Royal Enfield Himalayan Owners Thread
Discussion in 'Thumpers' started by Anthiron, Sep 2, 2017.
  1. Dool
    Dool Been here awhile Supporter
    Jan 9, 2021
    964
    Australia
    Too slow to pick up clues, its been the Bane of my life, have trouble with Accents also :hide I actually thought the price was for an Air cleaner!
    I mentioned Cam ( not sure of tongue position ) I couldn't sell you a hole, anyhow:-)
    Doctor T likes this.
  2. zefnerd
    zefnerd Been here awhile
    Jan 11, 2020
    132
    US
    I believe it is plastic, it looks like Suzuki went to brass on newer models and superseded the part with the plastic there. Like I said, wouldn’t know if they are a real fit until someone compares them in person for a physical and electrical fit.
  3. zefnerd
    Jan 11, 2020
    132
    US
    I’m going to revisit this on my bike and try the newer recommendations as I am curious if there are settings on both sides of the factory recommendations or if mine (2019) responds to a different setting due to some variance. Glad your is fixed, I know I was elated when I addressed mine.
    Dread likes this.
  4. Kiwi59
    Kiwi59 Been here awhile Supporter
    Dec 7, 2019
    979
    New Zeaalnd
  5. Kiwi59
    Dec 7, 2019
    979
    New Zeaalnd
    Nice place to ride. Getting closer to better weather now and more time riding.
  6. gusthedog
    gusthedog Been here awhile
    Sep 15, 2008
    309
    Took my rear seat off and mounted a small dry box instead. Good spot to store tools etc.
    Made a quick bracket up out of some aluminium I had lying around and a cut down bolt for the latch. Works well.
  7. BarKnee
    BarKnee Been here awhile
    Feb 11, 2012
    734
    Portland, OR
    The leuheanrede recommendation is also the route I went, from factory .66V to .56. That seemed to eliminate most of the stalling problems with my bike, but didn't help the cold starts. With 1500 miles, iridium plug, and valve lash adjustment the bike starts and stays running with just the enricher now, but does occasionally fluctuate from 1300 to 1750 rpm when warm and idling, not sure whats up there.
    zefnerd and Dread like this.
  8. Dool
    Jan 9, 2021
    964
    Australia
    What Brand is the Pannier rack?
  9. BarKnee
    Feb 11, 2012
    734
    Portland, OR
    Yes, pretty good riding in the Pacific NW. Having the Himalayan will probably stretch out the riding season for me, but Dec and Jan are generally the catch up on maintenance months for me.
    Enjoy your approaching summer and hope you put up some pics.
  10. gusthedog
    Sep 15, 2008
    309
    It's the soft pannier rack from Hitchcock's. Can't deal with any weight off road but sits nice and close to the bike. Tends to bend inwards as it doesn't have a cross stay. Perfect for light loads or on road though. I have a cross braced set of racks here ready to go on when I get a minute.
    Dool likes this.
  11. Dool
    Jan 9, 2021
    964
    Australia
    High Lift Camshafts are available , via PM only :clap
    Solid blue is RWHP , the Broken Blue Line is Torque in foot pounds or "Butt Dyno", I am not Paid to comment on the Red lines.:rofl
    BillMcQuade and bomber60015 like this.
  12. CaptainTrips
    CaptainTrips Long timer
    Nov 16, 2019
    1,320
    Vancouver(ish)
    I pulled my OEM air cleaner cover off the other day and looked at cutting the snorkel off, but to be honest, I doubt that would make one bit of difference because the snorkel flairs out to an area that is much larger than the hole itself. And cutting the hole significantly larger would eliminate the flange that the air filter seals onto. So I cut out the two reinforcing fins inside the snorkel and left it at that.
  13. CaptainTrips
    Nov 16, 2019
    1,320
    Vancouver(ish)
    I would assume that the steps from BS4 to BS5 and BS6 may/will result in different optimum value ranges for each generation, especially considering the different euro spec emissions qualifications.
    zefnerd likes this.
  14. zefnerd
    Jan 11, 2020
    132
    US
    Oh, that’s clever. :)
    Doctor T, gusthedog and bomber60015 like this.
  15. zefnerd
    Jan 11, 2020
    132
    US
    Like you, it fixed most of my issues. Cold starts are good, it still needs a bit of babying for the first mile if I don’t give it several minutes warmup. I don’t have a high idling issue. For science, I’m going to try the newest recommendations and see if they further improve things.
  16. Beemerboff
    Beemerboff Long timer
    May 23, 2005
    3,896
    Adelaide, South Australia
    Well took the plunge and ordered a lift from Eastbound, the smaller of the two.
    Arrived today, Sunday! six days after I ordered , so DHL came good.
    Ratchet has 1500 whatever rating stamped on and is a lot thicker gauge than the Aldi 1000s I have.
    Strap is 2000 rated and again is much thicker than 1000 strap on the Aldi's.
    Impressed with the general quality and construction too.
    Very pleased with the whole deal, lets just hope I never have to use it!
    ToasTje and bomber60015 like this.
  17. ToasTje
    ToasTje Been here awhile
    Jan 5, 2021
    139
    West Flanders
    Did you just order the winch or some other stuff as well? I'm looking to buy the winch and tyre kit.
    Just found I'd made a mistake ordering the 'flashing brake' lights. When doing research on the bike, I'd found that some had replaced their brake light with an LED one that flashes 2 or 3 times at the start. So I ordered one cause the more visibility I am on the bike, the better imo.
    Whilst reading the manual I found out that the latest version (BS6) uses a LED unit for the tail light section. I'd say I would ship them to an inmate for free as long as they pay the shipping but it's probably cheaper to order them straight from Amazon. :s
    Dool likes this.
  18. Kiwithl
    Kiwithl Been here awhile
    Apr 10, 2021
    135
    Thl
    Thanks. I've been wondering about enlarging the air filter intake.
    With a stock engine and exhaust does anyone think there'd be any benefit in doing this?
    I am thinking probably not.
    What is the most restrictive part of a stock intake tract?
    Dool likes this.
  19. bomber60015
    bomber60015 Hold fast Supporter
    Sep 11, 2008
    80,655
    Chicago-ish
    Likely the air filter itself.
    increasing flow through the intake tract only won’t do very much for you. The air pump that is your engine would need intake, cam, and exhaust changes to gain much of anything. Add displacement, and now you’re talking.
    Of course, increases come at a cost: fuel efficiency, low end torque, engine life.
    it’s all a balancing act.
    little ackman, Dool and Kiwithl like this.
  20. Kiwithl
    Apr 10, 2021
    135
    Thl
    I wonder if anyone's fitted an after market camshaft with stock airbox,filter and exhaust? Without a power thingymajig?
    I'm sure the answer's already here somewhere, but where?
    Also, if there's only money and time for one modification what's best? Ok, opinions will vary and big bore is probably the answer. But other than that?
    I think I remember someone saying a free flowing exhaust?
    And others a 14 tooth front sprocket.
    I should look at some retailers and compare prices; exhaust versus sprocket I suppose.
    I know it's a Himalayan and it will never be a CCM... (and that's ok with me). (I think). (Um?)
