Rusty axle nuts
Discussion in 'The Garage' started by dtysdalx2, Sep 10, 2019.
  1. dtysdalx2
    dtysdalx2 Knowledge is horsepower...
    Aug 1, 2004
    23,663
    Moneyapolis, MN
    I have a Jeep GC 2011 and the OEM wheels kept water in the nut area and turned the threads and nuts into rusty junk. Stubs even. :eek7
    Anyone have one repaired and have an idea what is involved? Mine are fine as of now but. A hub will probably fail tomorrow with my luck.
    This is what I have to deal with. I hosed it down with WD-40 gel.
  2. dtysdalx2
    Aug 1, 2004
    23,663
    Moneyapolis, MN
    No help huh? I thought so. :photog
    Well it sucks to be me. Probably needs to be torched off.
  3. shovelstrokeed
    shovelstrokeed Long timer
    Jun 20, 2003
    5,708
    6South Florida
    3 hrs, not very patient are you. A sparkle wrench will work but it doesn’t look like you tried very hard.
    Boatman and SmittyBlackstone like this.
  4. dtysdalx2
    Aug 1, 2004
    23,663
    Moneyapolis, MN
    Never heard of a sparkle wrench. :dunno
  5. A_Vasiliev
    A_Vasiliev Red, white and blue.
    Dec 7, 2007
    1,489
    Voronezh, Russia
    I think a "sparkle wrench" is an angle grinder :lol3
  6. dtysdalx2
    Aug 1, 2004
    23,663
    Moneyapolis, MN
    :D
  7. Slowklr
    Slowklr Attempting to fall in style
    Jul 20, 2019
    60
    Texas
    I'd give it a shot with a breaker bar after cleaning the chunks of rust off.
  8. shinyribs
    shinyribs Thumpers for life
    Sep 24, 2011
    4,826
    The South
    Slather it with penetrating oil of your choice and heat it very well with a torch before even attempting to loosen it. Looks like it's so rotten that, even if the nut does come off, there's not enough material left to hold it all back together. But you never know
    Good luck, man. But that looks like a goner to me :(
    #8
    Whodatschrome likes this.
  9. 1greenmachine
    1greenmachine Long timer
    Aug 28, 2010
    3,935
    green bay, wi
    Wire brush wheel it as clean as possible, throw away the wd40 and use knocker loose or any quality penetrate fluid. When you go to finally take it apart slather as much grease on the threads as you can and once you start dont stop.
    If all the fails then burn it down.:hide
    #9
    ohgood likes this.
  10. shovelstrokeed
    Jun 20, 2003
    5,708
    6South Florida
    Sparkle wrench is a cutting torch, dummies.
    #10
    mitchapalooza, dtysdalx2 and Beezer like this.
  11. Beezer
    Beezer Long timer Supporter
    Oct 26, 2004
    9,377
    Anchorage, formerly Spenard (hub of the universe)
    you can try wrenching it off but I wouldn't waste a lot of time on it. one hint of stubborn and I put the fire ax on it. those spindles are shot so nothing to fuck up.
    edit: posting same time as you mr Shovel.... I know what you meant... we're talkin the same tool...
    #11
  12. The.Cheese
    The.Cheese Adventurer
    May 28, 2018
    34
    North Georgia
    So you're not trying to get it apart because somethings broke? You're just worried its too rusted? Leave it be then. Deal with it when its a problem.
    #12
    MotoChris521 likes this.
  13. 1greenmachine
    Aug 28, 2010
    3,935
    green bay, wi
    Maybe down south, everyone I've ever talked to calls it a smoke wrench
    #13
    dtysdalx2 likes this.
  14. Slowklr
    Jul 20, 2019
    60
    Texas
    Or blue wrench.
    #14
    Ducky 149, katbeanz and 1greenmachine like this.
  15. AviatorTroy
    AviatorTroy Long timer
    Oct 15, 2007
    2,413
    Castle Rock, CO
    There is a lot of scale there and you might be surprised what’s still left. Absolutely wire wheel the hell out of it, give it a 24 hour soak with really good penetrating oil like Kroil, and then a little heat and an impact wrench will bust that right off.
    No need to use a cutting torch, that’s crazy talk!
    #15
  16. anonny
    anonny What could go wrong?
    Mar 20, 2007
    6,722
    Beautiful Revelstoke BC
    Wire brush, your choice of penetrating oil, heat and beat.
    #16
  17. Bounder
    Bounder Typing...
    Mar 2, 2011
    1,997
    West Cork, Ireland
    Needle gun and some earmuffs and a dustmask will let you know what you are dealing with.
    I haven't found wire wheels to be very useful dealing with scaled corrosion like that, its too hard and the wire just polishes the rust flakes.
    #17
    shinyribs, Boatman and dtysdalx2 like this.
  18. ohgood
    Sep 21, 2010
    9,679
    alabama
    dremel a slot on either side, the nut falls off.
    then drill a hole or two in the wheel (or hub) to let the water out
    #18
  19. dtysdalx2
    Aug 1, 2004
    23,663
    Moneyapolis, MN
    #19
  20. dtysdalx2
    Aug 1, 2004
    23,663
    Moneyapolis, MN
    Urban Dictionary sez...
    ¯\_(ツ)_/¯
    Sorry, we couldn't find: sparkle wrench
    #20
    1greenmachine likes this.
