjustment with the new hitchcock's cam (a little early as I have 270 or so miles on it) but wet here today thru tomorrow. Will post up my thoughts once I get to start flogging it over the next couple hundred miles but preliminary thoughts. Don't waste your time or money on it. That said I noticed more so far from the hitchcock's cover for the air filter but of course I've tried to be good with only a few times above 4k so far.
    Doctor T, Dool and JustinP like this.
  6. LHRider
    LHRider Adventurer
    Jul 18, 2017
    47
    Or they could be simply awful.
  7. CaptainTrips
    CaptainTrips Long timer
    Nov 16, 2019
    1,320
    Vancouver(ish)
    Cheapo chain oiler works quite well.
    talmage and Doctor T like this.
  8. bomber60015
    bomber60015 Hold fast Supporter
    Sep 11, 2008
    80,653
    Chicago-ish
  9. BarKnee
    Feb 11, 2012
    734
    Portland, OR
    The Renthals come with a crossbar, haven't located it yet. Waiting for winter down time to swap the stockers out, will have to see if the crossbar works with Barkbusters.
  10. Dool
    Dool Been here awhile Supporter
    Jan 9, 2021
    960
    Australia
    Did you fit the Airbox mod at the Same time as the Cam ?
    JustinP and Doctor T like this.
  11. Doctor T
    Apr 2, 2019
    1,514
    Sussex UK
    Got one myself. Think i paid £12.00GBP. One little capful lasts about 300 miles. I fitted mine in the same place about 3000 miles ago with no problems to date. I use gearbox oil.
    CaptainTrips and Hondapaul like this.
  12. Doctor T
    Apr 2, 2019
    1,514
    Sussex UK
    Idiots guide to fit a big bore kit on a Himayalan. This PT1 of 5. To see view the rest go to Mytwistedvoices on YT.
    JustinP and Dool like this.
  13. CaptainTrips
    Nov 16, 2019
    1,320
    Vancouver(ish)
    I paid just under C$20 delivered for mine. Cheaper that trying to build my own out of scrap bits and pieces.
  14. ToasTje
    ToasTje Been here awhile
    Jan 5, 2021
    139
    West Flanders
    So led headlight: led unit has a green and red wire for the daytime running light, bike has a yellow and black wire.
    How do I know what to connect with what?
    Doctor T likes this.
  15. Hondapaul
    Hondapaul Been here awhile
    Aug 24, 2019
    115
    Ipswich UK
    Hi
    My choice of chain oil is Sthil Synth Plus bar oil. Some american did comparrison test on oils/scottoils/chainsaw oils for "best" oil to use on a motorcycle chain and gave it top marks in lube and anti fling.
    Can not seem to find a link to it at the moment but it was a really good indepth and honest review of oils and there properties.
    I have been usung the Sthil Synth plus for decades (until the X system) with 50,000 plus chain mileage (1988/9 VFR750FJ/FK 20+ years and 300,000 + miles) before i start to even think about chain wear (change the front sprocket when signes of wear start to appear and you will not need to change the rear).
    It would seem that the pump in the new X system is not as robust as it stopped working after only one refill of the Sthil oil... Did not expect that as have been using Scott oiler pretty much since they were invented... both vaccum and pumped.
    Sent it back to Scottoil and they repaired it foc and now keep to the propper (ccough *bl**dy expensive*) oil
    As a side note... lots of talk on here about the split/rivit link debate... I just went for the endless option... was removing the swing arm anyway to re-grease so it seemed a no brainer to me and 112 link DID ZVMX chain easy to find but prices do vary a bit... I have about 12,000 miles on mine so far and its only needed a couple of small adjustments to date.
    talmage and little ackman like this.
  16. JustinP
    JustinP Bike Curious
    Jun 19, 2011
    13,697
    Delmar NY
    Yellow is hot, black is ground on the bike. Refer to directions of the lamps for what it is on that end. Chinese wiring colors are all over the place.
    talmage and bomber60015 like this.
  17. ToasTje
    Jan 5, 2021
    139
    West Flanders
    Well, that very small piece of paper that has some resemblance of an manual has no mention what so ever of those 2 wires.
    What's the worst then can happen when I connect the wrong one???
    LED is short for Light Emitting Diode and from what I can remember from high school, current can only move in one direction in a diode.
  18. sqeeezy
    sqeeezy Been here awhile
    May 12, 2019
    441
    Southern Spain
    APOLOGIES: Enduro Philosophy Alert
    little ackman likes this.
  19. benebob
    May 25, 2016
    397
    PA
    no i put it in a few days and 500 or so miles before I did the cam. Seat if the pants it seemed to breath a bunch better and rev quicker then the stock with my delkivik and a k&n air filter. The cam does have a crisper pop at idle but doesn’t seem to do much beyond that. Will give it some more miles to see if it is just me being tired of break in speeds
    Dool likes this.
  20. JustinP
    Jun 19, 2011
    13,697
    Delmar NY
    There's other components besides the LED, but either way shouldn't hurt anything.
