Royal Enfield Himalayan Owners Thread
Discussion in 'Thumpers' started by Anthiron, Sep 2, 2017.
  1. zefnerd
    zefnerd Adventurer
    Jan 11, 2020
    72
    US
    Yeh, Timing wise, I was thinking about how the latest Euro5 compliant bikes have a much different ECU setup, a reason boosterPlug is bowing out and perhaps why PowerTronixECU introduced the FuelX and needed a special version for the 2021 Himalayan.
    I doubt electrically the ECU replacement could cause that much trouble, but it malfunctioning could be a problem for the engines health. Just my view, the various certifications just tend to ensure a certain level of dependability on the design side.
    Dool likes this.
  2. Doctor T
    Doctor T Gruppy old git
    Apr 2, 2019
    1,441
    Sussex UK
  3. CaptainTrips
    CaptainTrips Long timer
    Nov 16, 2019
    1,232
    Vancouver(ish)
    Mine is also GIDIBII Nemo 2 bought from AliExpress.
  4. Dool
    Dool Been here awhile Supporter
    Jan 9, 2021
    835
    Australia
    The Reprogrammable ECU does not support the newest Bs6/Euro5 models and yes they are served by FuelX and probably little else ATM.
    Booster plug pulling out makes me worry that the AIT sensor is hidden, I havent seen one yet.
    But for the Models before, this ECU is just what the Doctor ordered, to say it is Revolutionary may be a step too far:hide but if you want to go past "Piggy Backs" and "Cheats" Then being able to change the ECU is a Dream.:lift
    Or maybe not? Im not too concerned about the engines health otherwise I wouldnt opening it up so often:-)
  5. wfrpalm
    wfrpalm Been here awhile
    Apr 22, 2009
    220
    between Akron and Y'town
    Man the gauges fogging up sucks.
    bomber60015 likes this.
  6. White mt guy
    White mt guy Long timer
    Jan 20, 2016
    1,857
    northeast
    Yup, got mine replaced under warranty at 500 miles and now at 2600 miles and are fogging up again.
  7. RheinGold
    RheinGold Weniger aber besser.
    Sep 6, 2006
    42
    Breukelyn
    Lets talk electrical output.
    I want to add two fog lights to my 2021 Himi. I also use a GPS and heated jacket. When not riding it's usually on a trickle charger.
    I think the alternator puts out only 110W. Is that AFTER powering the bike's spark plug, lights, ABS, etc.?
    How many watts do you think I can draw without killing the battery.
    And, what's the best gauge for the LED lights' wires? I'm thinking 16Ga.
  8. Scottyhumbucker
    Scottyhumbucker Been here awhile
    Jul 19, 2020
    172
    Sacramento
    :imaposer:happay
    Mine runs better with the Hitchcock’s cam and air box mod. Noticed more wakey wakey in the middle RPM range and better acceleration. I’m now pissing and moaning more about the brakes. This is one of those bikes that it just never ends. Wife asked “Are you happy now?” LOL
  9. CaptainTrips
    Nov 16, 2019
    1,232
    Vancouver(ish)
    I haven't looked at the lambda pigtail yet, but I did test the TPS. Seems fine and voltages are within spec, currently just under 6v. I thought about playing with this, but the PT is calibrated to the TPS open and closed positions manually, so would it make any difference what voltages the TPS is using if the PT is recalibrated for it anyway?
    I did notice that the map that I am currently using jumps the ignition advance from 0/2 to 7 in the 2000 to 3000 rpm range and throttle openings that I am experiencing the issue with. I wonder if that has anything to do with it. I wonder if I should smooth this out.
  10. Dool
    Jan 9, 2021
    835
    Australia
    7 seems high in that area though I doubt it would cause an intermittent fault. You have nothing to lose by dropping that advancement, the 462 map would have no extra advancement there.
