Royal Enfield Himalayan Owners Thread
Discussion in 'Thumpers' started by Anthiron, Sep 2, 2017.
  1. OzzyRider
    OzzyRider Adventurer
    Dec 10, 2017
    10
    Brisbane
    Now a proud Himalayan owner, too. Only done 500 km so far but absolutely love it. The handling is fantastic (kudos to Harris Performance Engineering, they clearly know what they're doing!) and the engine is sweet - surprisingly smooth for a thumper. Although it's not a powerful engine, I like its low down torque which makes for a very relaxed ride. In fact, the word 'relaxed' sums up the bike's character very well.
  2. OzzyRider
    Dec 10, 2017
    10
    Brisbane
    The only negative so far was wind buffeting. I'm 5' 9" and it hit me straight on the visor. Since the windscreen is cheap to replace I decided to cut it off. I took me several hours of sawing, filing, sanding (first P40 then FL212P then P600) and polishing with Brasso, but I think the result looks OK. Now my head is in clean air while still no pressure on my chest.
    steeve, balt, LoneStarGazer and 7 others like this.
  3. Eatmore Mudd
    Eatmore Mudd Mischief on wheels.
    May 28, 2012
    4,167
    Wet side of WA.
    Heck of an entry!
    Welcome to the Asylum.
    Richarde1605 likes this.
  4. OzzyRider
    Dec 10, 2017
    10
    Brisbane
    I did manage to download the Service Manual for the BS3 (carburettor) model here. Surprisingly though, this version doesn't contain any information on engine maintenance (e.g. valve adjustment, cam chain adjustment, oil change procedure, etc.). In every other respect it is comprehensive, and I wonder whether there's a separate manual just for the engine. I've contacted Royal Enfield regarding this.
    Eatmore Mudd likes this.
  5. Richarde1605
    Richarde1605 Long timer
    Jan 1, 2015
    11,630
    QLD Australia
    Welcome, a well behaved friendly puppy is how I describe mine :-)
    Sent from my SM-G950F using Tapatalk
  6. Eatmore Mudd
    May 28, 2012
    4,167
    Wet side of WA.
    How tall is that wind screen ? Nicely done BTW.
  7. Richarde1605
    Jan 1, 2015
    11,630
    QLD Australia
    Looks good from this angle...
  8. macmotor
    macmotor Whiskey Dick
    Jun 18, 2008
    138
    Fort Fun
    Unique rides moved to Loveland, they are down by the Sonic and walmart on Denver ave.
    I also heard that a while back RE re structured their dealer ship requirments when they got a new NorthAmerican rep etc.. that wasnt favorable for a lot of dealers that were not moving a lot of bikes. They bummped the order numbers etc..
    Eatmore Mudd and eakins like this.
  9. eakins
    eakins Butler Maps
    May 29, 2002
    38,942
    Fort Collins, Colorado
    Did you consider adding a Laminar Lip or MRA Airwing before you cut the screen down?
  10. eakins
    eakins Butler Maps
    May 29, 2002
    38,942
    Ah thanks.
    The reps at the IMS sounded desperate to have a Colorado dealer and yet they bump their dealer. I don't think many RE sell anyway but this bike could change the landscape for them.
  11. eakins
    eakins Butler Maps
    May 29, 2002
    38,942
    Does the screen have a 2 angle position adjustment?
    I see a 2 hole above that rear screw.
    Can you move it more upright?
  12. OzzyRider
    Dec 10, 2017
    10
    Brisbane
    Yes you can, but the more upright position made the buffeting rather worse for me. I'd like to add though that how much buffeting one experiences very much depends on one's height and helmet. I'm 5' 9".
  13. eakins
    eakins Butler Maps
    May 29, 2002
    38,942
    Did Harris redo the suspension?
    Upgrade valving, springs?
    I assume the stock suspension is basic.
  14. Richarde1605
    Jan 1, 2015
    11,630
    QLD Australia
    Yes you can, I found with my helmet more buffeting in the forward/higher position. YMMV
    Fitting handguards means you need to move the screen to the forward position.
    I am still deciding which way I'll go...
    eakins likes this.
  15. Richarde1605
    Jan 1, 2015
    11,630
    QLD Australia
    Suspension is basic, same for every market as far as I can tell.
    It suits the nature of the bike quite well.
    Harris did the frame and basic layout it seems. Components woud have been chosen on a cost basis, one of the Ozzy owners is getting a new rear shock built...
    eakins likes this.
  16. Eatmore Mudd
    May 28, 2012
    4,167
    Wet side of WA.
    Harris designed protyped and tested and developed and refined it at thier facility in the UK for RE. Then they tested it some more in the real world and made tweaks .
    eakins likes this.
  17. mettalique
    mettalique Been here awhile
    Dec 31, 2012
    423
    Mt Mee, QLD Australia
    If you want to fit Bark Busters you will need to shift the screen to the more forward position for clearance
  18. remzamora
    remzamora Adventurer
    Nov 6, 2014
    39
    Wind deflector and barkbuster installed. [​IMG]
    Sent from my ONEPLUS A3000 using Tapatalk
    wilfred, cyclopathic and Eatmore Mudd like this.
  19. cyclopathic
    cyclopathic Long timer
    Dec 23, 2007
    9,584
    Does anyone know if Racetech GVE or similar would fit? It's a damping rod fork, correct?
  20. Eatmore Mudd
    May 28, 2012
    4,167
    Wet side of WA.
    Stop reading my mind. :D
