Royal Enfield Himalayan Owners Thread
Discussion in 'Thumpers' started by Anthiron, Sep 2, 2017.
  1. FEG32
    FEG32 Too old and fat for any of this.....
    Aug 23, 2010
    307
    Cincinnati, OH
    My Himalayan has had an annoyingly weak idle and would stall several times until finally warming up. Took it to a local dealer here locally and their “fix” was to crank the TPS all the way up and call it done. I undid that mess and installed a Booster Plug and am happy to say it completely fixed the issue. Bike always seemed a little lean and the Booster Plug was just the ticket.
  2. Loadtoad101
    Loadtoad101 Been here awhile
    Feb 28, 2017
    653
    Livingston TN
    Took my Himalayan to the Hatfield McCoy trails in Southwest West Virginia in my cargo trailer toy hauler conversion. Rode with a couple of KTM 690s and some hondas. The bike did fantastic, me not so much.
    Part 1
    Part 2
    LogHouseBikers and Kiwiscoot like this.
  3. Scottyhumbucker
    Scottyhumbucker Adventurer
    Jul 19, 2020
    37
    Sacramento
    Indeed. You’ll also notice lean surge at mid RPM steady throttle gone.
    FEG32 likes this.
  4. FEG32
    Aug 23, 2010
    307
    Cincinnati, OH
    I took it out for about 60 miles today, so much better. Especially in the 25-50 mph range just putting along.
    GeeMan67 likes this.
  5. ScottFree
    ScottFree Been here awhile
    Jun 7, 2011
    573
    Ill-Annoy
    Remember how some people removed the master links in their chains and found bad wear because the link hadn't been lubed when the chain was installed at the factory? Remember how we all pledged to check ours to make sure this wouldn't happen to us? And then some people who shall remain nameless forgot all about it?
    (Raises hand ruefully)
    Luckily, I didn't find this out by having the chain break along the road; I was brushing off the dust from the afternoon's gravel-road rides (while thinking mostly about the damn "turkey start" gizmo on my boat, which has been acting up), and noticed a lot of powdered rust around the master link. So, I popped off the clip, slid the link out (keeping the chain on the sprocket for convenient reassembly) and found... not a speck of grease inside the rollers, a modest amount of rust powder, and about ten percent of the pin worn away. For now, I cleaned everything up, greased the pins with good ol' Harley wheel bearing grease (the first thing I found on the shelf), and put it back together. I think the chain is still good for 3-4000 miles (it's starting to show uneven wear), but I should probably replace the master link. So where do I get one...? The stealership? I can try when they open on Tuesday, but given they ordered an air filter for me in mid June and it still hasn't come, I'm not expecting them to have one in stock. Found an "RK Racing 525 X-ring" master link on Amazon; fifteen bucks but free overnight shipping. Will any 525 clip-style master link work? Does it have to be O-ring style? Suggestions welcome.
    Doctor T likes this.
  6. Scottyhumbucker
    Jul 19, 2020
    37
    Sacramento
    I read this entire thread beginning to end. Some folks said Booster Plug did nothing. Others dug it. Glad it worked out for you as well. Mine ran so lean it was terrible. I checked the vent tube to the EVAP, mine was not kinked. I do suspect that my EVAP system will “fall off” soon. I’ve got 900 miles on mine now and I’m also noticing it seems to be breaking in nicely. Getting ready for a 400 mile R/T from Sacramento to Reno via Henness Pass in October. All back road/off road. This bike forces you to find the scenic routes.
    Kiwiscoot and FEG32 like this.
  7. BurnieM
    BurnieM Long timer
    Sep 24, 2003
    4,376
    Sydney, Australia
    Hitchcocks were recommending a JT master link as replacement for the standard link.
    I bought a couple as spares (but I am probably no closer to you than Hitchcocks).
    https://accessories.hitchcocksmotorcycles.com/s.nl?ext=F&sc=1&category=&search=Himalayan chain link
  8. CaptainTrips
    CaptainTrips Been here awhile
    Nov 16, 2019
    558
    Vancouver(ish)
    If shopping online, look for a link that says 525 "standard" in the name. I made the mistake of ordering a 525 link that turned out to have proprietary pin diameters, meaning that it would seize if I tried to force it onto the chain.
