Said goodbye to Locus, what are your recomendations for a replacement?
Discussion in 'GPS 101 - Which GPS For Me' started by Eatmore Mudd, Mar 21, 2019.
  1. Eatmore Mudd
    Eatmore Mudd Mischief on wheels.
    May 28, 2012
    3,471
    Wet side of WA.
    Locus Pro is being a D!@K. I switch off the permissions and force stop the app between uses then switch them on and launch it when I use it same as all the other apps.
    Now they have a new EULA and want access to everything all the time including body sensor data. ( that will eat battery run time )
    Worse yet is that they went into my note pad app and into my text messages and censored all my LAT LONG information right out of text messages sent in the past and the notes I was keeping it in. ( dirty sneaky underhanded move on their part)
    There is no way to use the Lucus Pro and add ons that I bought and paid for to use unless I agree to the new EULA. That's extortion imho.
    I uninstalled it.
    What are your recommendations for a replacement ?
  2. webmonstro
    webmonstro A Aventura Continua....
    Jul 21, 2008
    1,134
    Portugal
    Just use the old version
  3. ohgood
    Sep 21, 2010
    9,693
    alabama
    1 use the old 3.6*** version you were using, if you don't agree to the eula of the newer version.
    2 nothing is hostage, you can access ALL the files locus has created for you, they're either in /data/app/com.android.menion.locus
    or
    on your sdcard.... you can use all the database, map, tracks, as you see fit without the application or its eula. I'm still trying to find the 3.6xx and 3.7xx eula to see what has changed, i think I'll need to install the free versions to do so.
    just so you know, the battery life will not be impacted at all by using the sensors on the phone... they are on and active all the time unless specifically turned off, the locus app just logs (with your permission) what they're saying if you tell it to.
    the cheapest alternative is 1 use the old version
    the next cheapest is oruxmaps, osmand, or similar.
    i hope you understand the issues with forse closing applications, and how it will corrupt/destroy data by doing so.... it's a bad practice that will lead to issues that you listed in the locus thread.
  4. worwig
    worwig Long timer
    Nov 30, 2009
    1,947
    Hog Mountain
    :imaposer
  5. clawdog60
    clawdog60 Long timer
    Feb 21, 2013
    2,747
    east central ILL, land of ILL (sick)
    You just think that it’s uninstalled. You opened the door.
    worwig likes this.
  6. PNWet
    PNWet Been here awhile
    Nov 2, 2014
    938
    Puget Sound, WA, USA
    Trail Tech Voyager Pro, not an app, but a worthy replacement.
    clawdog60 likes this.
  7. PineLaneRider
    PineLaneRider Long timer
    Dec 25, 2016
    1,059
    Between Michaux and Tuscarora State Forests
    ^ $600 GPS unit v $5 app...? :hmmmmm
  8. PineLaneRider
    Dec 25, 2016
    1,059
    I guess what app you chose is determined by what you use it for. I use Google Maps for A-->B online directions and Guru Pro (Galileo) for offline and track following.
    #8
  9. ohgood
    Sep 21, 2010
    9,693
    alabama
    oruxmaps is pretty dang good, not as polished, the routing is a little rougher, but a great application.
    the play store version is a few behind the online download, per Google's restrictions on permissions/and in app purchases.
    #9
