Royal Enfield Himalayan Owners Thread
Discussion in 'Thumpers' started by Anthiron, Sep 2, 2017.
  1. Bradster49
    Bradster49 Been here awhile
    Oct 28, 2018
    161
    Lille France
    India is an amazing, diverse , beautiful place full of incredible people who exist within the greatest democracy on earth without as much structure as we have in the west which unfortunately gives them a mindset that enables them to make 'friday afternoon' vehicles etc all week. But I am happy to say things are getting better.
    BillO1s and Flicka like this.
  2. Mr. Goodkat
    Mr. Goodkat The Dude abides......
    Apr 19, 2017
    1,120
    Escanaba MI
    Could be! I'm not really worried about it but I read some things about it about 200 pages back so I figured I'd ask while the tank is off.
    I moved the hose a bit and thought about putting some electrical shrink wrap around the hose where it bends to see if that would help it hold it's shape vs twisting it kinking.
  3. workhorse
    workhorse Motorcycle as a medium of travel
    Jul 26, 2015
    708
    The mountains of the mid north coast NSW
    Friday afternoon vehicles all week
    Hmmmm
  4. stevenatleven
    stevenatleven Adventurer
    Nov 29, 2013
    67
    Scotland
    I have had rubbing issues as well and re routed and wrapped some of the wires in gorilla tape. Actually might take the wire frame off eventually. When you take the tank off there are a few wires that look particularly vulnerable to wear and damage.
  5. Mr. Goodkat
    Apr 19, 2017
    1,120
    Escanaba MI
    It's a good thing to look for and no bike or manufacturer is exempt from the possibility. Last May I picked up a new leftover 2014 VStrom 1k and one of the warranty recalls was too have the main wire harness under the tank relocated and wrapped in extra tape. There were a number of cases where the harness was rubbing through and grounding through the tank in as little as 5000 miles or less. 8200 miles later I haven't had a problem.
    With the tank off this is the perfect time to add a little protection. I don't care for electrical tape though. It never seems to hold well in my v experience. I've never used gorilla tape but I have something called "skaters tape" I think. It's pretty tough stuff, has good adhesion, and I think it would work well at protecting wires and hoses.
  6. thumpism
    thumpism Between bikes
    Dec 16, 2005
    7,682
    Richmond, Virginia
    True. My old Yamaha conked out a hundred miles from home and it turned out to be insulation on several wires passing through the headlight shell had rubbed through on the edge of the opening. Not too hard to fix once I figured it out.
  7. CNRED
    CNRED It'll be OK Supporter
    Feb 17, 2008
    1,034
    Scottsdale, AZ
    The wiring harness on my 1992 BMW GSPD grounded to the frame at the steering neck. Burned up the entire main wiring harness to a crisp. Turned out to be a boat load of work and the new harness was very expensive. When installing the new harness I used an extra portion of plastic harness sleeve in the suspect area and rerouted the harness to avoid the problem.
    If there is wiring chaffing, take care of it when you discover it, it does not get better by itself.
    Mr. Goodkat likes this.
  8. Flicka
    Flicka Been here awhile
    Nov 24, 2018
    130
    Italy
    If someone can, could take the size of the needle bearings on the swing arm?
    I'm looking for an alternative to OEM spare parts.
  9. MrDralas
    MrDralas Super n00b
    Sep 26, 2018
    632
    North of somewhere
    On the Himalayan it’s no problem to do, with the stock tires. Can even patch the tube with out removing the rim.
    29C462CA-1CE0-487B-BA6A-A6AAA4FB03B8.jpeg 14F376F2-8394-4332-8817-81CB10763E71.jpeg
  10. Oilhed
    Oilhed MarkF Supporter
    Oct 17, 2003
    16,230
    Connecticut
    Nice. Those panniers look familiar. Are they just rebranded or some cheap knock-off?
  11. Oilhed
    Oct 17, 2003
    16,230
    Connecticut
    Quick question. Can you easily remove the rear luggage rack & passenger seat?
    How does it look? Anyone have a photo without the rack & pillion?
  12. UPMotoTouring
    UPMotoTouring Adventurer
    Oct 12, 2018
    25
    Negaunee, MI
    I'll be doing some electeical work on my Hima in the next week, and I'm planning on using gaffers tape for any securing/reinforcement. Duct tape strength without the mess and is used in media for taping down wires. Matte black.
    If you get some, don't skimp on quality. You might turn into a tape-nazi when your wife decides to use it for menial tasks. Not that I have experience.
    JustMikey and Eatmore Mudd like this.
  13. Mr. Goodkat
    Apr 19, 2017
    1,120
    Escanaba MI
    I'm new to the bike but I have the seat and tank off now. The pillion is actually released with the key first then the main saddle comes off. I think a custom cover would have to be made that uses the latch pin from the pillion seat so it can cover the pillion location and still hold down the main saddle.
    I'm not sure about the rack and haven't looked closely as how to remove it.
  14. Mr. Goodkat
    Apr 19, 2017
    1,120
    Escanaba MI
    I'm going to try the gorilla tape and today I'm going to the store that carries it anyway. I'm sure both gorilla and affers are better than electrical tape.
  15. Eatmore Mudd
    Eatmore Mudd Mischief on wheels.
    May 28, 2012
    3,980
    Wet side of WA.
    Tail rack comes off with our bolts. It'd look funny without the passenger saddle, there's a tool tray molded in the fender underneath it.
    I don't think they are rebranded. If they were the price should be higher. They are very good quality. And the aluminum is 2.5mm thick with stainless hardware. I think we're safe to call them a good close copy.
    AZ Mtn Girl and Oilhed like this.
  16. Kiwiscoot
    Kiwiscoot Been here awhile
    Feb 14, 2010
    714
    Christchurch, New Zealand
    Get some of the spiral wrap. Excellent to help with chafing of wires. You can get it in black too. Built missile harnesses with this stuff in my day. Nothing as harsh as the aviation or marine environment.
  17. RossoLinea
    RossoLinea Been here awhile
    Jun 27, 2018
    245
    SoCal
    Here's a photo with the rack removed:
    I've also made a tray to replace the passenger seat but don't have a handy photo.
    Regards,
    Ken
    Davethestick, Tomocan, Oilhed and 2 others like this.
  18. sdbruns
    sdbruns Potemkin villager
    Jun 13, 2007
    2,071
    Summerland
    White ones ARE the fastest.
    AZ Mtn Girl likes this.
  19. Mr. Goodkat
    Apr 19, 2017
    1,120
    Escanaba MI
    Where do you normally get that?
  20. RossoLinea
    Jun 27, 2018
    245
    SoCal
    Anyone want to guess what this is?
    Regards,
    Ken