  9. FEG32
    Aug 23, 2010
    307
    Cincinnati, OH
    I feel like the folks that said it did nothing were looking for benefits it wasn’t going to provide. It added just of enough of a slight boost in mixture richness to solve my bikes issue. For me it was worth a shot. As for breaking in mine was crazy loud for the first couple hundred miles, the engine almost “rang”. it has quieted down nicely. I’m extremely happy with it. It reminds me of my old KLR but with a better seat and I don’t need a stepladder to get on it
    CaptainTrips and Scottyhumbucker like this.
  10. kitkat
    kitkat Been here awhile
    Oct 3, 2003
    560
    california
    Lighting update:
    One of my cheap led accessory lights died a second time so I figured they're too cheap and ordered a single light bar,
    https://www.amazon.com/dp/B00NPQUYM0/ref=twister_B07JG6X793?_encoding=UTF8&psc=1
    It illuminates the path in front better than the two lights did and it turns with the forks so that's another plus. Hopefully it lasts a reasonable amount if time.
    In place the two lights I removed I'd like to find a pair of yellow fog lights. If anyone knows of a solid little light, 2" or there about, that's inexpensive please let me know!!
  11. Kiwi59
    Kiwi59 Been here awhile Supporter
    Dec 7, 2019
    270
    New Zeaalnd
    TEC bikes in the UK also recomend them for the reason you descride. Welocme to the club. have read the forum as well when I joined. Lot more posts and tips on here now. Enjoy the new ride.:clap
  12. Kiwi59
    Dec 7, 2019
    270
    New Zeaalnd
    Sorry that hot grips did work, have them on two bikes. I set is 8 years old now and still working ok and 2nd on the Himma and also fine. Maybe you just got a dud set.
  13. Doctor T
    Doctor T Gruppy old git
    Apr 2, 2019
    575
    Sussex UK
    I bought 2 master links from Aliexpress for £2.50 each. Only bought for on road emergencies to get me home. There are the standard "O" ring type. Ive had to use one already due to rust on the original link. Again no grease in sight. Anyway, the cheap link has lasted 560 miles since fitting so far.
  14. sam2019
    sam2019 Been here awhile
    May 1, 2019
    452
    India / Germany
    no too small but very bright. I use only one on the left side and its enough.
    https://www.amazon.in/gp/product/B084R9FLBN/
    kitkat likes this.
  15. LogHouseBikers
    LogHouseBikers Been here awhile Supporter
    Jun 20, 2010
    456
    Now in Middleburg (Jacksonville) Florida
    Enjoyed the videos! Thanks for sharing!
    Loadtoad101 likes this.
  16. kitkat
    Oct 3, 2003
    560
    california
  17. sam2019
    May 1, 2019
    452
    India / Germany
    You said cheap. mine are 6 bucks, yours are 60...
    however, I think I recognize your selection and basically they are less bright than mine, I had them on my Bullet years ago. also cheap china stuff and those numbers, well, my flashlight has 2000 lumen and is brighter than those.
    I may be wrong though, one never knows what LED is used inside the housing. I have seen absolute identical looking LED headlights and one was very bright and the other only 10% of that, big price difference too.
    kitkat likes this.
  18. sqeeezy
    sqeeezy Been here awhile
    May 12, 2019
    233
    Southern Spain
    I've posted already, and warned youse-all, as if I was someone who knows this stuff..."with these masterlinks, we're doomed!" (in Scots accent). I'd suggest doing what I did after two chains ended up with dried-up masterlinks, and that is move up tech-wise to the 20th century (sic) and install a rivetted link, and a good quality chain, and a Tuturo oiler. I used my nasty cheapo eBay chain tool and it wasn't too difficult to upgrade. Over the RHS of the pond there's loads of bike places sell chains and masterlinks so I s'pect in the US there will be too. Good luck and don't overtighten when you flatten the rivet, enough's enough.
  19. kitkat
    Oct 3, 2003
    560
    california
    I know, LED's are a gamble!
    The size, shape and mounting are important to me and I know I said cheap but everything cheap is too big!
    This link are the ones that I had up until now, they don't last!
    https://www.amazon.com/dp/B00SNX6E60/ref=twister_B07FNN6YX5?_encoding=UTF8&psc=1
    I like the size and shape and they mount directly to the tank's crash bar without using the bracket. Their form factor is perfect - but they fail so they suck!
  20. Doctor T
    Apr 2, 2019
    575
    Sussex UK
    Just cleaned my chain and my budget master link is stamped JT. Can't see the price on Hitchcocks site but i bet they cost over the £2.50 each delivered i paid. I always look at their site and search for the same item elsewhere. Research always pays off.
