Royal Enfield Himalayan Owners Thread
Discussion in 'Thumpers' started by Anthiron, Sep 2, 2017.
  1. DaveJFLA
    DaveJFLA Cranky before Coffee
    Feb 14, 2005
    54
    Southwest Flatistan
    They have a couple in now, picked mine up yesterday
    Bar None likes this.
  2. RossoLinea
    RossoLinea Been here awhile
    Jun 27, 2018
    245
    SoCal
    I'm in Murrieta, just a little north of San Diego.
    Regards,
    Ken
  3. Bar None
    Bar None Long timer Supporter
    Mar 2, 2007
    15,754
    SWFL WNC
    I was at the dealer in Fort Myers FL a couple days ago and the salesman said that they have 4 2019s and I guess now 3.:clap
  4. Eatmore Mudd
    Eatmore Mudd Mischief on wheels.
    May 28, 2012
    4,168
    Wet side of WA.
    There most likely is. You could check McMaster-Carr, see what they've got. https://www.mcmaster.com/
  5. azgsa
    azgsa Dude
    Feb 11, 2008
    1,890
    Central Arizona
    After you posted this I looked at mine last night. The right one came out pretty easy. The swingarm pivot bolt tube doesn't have any kind of lip in the inside for the plastic cap 'tongs' to grab onto, and it's painted with the same greenish-tan primer stuff I've noticed under the paint on everything else that's steel on the Himalayan. There was a lump of the stuff just inside the tube which prevented my plug from seating well. I scraped off the lump then wrapped one round of plastic electrical tape around the plug 'tongs' to make the fit a little firmer in the hole and more 'grippy'. It's in firm now.
    Eatmore Mudd likes this.
  6. kokomoto
    kokomoto Adventurer
    Feb 11, 2004
    99
    Chattanooga, TN
    Would this be evidence of the leak that a few Hima owners have had a problem with? The pics are left and right side. The right side is dry. The left side, not so much.
  7. Bradster49
    Bradster49 Been here awhile
    Oct 28, 2018
    161
    Lille France
    Yesterday I contacted hitchcockmotorcycles.com and an engineer there confirmed that they are developing a big bore kit for the Himalayan in the way of a barrel and piston set that brings it up to 465cc that will be available soon. Combined with a powertronic system and a freeflowing exhaust quite a gain in the upper power band can be expected.Obviously no dyno figures or prices available at present but was it Mickey Thompson who said "The only thing faster than cubic inches is rectangular dollars" ?
  8. Treebone
    Treebone Been here awhile
    Jul 30, 2007
    265
    Wellington, Nevada
    That kinda sucks. How many miles on it? Do you ride it hard or easy? Inquiring minds want to know!
  9. dmusil
    dmusil n00b
    Jun 10, 2018
    5
    Reifs Mills Wisconsin
    Looks like the same leak I had. Snugged up the two bolts. Has not leaked since.
    Bojer, MrDralas and nathanthepostman like this.
  10. nathanthepostman
    nathanthepostman Been here awhile
    Apr 28, 2009
    903
    Mine weeped from there not long into ownership (although not as much) and the dealer just nipped up those two nuts. And that solved it.
    My head gasket did go a little while later mind. Fixed under warranty.
    MrDralas likes this.
  11. Loadtoad101
    Loadtoad101 Been here awhile
    Feb 28, 2017
    742
    Livingston TN
    Yes, mine starting leaking and I tightened up the two visible nuts but that did not solve the problem. I had to get to the head bolts and re torque them. Seems to have solved the problem but I need to put some more miles on it to be sure.
    Bojer, Eatmore Mudd and MrDralas like this.
  12. Loadtoad101
    Feb 28, 2017
    742
    Livingston TN
    That's the little bugger I lost. RENA is no use, ordered mine 2 months ago and haven't seen it yet. I tried the guy on Ebay and he never got back to me. I just sent him another email asking about it. I might have to make my own. The chrome one from Hitchcocks is the right item, but I think would look silly on a Himma!
  13. Loadtoad101
    Feb 28, 2017
    742
    Livingston TN
    Just finished up redoing my seat with the Seat Concepts high version of their seat. Had a real problem using 1/4" staples recommended in their instructions. Don't know if it was how short those staples are, or my electric staple gun, it pretty much just bounced off of the tough seat pan material. I went with 3/16 and I was barely able to make that work. I will probably have to tighten the seat up when we get some warm weather so the material will stretch, so I am going to get a air powered staple gun when I go to tighten things up.
  14. Loadtoad101
    Feb 28, 2017
    742
    Livingston TN
    Re the swing arm caps. Went out to measure the cap to see if I can find something that would work as a replacement. The one I have left just came off with barely any force at all. Hit it with a leg or a branch while riding and off it will come easily. The Inside diameter is 32mm, the outside 45.75 mm. I think I will attach mine with a little silicone sealant to keep them from popping off. Just went on Ebay and searched for round tube plug. Lots to choose from. The 32mm = about 1 1/8" or 1.259 inches. I think any in that size would work.
  15. ajpjive
    ajpjive Been here awhile
    Apr 1, 2015
    110
    Lansing, MI
    Still waiting to see about an ABS 2019, so no REH here to pull a swing arm cap off of. If someone can loan me one, I can 3d scan it or mock one up in CAD. We should be able to come up with a sturdier, more secure system--maybe a cap with an o-ring channel?
    Bradster49 and Eatmore Mudd like this.
  16. Loadtoad101
    Feb 28, 2017
    742
    Livingston TN
    Man, that would be sweet! That 3d technology is a modern wonder.
  17. CDRODA396
    CDRODA396 Adventurer
    Mar 18, 2018
    82
    North Carolina, USA
    Looking good! My weekend schedule is full, so today drove by the local auto/motorcycle upholstery shop just to see....they said $40, ready Monday, so I went ahead on passed it on to him. I cant wait to jump on it and ride, supposed to be in the 70's here next week!
    Loadtoad101 likes this.
  18. wolftrax
    wolftrax Long timer Supporter
    Sep 23, 2008
    1,057
    Blue Ridge Mtns Ga.
  19. Richarde1605
    Richarde1605 Long timer
    Jan 1, 2015
    12,077
    QLD Australia
    At the end of the day the himma delivers exactly what it says on the box.
    It is far too 'low' powered to people who want full weather protection and 100mph cruising speeds.
    But as enthusiasts like to tweak things it is a great example of a great base.
    Buy one, tweak one, enjoy one.
    JagLite, Matt TwoTired, azgsa and 4 others like this.
  20. DaveJFLA
    Feb 14, 2005
    54
    Southwest Flatistan
    Yep...I think 2 of the others were sold...need a free weekend from work to run up some miles...
