Royal Enfield Himalayan Owners Thread
Discussion in 'Thumpers' started by Anthiron, Sep 2, 2017.
  1. zefnerd
    zefnerd Adventurer
    Jan 11, 2020
    70
    US
    Not sure about your market timing on introducing an ECU piggyback for a Himalayan, but good luck on your endeavor. Also hope your hardware provider is handling your regulatory regs (electrical, radio interference, CARB Id) for you so you can focus on support, regulations are interesting but not fun if the goal is hobby level.
    Dool likes this.
  2. Dool
    Dool Been here awhile Supporter
    Jan 9, 2021
    827
    Australia
    Timing is probably as good as it gets, this is no Piggy Back, it's a replacement ECU that is programmable and I doubt it has passed any interference tests.
    zefnerd, Doctor T and BillMcQuade like this.
  3. Hondapaul
    Hondapaul Been here awhile
    Aug 24, 2019
    108
    Ipswich UK
    Hi - found this if its any help
    https://www.ebay.co.uk/itm/27190658...7779&msclkid=cf0bff2987691dd35c6d9e66dab59381
    which stats in the blurb - AS USED BUY THE NATIONAL VINTAGE TRACTOR CLUB MEMBERS - which might give you an option of where to try for straight 90wt.
    Doctor T and Kiwithl like this.
  4. Dread
    Dread Putt-Putt Adventurer
    Sep 17, 2006
    783
    Boise, ID
    New owner, longtime lurker on this thread. In Boise Idaho.
  5. Hondapaul
    Aug 24, 2019
    108
    Ipswich UK
    I believe that it was Suzuki who use to state in the manuals.. Lubricate rear chain - brush with engine/gear oil before each ride...
    I must admit that I have used waste oil before now if i did not have any lube handy... Really liked the PJI chain lube back in the day and the old pan on your mothers stove to soak the old style chains. but after using my first scottoiler i was just hooked...
    My early VFR had the behind the numberplate resivour and its was truly a fit and forget for a six months, or longer...
    I know straight oils are cheaper but not sure cheaper per (road only) chain mile. £100/120 for a VFR750 chain set and, genuinely, 50,000 miles+ on my first chain which I only changed as heading back to France/Italy for a three month hoilday and just thought it was a good idea, just in case, to change it.
    Second chain was 60,000+ and counting when I sold the bike. I have owned many many motorcycles but only the VFR's (and a CX500 with over 90,000 miles on its CMA mag wheels, but as that is shaft... not so relavent to chain milage :-)) have been long term/high milage.
    Used to rider marshal enduros back in the day and the only scott oiler type thing i had considered was lube tube with a petcock on it... Slap oil all over it each time you go was the norm or just realise that, fully of road, the chain is as disposable as the tyres
    Doctor T likes this.
  6. little ackman
    little ackman Been here awhile
    Mar 3, 2019
    174
    Bundaberg Australia
    Subtle is over rated. Brashness gets the point across.
  7. CaptainTrips
    CaptainTrips Long timer
    Nov 16, 2019
    1,227
    Vancouver(ish)
    GL1 and GL5 are API service categories. If I remember correctly these are cumulative in the sense that GL5 would include all previous standards (GL1 to GL4) like JASO MA vs JASO MA2 it is a higher standard.
    Kiwithl likes this.
  8. CaptainTrips
    Nov 16, 2019
    1,227
    Vancouver(ish)
    I'm in the mood to tinker. Someone please remind what increasing TPS voltage (vs decreasing it) actually does.
  9. RideFreak
    RideFreak Torque Junky
    Apr 17, 2009
    16,580
    Out in the NM Dez somewhere
    increase TPS voltage is richer as the ecu thinks the throttle is open further, decrease voltage=leaner.
    dcoop and CaptainTrips like this.
  10. Solera
    Solera Been here awhile
    Jan 1, 2019
    106
    ACT, Australia
    Cool!, a replacement ECU is the best way to go. Never really liked piggy-backs, more connectors to play up. As far as compliance testing or what have you goes, ha!. Just ask for the appropriate sticker. Any interference can't be any worse than those damn switching wall-wart/plug-packs that everyone has a gazillion of, and those little on bike USB chargers, they aren't too clean either and I bet none of those have been tested. Besides being a vehicle ECU I would expect its got enough filtering and protection designed in for its own sake that it's unlikely to cause external problems, and unless your pacemaker is in your bum nothing should be close enough to it anyway.
    I'm 6 months away from end of warranty, if I still have the bike I'll be doing some more intrusive upgrades and would be interested in this here device if you are looking at going that way.
    Doctor T, little ackman and Dool like this.
  11. Beemerboff
    Beemerboff Long timer
    May 23, 2005
    3,854
    Adelaide, South Australia
    Carb bikes have a TPS too, so they probably only effect the ignition map / advance.
    So, if you think you need more advance not that hard to work out which way to turn it.
  12. Kiwi59
    Kiwi59 Been here awhile Supporter
    Dec 7, 2019
    955
    New Zeaalnd
    It will run an 477 BB kit but it needs more fuel. Had a PT that was faulty ran better than the stock fueling on map 2 but not would allow to increase the fueling. Getting a replacement form PT. :y0! Still needed more fuel low down so Dools new ecu may be the answer.
    Dool likes this.
  13. Kiwi59
    Dec 7, 2019
    955
    New Zeaalnd
    Please post results.
  14. Dool
    Jan 9, 2021
    827
    Australia
    I have just started testing the new FuelX unit , connected to the O2 sensor circuit.
    On the first run it supplied enough extra fuel to run my 477, not as effective as the Powertronic piggy back but good enough, although at the cost of about 300 shipped it is less than 50 bucks cheaper than the Reprogrammable ECU.
  15. Kiwi59
    Dec 7, 2019
    955
    New Zeaalnd
    Welcome to the Himma club. Enjoy the new ride.:y0!
    Dread likes this.
  16. CaptainTrips
    Nov 16, 2019
    1,227
    Vancouver(ish)
    My Hima is developing a fueling or ignition glitch. At around 3k rpm the engine will occasionally cut out for a moment. It seems to be related to throttle position but it is not consist enough to be repeatable. In second or third gear it will manifest it self as a moment where the ignition just seems to cut out. But a couple of times yesterday, it would just stall the engine when pulling away from a stop.
    I am running a PT with the supplied PT maps unaltered right now on map 2. I suspect that it might be the TPS but I think I will bypass the PT first and remove the lambda pig tail to restore stock ECU functionality to see if the problem continues. Any advice on testing the TPS?
    Dool likes this.
  17. Dool
    Jan 9, 2021
    827
    Australia
    When you disonnect the Lambda pigtail it will be forced to Trim with the O2 sensor, what if you try that first. Just saying because mine was Faulty , I cut off the cover and found that the wire had not been soldered properly and it intermittently made full contact.
    TPS test would be on Youtube
    CaptainTrips likes this.
  18. Doctor T
    Doctor T Gruppy old git
    Apr 2, 2019
    1,437
    Sussex UK
  19. Loadtoad101
    Loadtoad101 Been here awhile
    Feb 28, 2017
    741
    Livingston TN
    What's the name of the oiler? Where did you buy?
  20. Doctor T
    Apr 2, 2019
    1,437
    Sussex UK
    The one most shops sell is Cobrra Nemo 2, These sell for around £85GBP but others under different names are the same unit but a lot cheaper.£25GBP. Mine is called Gidibll universal oiler. They can be bought from ebay and aliexpress. Aliexpress sell them the cheapest if you don't mind waiting