  11. Beemerboff
    Beemerboff Long timer
    May 23, 2005
    3,856
    Adelaide, South Australia
    Yep, that is a estimate of the power free after running the ignition/injection/ lights/ABS, etc. But only an estimate, there are simply to many variables to give an accurate figure.
    LEDs don't draw much power so 16g cable is not essesential, and the wires on the lamps themselves can be quite light gauge. But lighter wire is not always easy to find, and stock 1/4" auto size terminals do not always work that well with smaller wires.
    So if all you have is 16g wire and 1/4" / 6.3 mm terminals, fine, but if you have to buy everything in and can wait there are plenty of kits out there with three sizes of crimp terminals and crimp pliers to suit, and you are probably going to need the smaller terminals sometime anyway----!
    Doctor T likes this.
  12. Scottyhumbucker
    Jul 19, 2020
    172
    Sacramento
    I have a question for my fellow inmates... I’ve got the Eastern Beaver harness for my GPS... for those of you that have done this install, where did you choose to tap in for power for key on ? Taillight? Somewhere else?
  13. Kiwi59
    Kiwi59 Been here awhile Supporter
    Dec 7, 2019
    956
    New Zeaalnd
    I agree restore the original first and go from there. Hope the PT is not faulty as mine was.
  14. Kiwi59
    Dec 7, 2019
    956
    New Zeaalnd
    Also comes down to the unit being assembled correctly!:-)
    zefnerd likes this.
  15. Doctor T
    Apr 2, 2019
    1,441
    Sussex UK
    I run 2 x 10W LED spots as daylight lamps so on all the time. Along with these, i have a LED headlamp, GPS, and Phone running all the time. Above tick over my meter still shows 14.2 Volts.
    With a heated jacket, i think you will be OK as others on here have heated clothing. With the LED spots, 16GA wire is not needed as the Volts/Amps are low.
  16. drdubb
    drdubb OFWG Supporter
    Dec 13, 2009
    2,417
    Durham, North Carolina
    I used posi-tap connectors and the tail light as a trigger for the relay. Power was directly from the battery.
    bomber60015, jcw64 and JustinP like this.
  17. JustinP
    JustinP Bike Curious
    Jun 19, 2011
    13,601
    Delmar NY
    Put 500+ miles on this weekend. Celebrated her 1000 mile anniversary at one of my favorite scenic lookouts, Mt. Utsayantha. Got in a lot of Section 1 and 2 of the NEBDR this trip, and putted around backroads of PA to meet a friend in Wellsboro. The smile/$$ ratio of this bike can't be beat.
    And of course I had to play in the mud to get around a downed tree. I'll be glad when these tires burn out and I can replace them with something a hair better in the mud. They magically turn into slicks as soon as you see mud.
  18. Eatmore Mudd
    Eatmore Mudd Mischief on wheels.
    May 28, 2012
    4,168
    Wet side of WA.
    Not so much higher standards but higher numbers for different standards.
    Example: GL-5. GL-5 is the bees knees in differentials but not such a good idea in transmissions ( brass bushings and synchro blocking rings) It has phosphorus in it. Phosphorus does not play well with yellow metals like brass.
    MA-MA2. MA2 has less ZDDP in it than MA. I'm down to my last jug of MA
  19. BarKnee
    BarKnee Been here awhile
    Feb 11, 2012
    732
    Portland, OR
    I'd have to agree with that. Looks like you had some great travelling. I've added Barkbusters and considering crash bars, what brand do you have, they look robust without adding a lot of width.
    Did some backroad putting also along with some fall colors viewing, great fun!
    modiorne, JustinP and zefnerd like this.
  20. JustinP
    Jun 19, 2011
    13,601
    Delmar NY
    I went with the Givi. I like the 3 point mounting, great protection. And they don't interfere with any maintenance (oil changes, valve adjustment etc). I have not hung them up on anything yet.
    Great shot! What seat pad is that? I need something between my arse and the sticky rubber.
