1. ninja man
    ninja man Adventurer
    May 13, 2007
    36
    Hampshire,England
    bought the ktm removal kit part no 61305922144 but it comes with a blind connector for the electrical connector that doesn’t appear to have a resistor in it just blank plugs so either I have to leave the valve connected and just blank off air box and remove and blank cylinder plates so valve doesn’t do anything and FI code won’t come on or does the SAS not throw up a code if unplugged anyway?
  2. bionicman
    bionicman On your Mom
    Aug 19, 2005
    440
    WA
    apologies but the question is...?
    I used the rottweiler stage 3 kit but electrical connector is just a loop that tricks the ECU into thinking alls ok
    make sure you plug the airbox so all input air travels thru the filter
  3. ninja man
    May 13, 2007
    36
    Hampshire,England
    Is the loop on the electrical connector a specific resistance or is it just a loop for continuity that was what I was querying because the connector sent appears to be just a blank ie no loop, I know about the air box blanking from my 990 and 950 but it’s the electrics that confused me
  4. Lutarious
    Lutarious Renaissance Man
    Dec 28, 2013
    383
    Oakland
    You can try without the dongle thing. If it throws a code, try installing it. Im guessing it' not a blank connector, but you could test it just to be sure, then call Rottweiler or whoever you bought it from and ask what the correct resistance should be.
  5. bionicman
    Aug 19, 2005
    440
    WA
    what he said - test it before installing then call supplier with information if you have issues
  6. ninja man
    May 13, 2007
    36
    Hampshire,England
    It’s from Ktm power parts but good shout about testing it’s resistance (if any) ,thanks for replying
  7. Deviant
    Deviant aka KTM 1290SAdvR
    Aug 14, 2013
    3,741
    Curious to know if that's all you need. Update us.
  8. ninja man
    May 13, 2007
    36
    Hampshire,England
    Will do
    #8
  9. IanC
    IanC Been here awhile
    May 31, 2004
    400
    Minehead, Somerset, UK
    I'm amazed KTM are doing a SAS removal kit to be honest, is this new for the 1290? Available in all countries?
    #9
  10. ninja man
    May 13, 2007
    36
    Hampshire,England
    I bought it from ktm power parts it’s in UK dealers dunno about anywhere else ‍♂️
    #10
    IanC likes this.
  11. Dreedr
    Dreedr Ready to Roast
    Sep 24, 2017
    94
    WV
    The kit says it’s for a 2014- 2017 Super Duke R. Is that what you’re working on? Don’t know if there’s a difference.
    #11
  12. ninja man
    May 13, 2007
    36
    Hampshire,England
    Trip to the dealers to check as they said it will do the job as there’s no difference on how the sas systems work on either bike but I’ll still double check that I’ve not mis understood, it’s an 1190 r but I’m not changing air box just blanking off sas connection from it and removing and blanking cylinder connections so valve could stay connected electrically but it wouldn’t actually do any thing hopefully to reduce the popping on overrun with non standard exhaust also doing o2 removal. Just querying if the sas throws up a code if unplugged electrics no biggy if it stays in place as described before,just wondering
    #12
  13. ninja man
    May 13, 2007
    36
    Hampshire,England
    rang dealer and he says it’ll be fine left connected but without hoses as long as air box is blanked and cylinders blanked bike “brain” will carry on thinking it’s all good same as putting a resistor in its place . If I decide to mess with air box I’ll fit a power commander and have done with it cheers for advice.
    #13
  14. IanC
    May 31, 2004
    400
    I've got a Power Commander if you need one (Somerset). It's from an 1190, which has a different part number, but I'm told it works on a 1290.
    #14
  15. ninja man
    May 13, 2007
    36
    Hampshire,England
    Mine is an1190 r will give it some thought thanks for offer. Why aren’t you using it?
    #15
  16. IanC
    May 31, 2004
    400
    Had it on my 1190 R, but now got 1290 SA-R, don't really need it!
    #16
  17. wiseblood
    wiseblood Harshing your buzz
    Dec 29, 2008
    22,514
    New York City
    Does anyone know what the resistor ohms should be to remove the SAS valve? It’s a big hunk of crap I’d love to remove, if possible!
    I put a multimeter on the leads, and the OEM valve appears to have about 20 ohms resistance. Seems pretty low, no?
    #17
