Royal Enfield Himalayan Owners Thread
Discussion in 'Thumpers' started by Anthiron, Sep 2, 2017.
  1. Loadtoad101
    Loadtoad101 Been here awhile
    Feb 28, 2017
    732
    Livingston TN
    Here it's showing $64 bucks for a bottle!
  2. Tromper
    Tromper Sagaciously Annoying Supporter
    Sep 26, 2009
    2,193
    Land O Drizzle
    I'm a fan of "Ride-On" myself.
    https://www.ride-on.com/
    I can verify that it does work on smaller holes, & no corrosion issues through a couple sets of tires.
    Their "No Weights" claim and "Longer Tire Life" I can't verify. I might be able to verify the later at some point this year though since I did just put a fresh set of tires on the burger and added Ride On pretty close to immediately.
    JagLite and CA Stu like this.
  3. kitkat
    kitkat Been here awhile
    Oct 3, 2003
    577
    california
    Thanks for posting this!!
    I can’t make out the part number and size, photo too fuzzy on my phone. Do you have a higher res photo or can you tyoe the part number?
    Thanks!!!
  4. Bradster49
    Bradster49 Been here awhile
    Oct 28, 2018
    161
    Lille France
    You are getting ripped off
  5. Loadtoad101
    Feb 28, 2017
    732
    Livingston TN
    Plug this into the search bar on Ebay: 261642267617
    The Seller Dangoodbuy list the part # as RFP138
    kitkat likes this.
  6. Loadtoad101
    Feb 28, 2017
    732
    Livingston TN
    Only if I buy it!
    azgsa, CDRODA396 and Richarde1605 like this.
  7. Bradster49
    Oct 28, 2018
    161
    Lille France
    Sorry to confuse I was speaking metaphorically
  8. Loadtoad101
    Feb 28, 2017
    732
    Livingston TN
    No problem, you didn't confuse me, my answer was tongue-and-cheek. :evil
  9. rockt
    rockt Long timer
    Oct 13, 2003
    3,203
    Canada
    Here's an interesting video riding a Himalayan after EVAP removal. Is this one of you guys? Seems to feel it enhanced performance a bit.
  10. cwadej
    cwadej Keeper of the truth
    May 20, 2008
    2,165
    San Diego, CA
    How would removing evap system improve performance?
    Landsurfer74 likes this.
  11. Vikingtazz
    Vikingtazz Will ride for food.
    Aug 15, 2010
    1,790
    Prescott Ontario, Canada
    Don't forget that's a left-hand drive version of the bike.
  12. Bradster49
    Oct 28, 2018
    161
    Lille France
    Right hand drive, he is in England. I saw this and questioned the possible advantage in performance myself.
  13. Loadtoad101
    Feb 28, 2017
    732
    Livingston TN
    I'm heading out to AZ and Calif next month to visit family and wanted to take my bike. My truck is a F250 with large tires and getting the Himma up in the bed alone was not very safe or much fun. A hitch carrier did the trick. Now I can easily roll the bike up on the rack safely by myself.
    IMG_20190208_165433543_HDR.jpg Carrier with some extra support to keep the rig from moving. Very solid with the turnbuckles.
    IMG_20190208_165526844_HDR.jpg The ramp lays across the supports just above the yellow chains and is held in place by the wing nuts and a safety pin. The ramp is 6' long.
    IMG_20190209_120049058_HDR.jpg Took it for a test ride, solid as a rock. Can't tell it's back there, no sag at all on the bed. Highly recommend this type of carrier for the Himalayan.
    EnduroAmerica likes this.
  14. mxz
    mxz Been here awhile
    Sep 11, 2015
    771
    That would be illegal in most of the civilized world. First, there are limits on weight you csn put on the frame of the car. Not sure what the rack is mounted to, but it needs to be able to support 4 times the weight of the bike. This is considering that the downward force of the whole thing will be multiplied if you, say, hit a pothole. Well let’s say yours is beefy enough as its fkin big, but second - you are covering the tail lights. In other words, they won’t see you braking :) maybe not an issue where you live, but most countries will have you pulled over for a load like this in no time :)
    lithodave likes this.
  15. Landsurfer74
    Landsurfer74 The road goes on forever.
    Nov 27, 2018
    122
    Rotherham. Coal Mining and Steel, now shame .....
    So a light board would be a good idea ?:hmmmmm
    My worry would be vertical axis G (VAG) experienced, 4g is a bit hopeful TBH . Looking at the moment arm measured from the front axle i would be a little nervous. The combination of front axle and rear axle moments would give wildly different VAG results but my bottom line .... 4g is not enough of a reserve factor.
  16. nathanthepostman
    nathanthepostman Been here awhile
    Apr 28, 2009
    903
    Dave Cooper here in the UK do bike racks that mount to the towbar plate. I had one to carry a CT110 around on a Ford Focus. Weight limit is about 130 kilos so mainly for scramblers, but I can't see how a sturdier set up mounted to a sturdier vehicle such as that pick up wouldn't take a Himalayan. As Loadtoad said though, just a pain in the ass getting it on sometimes.
    http://www.davecooper.co.uk/bike-racks/motorcycle-racks
    Bradster49 likes this.
  17. Loadtoad101
    Feb 28, 2017
    732
    Livingston TN
    Re: Bike carrier: Tongue limit on my factory installed hitch is #600 pounds, limit on the carrier is #600 pounds. Right now with wt of carrier and motorcycle i'm at #525 pounds. Led tail, brake, license plate holder with light are in the mail as we speak and will be installed prior to trip. I have read many reviews of the same carrier being used with heavier bikes with no issues. :*sip*
  18. LogHouseBikers
    LogHouseBikers Been here awhile Supporter
    Jun 20, 2010
    465
    Now in Middleburg (Jacksonville) Florida
    I see lots of cars, trucks, and RV's with bike carriers similar to this, some carrying Big HD's and Goldwings. As long as your taillights are clearly visable, or you put some on behind the bike, I think you are good. The REH is not too heavy, so probably OK.
  19. rockt
    rockt Long timer
    Oct 13, 2003
    3,203
    Canada
    I have the same type of hitch mounted rack and I've transported lots of bikes without catastrophic results. BUT, it does move around a bit, which is somewhat un-nerving. I've since added tie-down straps from the rack to the truck frame but I like LoadToad's chain and turnbuckle solution better. Might have to try that.
    With modern LED brake lights and the third high-mount brake light, the lights are still highly visible through/around the bike, at least with my truck and the naked-type bikes I've transported.
  20. Vikingtazz
    Aug 15, 2010
    1,790
    Boss hitch carrier and class IV hitch is good for 600lbs - no issues.
    My first trip to Moab was the same setup, but with an XR650L instead of the REH - that's a 7000km round trip.
    Mr. Goodkat and EnduroAmerica like this.
