Royal Enfield Himalayan Owners Thread
Discussion in 'Thumpers' started by Anthiron, Sep 2, 2017.
  1. wolftrax
    wolftrax Long timer Supporter
    Sep 23, 2008
    1,049
    Blue Ridge Mtns Ga.
    Well what are you waiting for, let's see em!
    Sent from my KFAUWI using Tapatalk
  2. Vikingtazz
    Vikingtazz Will ride for food.
    Aug 15, 2010
    1,743
    Prescott Ontario, Canada
    Eatmore Mudd, JBeK and voodoochilled like this.
  3. Vikingtazz
    Aug 15, 2010
    1,743
    CR Hi bend replacement:
    Eatmore Mudd and JBeK like this.
  4. voodoochilled
    voodoochilled Been here awhile
    Dec 26, 2017
    125
    Rochester, NY
    Thanks Vikingtazz! Good to know. Did you end up replacing your stock bars with this then? I’m guessing so from the picture you posted above.
    Eatmore Mudd likes this.
  5. wolftrax
    Sep 23, 2008
    1,049
    Blue Ridge Mtns Ga.
    Did my second service at 3681 miles. Both the intake and exhaust clearances were in spec with the intake @ .08mm so I backed it out to .10mm. The exhaust hadn't moved at all @ .25mm. Had 1 bent spoke which I removed and straightened and other than that nothing out of the ordinary. I'm pleasently surprised how well this bike is built.
    Thought I'd add a bit more wind screen. I had a Laminar Lip left over from a CB500X so I threw it on Sherpa. Haven't tested it yet. Also installed a USB volt meter to charge my GPS.
    Got an email from Seat Concepts saying they should have two seats for the Himalaya in about 6 weeks. A standard and a tall. [​IMG][​IMG]
    Sent from my Moto G (4) using Tapatalk
  6. Vikingtazz
    Aug 15, 2010
    1,743
    JBeK likes this.
  7. Vikingtazz
    Aug 15, 2010
    1,743
    Yessir - turned good ergos into great ergos.
  8. wolftrax
    Sep 23, 2008
    1,049
    Blue Ridge Mtns Ga.
  9. Vikingtazz
    Aug 15, 2010
    1,743
    Look what came in the mail today :-)
  10. wolftrax
    Sep 23, 2008
    1,049
    Blue Ridge Mtns Ga.
    Nate, would you mind sharing your impressions of the RE hard panniers. Going to do Africa next year and thinking the security of hard boxes might be a good investment. The OEM boxes look good but just wondering if you think they are up to the rigors of overland travel.
  11. FredRydr
    FredRydr Danger: Keep Back 300 Ft.
    Aug 16, 2005
    4,301
    Carlisle Pennsylvania USA
  12. JBeK
    JBeK Been here awhile
    Apr 3, 2018
    779
    Ohio
    I think the K&N filter is designed to be airflow from outside of "cylinder" to inside which is reverse of the stock RE filter design. Not sure how well the pre-filter sleeve would work in the RE setup...
    Do you think it will work OK?
  13. JBeK
    Apr 3, 2018
    779
    Ohio
  14. Vikingtazz
    Aug 15, 2010
    1,743
    Another really nice thing about FI - it will work great even with the change in air flow.
    The pre-filter should be a solid option for dusty environments and would still pass more air with the K&N than the stock unit.
  15. Richarde1605
    Richarde1605 Long timer
    Jan 1, 2015
    10,480
    QLD Australia
    I don't think that the stock paper a/f limits flow in any way, it is larger than some bikes making much more hp. Also I don't trust oiled fabric filters on off biased vehicles, in my experience there is always a fine coating of 'dust' downstream of them, even on my mx6 canam that draws air around the steering head, probably the cleanest place...
    The standard cat con would probably be one of the major limitations on flow, then possibly the mild cam and carby size, eventually I will probably make a rough copy of the header pipe and see what if any benefits are there, then pull the head and check for a nice three angle valve job, and perhaps clean up the ports. A slight skim to bump up the comp ratio a bit would yield slightly more efficiency. But I doubt much more could be done without compromising the lovely flat power delivery.
    Though it would be fun to see just how much you could get out of an LS410, no doubt someone will go all out on one, then we can pick and choose which mods to make that suits us, much like how you build established engine designs, you decide the power, and the delivery, then bore or stroke, valve sizes cc the chambers whack in the cam and get exactly what you want.
    I don't see the himma as a race bike, but as the engine is so smooth, it would suit a road based bike also, probably not many people thought that a two smoke dirtbike motor by Bultaco could be a road and racebike in the Metralla.
    Anyhow end of my random ramblings...
    for the moment
    Sent from my SM-G950F using Tapatalk
  16. nathanthepostman
    nathanthepostman Been here awhile
    Apr 28, 2009
    903
    I've been impressed to be honest, especially for the money. I'm not sure of the gauge, maybe 1.5mm side walls, but they feel as sturdy as a Krauser, Givi or SW Motech pannier and I like that they've been tucked nice and tight to the bike, so they're well within the handlebars. The sloping corners are a bit annoying as it means that the base of the pannier isn't flat, so you do lose some packing room. I had Metal Mules on my GS and I liked that they were square cornered but that's just the way it is. I've not dropped the bike with them on yet and I suppose that'd be the ultimate test, but I did have them on when doing some trail riding and they remained secure and didn't flap around. I have thought about some soft luggage but to be honest I do like the convenience of aluminium panniers for road based travelling. I personally wouldn't be too worried about soft luggage in Africa though. I think most theft is opportunism - say if you leave something on your seat - so I'm sure you'd be alright. It's in Europe at the minute where you're more likely to have your luggage stolen, and the bike for that matter! Tonnes of bike crime in London sadly.
    Eatmore Mudd and Richarde1605 like this.
  17. wolftrax
    Sep 23, 2008
    1,049
    Blue Ridge Mtns Ga.
    Thanks for the reply. I traveled Southern Africa in 2008 via Cape Town with nothing more than a Giant Loop Great Basin. Had zero security concerns. This trip however I will ship to LHR and travel through Europe before turning South to the dark continent. Thanks for the warning about theft in Europe. One of the great ironies of travel, security in developing nations can be less of a concern than first world nations.
    Bkadv2 likes this.
  18. beer_in_beard
    beer_in_beard Adventurer
    Jun 1, 2018
    21
    Muncie, IN
    @wolftrax I just installed the RE Panniers on mine last weekend, haven't traveled with them loaded yet, but I agree with @nathanthepostman they seem very solid. Good locking mechanism and 4 keys :) I did have a little trouble on the right pannier, the clearance for the rotating part that locks the pannier to the rack didn't have enough clearance between the rack mounting screw and the rack (see pic), but I was able to get it in by placing the part in place first, then attaching the pannier. left side had just enough clearance to rotate the piece into place.
  19. voodoochilled
    Dec 26, 2017
    125
    Rochester, NY
  20. voodoochilled
    Dec 26, 2017
    125
    Rochester, NY
    Ordered. I'm going to try swapping out my stock handlebar with this over the weekend and see if it fixes my misalignment issue. Thanks for the tip.
