Royal Enfield Himalayan Owners Thread
Discussion in 'Thumpers' started by Anthiron, Sep 2, 2017.
  1. FarklePilot
    FarklePilot Been here awhile
    Feb 27, 2013
    413
    Vancouver Island
    Those brake and clutch numbers are "universal" as they refer to a "type" of lever. Don't get them reversed!! K25 Clutch and DK12 Brake.
  2. silentsnake
    silentsnake Adventurer
    Sep 15, 2018
    68
    Santa Clara CA
  3. Flicka
    Flicka Been here awhile
    Nov 24, 2018
    130
    Italy
  4. Bradster49
    Bradster49 Been here awhile
    Oct 28, 2018
    161
    Lille France
    I believe so Ken they are clever guys at Hitchcocks and have some exciting developments in the pipeline.
  5. rockt
    rockt Long timer
    Oct 13, 2003
    3,231
    Canada
    Very comprehensive write-up AZGSA. Any difference in the way the bike runs or performs? I hate all that extra wiring and plumbing.
  6. FarklePilot
    Feb 27, 2013
    413
    Vancouver Island
    I can report that after removing the evap canister the bike ran exactly the same. No improvement ( apart from the improved power to weight ratio:wink:) , nothing bad. Next is the air pump.
    Got to try and balance out the weight of the added Farkles!
    kitkat likes this.
  7. FarklePilot
    Feb 27, 2013
    413
    Vancouver Island
  8. azgsa
    azgsa Dude
    Feb 11, 2008
    1,888
    Central Arizona
    No difference noticed but I've only ridden it around the block a few times since making changes, just to make sure there weren't any issues. I don't expect any performance changes, especially from the EVAP system removal, but I've read about minor performance changes for air injection removal. The Hitchcocks page for their air injection delete kit says "This kit reduces exhaust popping on deceleration and backfiring typically associated with aftermarket exhausts. It also helps achieve true air/fuel ratio for fuel mixture tuning..."
    My primary reason for removal of this stuff is to reduce clutter and eliminate potential problem issues associated with a component/hose failure etc.
    B7ACKTHORN likes this.
  9. MtnGoat3
    MtnGoat3 Adventurer
    Feb 2, 2019
    29
    Northern NJ
    No worries my friend : )
    I was not trying to imply anything weird; just found it kinda of comical to see it in the picture w bike.
    Thx again for helping me with the adjustable levers.
    I looked on eBay and Amazon; they only seem to sell them as sets. So if I get set that fits KTM 390; or set that fits Ninja 250/300 will that work? Or do I need to purchase each one separately?
    Thx
    MtnGoat3:D
  10. Eatmore Mudd
    Eatmore Mudd Mischief on wheels.
    May 28, 2012
    4,166
    Wet side of WA.
    I had to buy a set of both and toss what I didn't need but that goes along with being the early adopter. The vendors have had to have sold enough of them for the Himalayan by now that contacting them and telling 'em you'd like one of each should work. Don't forget that you've got options depending on who you buy from. Long, short, angle adjustable ( like booatnuts levers ) colors, two tone etc.
  11. MtnGoat3
    MtnGoat3 Adventurer
    Feb 2, 2019
    29
    Northern NJ
    Thanks That's what I figured; that's why I asked again to be sure.
    I'm looking for Adjustable/Extendable; maybe even folding.
    Thx
    MtnGoat3
  12. kitkat
    kitkat Been here awhile
    Oct 3, 2003
    577
    california
    So no obvious differences in performance, have measured fuel consumption?
    And, has it triggered the “check engine light”?
  13. talmage
    talmage Adventurer
    Jan 27, 2015
    80
    Alexandria, VA
    I bought a similar pair from Amazon for about $15.
    It took 20 or 30 minutes to install them. I used a 14mm wrench on the nut that secures the mirror. I used a 6mm Allen wrench to secure the riser bolt to the mirror mount on the handlebar.
    While I had the toolkit out, I measured all of the Allen bolts I could find without taking the bike apart. I added that information to the wrench list I started in post #5951.
  14. FarklePilot
    Feb 27, 2013
    413
    Vancouver Island
    MTN Goat3 said:I looked on eBay and Amazon; they only seem to sell them as sets. So if I get set that fits KTM 390; or set that fits Ninja 250/300 will that work? Or do I need to purchase each one separately?
    As Mr Mudd commented, I specified to the seller what I would like, as in a "mix" of lever types. Admittedly they got it wrong first time. Sent me a brake lever for a cable type. Convinced if you send a message to seller PRIOR to ordering, laying out exactly what you need... DK12 brake hydraulic type "horn", K25 clutch ,cable type "horn". Horn refers to the part of the lever that has the pivot bolt go through it... The actual lever itself is somewhat universal.
  15. MtnGoat3
    MtnGoat3 Adventurer
    Feb 2, 2019
    29
    Northern NJ
    Excellent; thx for the pertinent info!
    What seller did you use?
  16. FarklePilot
    Feb 27, 2013
    413
    Vancouver Island
  17. MtnGoat3
    MtnGoat3 Adventurer
    Feb 2, 2019
    29
    Northern NJ
  18. MtnGoat3
    MtnGoat3 Adventurer
    Feb 2, 2019
    29
    Northern NJ
  19. FarklePilot
    Feb 27, 2013
    413
    Vancouver Island
    GT Motor Store
  20. FarklePilot
    Feb 27, 2013
    413
    Vancouver Island
    Do A Google search of "Store No.1750731" and it will come up... Ali Express.
