Royal Enfield Himalayan Owners Thread
Discussion in 'Thumpers' started by Anthiron, Sep 2, 2017.
  1. eakins
    eakins Butler Maps
    May 29, 2002
    39,261
    Fort Collins, Colorado
    So aproxapproxim 34.5" seat height now with a nice narrow nose. That's perfect and probably the better height for most. My DR was 35" and I have a 29" inseam. Worked great. My WRR is 36" and I notice the extra inch.
    This seat height will provide some great knee bend comfort for the long haul.
  2. eakins
    eakins Butler Maps
    May 29, 2002
    39,261
    Anyone going to update their rear seat section too? I ride with my daughter.
  3. Loadtoad101
    Loadtoad101 Been here awhile
    Feb 28, 2017
    742
    Livingston TN
    Let us know the exact model and part# for the Risers. I have been wanting some myself.
  4. B7ACKTHORN
    B7ACKTHORN Adventurer
    Sep 21, 2018
    22
    Somewhere. Somehow.
    That's right. Personally, it's not a bad idea to spend money on exhaust, after all a little sound that gets the attention is not bad at all, but at the expense of gas mileage and the exhaust note which irritates post 20 mins into the ride. I am no tuner tom, but the experience with a slip on has been good so far at least with respect to linear power delivery. Any gains experienced from the exhaust w.r.t. HP bump, zilch. But has the bike able to rev more freely and get to the meat of the band easier, a definite yes.
    I alway say, do what suits you best.
    Cheers!
    Richarde1605 likes this.
  5. DeltaT
    DeltaT Adventurer
    Jul 17, 2018
    23
    Congleton, UK
    Same. My dealer said mine was the first bike they've had that needed adjustments at first service, but I've heard of a few others from here and the FB group since.
  6. wolftrax
    wolftrax Long timer Supporter
    Sep 23, 2008
    1,057
    Blue Ridge Mtns Ga.
    Will do
    Sent from my Z558VL using Tapatalk
  7. chArj_Himalayan
    chArj_Himalayan Been here awhile
    Aug 6, 2018
    107
    Indianapolis, IN
    My thought as well,
    Try checking your air filter, the crank case pressure at those speeds can draw in oil.... something I was warned about by my dealer. I usually cruise at around 60mph and the I have never had to top off oil, I have over 3000 miles now.
  8. mxz
    mxz Been here awhile
    Sep 11, 2015
    771
    Bought the Grunt V3 from Greasehouse in India. (I belive it's called Indimotard). Chatted to them over their FB page, they responded, invoiced me via PayPal and shipped real fast.
    Other than requiring a little bit of copper grease under the gasket (some air was coming through the gasket seal) it fit fine, is much lighter than stock and sounds great. Louder, but not stupidly loud. Also it does not stain like the stock. That just got eww brown after a week.
    Matt TwoTired and B7ACKTHORN like this.
  9. mxz
    Sep 11, 2015
    771
    To whom it may concern, this is a DIY ABS fuse switch solution, basically a 15$ radioshack option. A hole drilled into the fuse case cover, a lead running out to an external fuse, added a switch on the bars with a cable tie, a water cover and some silicone sealer. Very basic, works like a charm. Can now switch on/off ABS (Euro model) without killing ignition. Pics below.
  10. B7ACKTHORN
    Sep 21, 2018
    22
    Somewhere. Somehow.
    True indeed, the brownish staining that the stock muffler is prone to is completely gone with a slip-on, courtesy, the high grade steel used. You'd have mild leak near the pipe/muffler meet point, but that shouldn't be a cause of concern, as it's very minimal. One thing of caution is make sure the exhaust mount point on the rearset is torqued well. The bolts they provide is of not a lengthy one and it's a tight fit.
    Would be interested to know where the leads of the wire that goes into the fuse box are affixed to in the fuse box, which fuse and how? Was it a direct blade fuse tap connector that was used in tandem with an additional inline fuse and switch setup? Photos of the wire ends that go inside the fuse box would be helpful, if possible.
    Cheers!
  11. eakins
    eakins Butler Maps
    May 29, 2002
    39,261
    Nice. Easy enough much cheaper than the Blue OX fuse bypass switch option. Those are stupid expensive for the materials involved.
    Glad to hear this works!
    Abs off in the dirt...Abs on for paved roads...modern technology to save your life one day.
  12. Richarde1605
    Richarde1605 Long timer
    Jan 1, 2015
    12,069
    QLD Australia
    I put the re options exhaust on mine in the early daze sic. I think that a thumper needs to thump ! ! !
    Not sure if they still are available...
    My neighbors like it, but I don't shit in my own nest by abusing the throttle in my street, I can't really comment on power etc. as it was fitted during the running in period, but it sounds nice, and doesn't bother me noise wise :-)
    Sent from my SM-G950F using Tapatalk
    TheQ likes this.
  13. cyclopathic
    cyclopathic Long timer
    Dec 23, 2007
    9,749
    There's nothing odd about OEM shock; it is not a progressive but dual rate spring. Dual rate springs are set up to work at balance point so they are essentially one rate when suspension compresses and another (lower) when it expands. The benefits of lower rate spring on expansion that the force with which wheel press down is falling at lower rate so wheel better stays in contact as it falls into pothole.
    The_Precious_Juice likes this.
  14. Eatmore Mudd
    Eatmore Mudd Mischief on wheels.
    May 28, 2012
    4,168
    Wet side of WA.
    Thanks man ! and much respect to you.
  15. wolftrax
    Sep 23, 2008
    1,057
    Blue Ridge Mtns Ga.
    Just made it across the continent, truly a pleasure to tour on. Crescent City, California.
  16. Capt. Gary
    Capt. Gary Been here awhile
    Aug 29, 2018
    276
    Alabama usa
    Via terria trailpack for the royal Enfield himalayan front frame is worth the price of admission. The fit is perfect the construction and the fabric is first class the ykk zippers and pulls are of quality materials I will re spray water repellent just to be suere. The capacity is quite large for its size I am quite pleased that I ordered these direct from the company . 20180925_112952.jpg
    BigCanoe, AZQKR, B7ACKTHORN and 4 others like this.
  17. Nanin
    Nanin Halfozze
    Nov 17, 2005
    411
    Valencia-Spain-Europe / Banora Point-NSW-Australia
  18. Ironhorse 332
    Ironhorse 332 Been here awhile
    May 6, 2018
    265
    Pennsylvania
    I want to see the guy that can flat foot on that bike.
  19. Eatmore Mudd
    May 28, 2012
    4,168
    Wet side of WA.
    This guy. He's a lumberjack. I think his name is Paul something or other.
  20. Coopdway
    Coopdway Curiouser Supporter
    Feb 21, 2006
    1,033
    Frontenac
